Running boards for 2005 RC Tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by reverendmoon, Apr 29, 2024.
  1. Apr 29, 2024 at 6:44 PM
    reverendmoon
    reverendmoon [OP] New Member
    2005 RC V8/2WD 2UZ-FE
    I've been reading the threads and surfing the web - but haven't found any [RC boards]. Any recommendation would be appreciated.
    Tundra2 likes this.
  2. Apr 29, 2024 at 6:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Apr 30, 2024 at 10:11 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    There's also THIS thread. also, any frame mounted running board for the AC will also be for the RC
  4. Apr 30, 2024 at 1:53 PM
    reverendmoon
    "any frame mounted running board for the AC will also be for the RC"
    Really? Since the cab is longer for the AC, over the RC, it seems the Running boards for the AC would be longer than the Running boards for the RC? Or will the AC Running boards simply extend past the RC drivers door and run up to the rear wheel well? :) Sorry, just trying to make sure.
    Maybe the frames for the AC and RC are the same? Thereby allowing AC boards to fit on a RC?
    Sooooo much to learn. Great Forum!!!!
  5. Apr 30, 2024 at 1:55 PM
    AC and RC frames should be generally the same, with variations for V6 vs. V8. That and more info over here. DC frames are the weirdo birds.
  6. Apr 30, 2024 at 2:21 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    you know what's weird. Half a door. That's weird.
    abcinv likes this.
  7. Apr 30, 2024 at 2:39 PM
    Perfect size for my dog = perfect size for the door.
  8. Apr 30, 2024 at 4:18 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  9. Apr 30, 2024 at 4:25 PM
    w666
    Maryland
    The OEM style for AC (courtesy of PHM) might look OK on an RC
  10. Apr 30, 2024 at 5:08 PM
    reverendmoon
  11. Apr 30, 2024 at 5:17 PM
    First thought: www.car-part.com to find used and potentially even color-matching. But I'll forewarn you: If you can get them to let you remove, it's best. You need EVERY piece of hardware you can get, down to the screw; you CANNOT purchase the brackets and screws from Toyota.
    Second thought: Why not just go with something like what @abcinv installed, I think these are from n-Fab: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1543#post-3074713
    He'd also linked up these at one point that should fit AC/RC but they looked a bit sketch on quality to me: https://www.tundras.com/threads/nerf-running-board-sale-on-amazon.115139/#post-2972682
    abcinv likes this.
