  1. Apr 30, 2024 at 5:13 PM
    thebuildist
    thebuildist New Member
    Bob
    2017 SR5 Crewmax 4x4
    Rear seat storage
    I modified and installed an actuator for electric tailgate locking. It wasn't too hard to do with the cheapest actuator on Amazon. I made a bracket to bolt the actuator itself to the righthand side of the handle assembly. To locate the actuator itself: there's a black plastic arm coming off of the tailgate handle assembly, and that arm has a vertical shaft sticking up from it. The key cylinder lever moves that shaft back and forth. You just mount the actuator inline with the movement of that shaft, oriented like in the picture.
    Then I made a .090" flat steel traverse arm with a hole in one end just big enough for a #4 screw to join it to the actuator, and on the other end a hole just big enough to slip over the vertical shaft coming off of the black plastic arm. I removed the lever off of the key cylinder, put the flat steel traverse arm down over the black plastic shaft, and then replaced the key cylinder lever. The key cylinder lever now does dual duty as a retainer for my new traverse arm.
    There's just enough actuator travel to do the trick, so the location of the actuator has to be just right. In my case I measured carefully to get just the right length of traverse arm. But I could just as well have built the actuator bracket with slots to allow the actuator to be repositioned. But one way or the other, you do have to get the actuator in just the right position. But once properly adjusted it works 100%.
  2. Apr 30, 2024 at 5:52 PM
    SAGE63
    San Diego County
    love the lego man headrests
  3. Apr 30, 2024 at 6:41 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  4. Apr 30, 2024 at 6:50 PM
    koditten
    Kirk
    Midland of the Mitten
    They just in case I'm short on gas money...
  5. Apr 30, 2024 at 8:13 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I had been planning this installation for months before I finally decided to do it. Mainly due to complexity and time. Especially if it's 4x4 which adds more work. If it is 4x4, you must remove the front differential temporarely and cut one of the crossmember.
    I don't have much experience doing this kind of thing but I like to do it and learn as much as I can. There were many things that concerned me. But the things that worried me the most were two things. First, How to do this safely in the garage of my house. I made a wooden base for the jack stands. This way I didn't have to use them at maximum height. Also, added two additional jack stands and placed 4 rear wheel chocks. I bought an adapter for the jack to help lower the front differential. The other thing was time since for me this is a hobby and the time I have is limited. I tried to organize and think of all the possible things I would need to have available before I began.
    At this point I cannot recommend one thing or another because I am still in the process. But when I finish I can give you all the details and lessons learned so that you can make a decision with detailed data.
    I'm recording everything and my plan is to make a video with all the details, including those that aren't mentioned in the installation guide.
    Henry1jg, woods, WAtundra4x4 and 3 others like this.
  6. May 1, 2024 at 3:28 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Man, cutting the cross member underneath the differential isn't for the faint of heard. Good on your for tackling such a project
  7. May 1, 2024 at 3:47 AM
    Bergy24
    Bergy24 New Member
    Installed the Driver Side Grab Handle last Friday and installed some E Track to bed rail adapters so I could install some storage bins. I could have added T Nuts directly to the bins, but with the E Track I have more options and they are easy to remove if needed. I ordered another set of adapters and bins for the front as well.
    upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg upload_2024-5-1_6-45-29.jpg
  8. May 1, 2024 at 4:06 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    There's a Florida thread somewhere on here (or maybe southeast US thread); maybe post this question in there for a better response and more relevant exposure....
  9. May 1, 2024 at 4:16 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Good for you doing it on your own. When you finish you will know that it was done right. I’ve done many lift kits, body lifts , leveling kits but never a lift when I had to cut the crossmember, but I think I’m familiar enough with tools that I can do it… but yes it’s a hobby for me too, but man do I have a lot of nice tools! Thanks for the follow up, I’ll keep tabs on the build
    Tripleconpanna likes this.
  10. May 1, 2024 at 5:24 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I did a similar thing with the universal kit on Amazon. Can't beat 2 actuators for $9. That was about 3 years ago and still works well. Just gotta bend the mounting just right and mount the actuator with the right amount of travel for the piston to get full extension. I had all the wiring already so it saved me just about $200 vs buying the kit from the dealer.
  11. May 1, 2024 at 7:15 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    More camping. 75 mins from home. <3 AZ
  12. May 1, 2024 at 8:33 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Good stuff... Going to have to double that drive to get out of the heat pretty soon.
  13. May 1, 2024 at 9:47 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    What RTT is that? Looks very slim. I like the profile.
  14. May 1, 2024 at 10:01 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    You’re spot on, brother.
  15. May 1, 2024 at 10:02 AM
    singletrack_dad
    Ty
    2014 TRD OR CM
    Inspired overland RTT. Only 4” tall & 90lbs. It’s like it’s not even up there. It’s not roomy by any means but large enough for the wife and I up there no problem.
  16. May 1, 2024 at 10:11 AM
    thebuildist
    Bob
    Rear seat storage
    I really like the interior on my 2017 CrewMax SR5. Mostly.
    What I don't like is the cheap feeling shifter knob.
    My truck had 150K when I got it. And the spot where your thumb rests on the shifter was kind of worn down and kind of sticky.
    So I dug through my junk box and found a knurled aluminum shift lever. But it was drilled/tapped too large. So I drilled it about an inch deeper and tapped it to 8-1.25. And that was definitely better than stock. But it kind of sticks up too far in the air and was almost hitting my cell phone holder.
    So I decided to go low tech: this morning I grabbed a red Snooker ball. Drilled it inch and a half deep with a 17/64ths bit. And then tapped it 8-1.25.
    Perfection!
    Henry1jg, Velocity72, WFD473 and 6 others like this.
  17. May 1, 2024 at 10:16 AM
    Damie Street
    Edsel
    Is it comfortable?
  18. May 1, 2024 at 10:39 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Baller. Looks like the TRD shift knobs you sometimes see in 6MT Tacomas
    thebuildist[QUOTED] likes this.
  19. May 1, 2024 at 10:44 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Running the same on mine...
  20. May 1, 2024 at 10:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like a red lollipop
  21. May 1, 2024 at 12:23 PM
    Toyotech170891
    Toyotech170891 New Member
    2021 Limited Tundra 4X4 Magnetic Gray
    Painted my wheels with Spraymax 2k Hot Rod Black.
    Henry1jg, jclem65, MJustice and 17 others like this.
  22. May 1, 2024 at 12:26 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Painted? They look powder coated. :) Good job!
    Now...just avoid the curbs! :rofl:
  23. May 1, 2024 at 12:30 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Nice, those look great for an at-home job
    woods and Toyotech170891[QUOTED] like this.
  24. May 1, 2024 at 12:34 PM
    Toyotech170891
    Thanks. I should have powder coated them. took 2 months of weekends to do them. the wheels came off my 2017 that i had stored in the garage. i had the TRD Pro wheels on the 17 but got in a head on collision with that one and totaled the truck. i would have bought new TRD Pro wheels but the price doubled since i bought them last. im not spending over 3k for wheels. In less than 2 weeks i found a 2021 limited to replace my 17.
    BR73, WFD473 and woods like this.
  25. May 1, 2024 at 12:34 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    Nice looking wheels and you did a great job of painting them!
  26. May 1, 2024 at 12:37 PM
    Toyotech170891
    Loved that truck. I just paid it off before this guy came in my lane.
    BR73, kingpin3919, WFD473 and 5 others like this.
  27. May 1, 2024 at 12:45 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    What hit you?
    all ok?
  28. May 1, 2024 at 12:45 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Holy shit, glad you're still here to tell the tale!
  29. May 1, 2024 at 12:47 PM
    Timberline
    Gotta love a truck that gives it's life to save yours!
    bflooks, smurfblue40, WFD473 and 6 others like this.
  30. May 1, 2024 at 12:48 PM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Glad youre ok. What did the other car look like?
    IsaiahCanada likes this.
