  1. Apr 28, 2024 at 11:48 AM
  2. Apr 28, 2024 at 12:19 PM
    Went and did a trail with the local 4R group yesterday, about 10+ rigs and my truck made the group cover photo! B938ED09-C71C-4258-950A-04F994DB0264.jpg
    11689A47-E59A-40CD-A4EC-B8592F4069D4.jpg 95731844-9D92-4E17-88C9-A61BEB2559AC.jpg After the trail I noticed I had an admirer leave a note within the last few weeks after the last hose down…… kinda weird
    C816D291-B340-4B0C-BE1D-A643D9E52046.jpg Went and set up camp on the mountain at about 630 as dusk nestled into the canyon, camp ground was kinda noisy, so at one point I just started making loud noises to join in the fun….
    late night cake pop before bed, diesel heater kept us nice and toasty but I leaked all kinds of diesel in the truck bed(if anyone has reccos for getting that off/out) BDD77889-CF88-4321-B708-889683E51309.jpgBAF92CC3-B6F2-452A-82A7-EC8CD1EB6889.jpg B04DFD58-830A-4B0C-91F9-CD1CA3B9D3C9.jpggot up kinda early and packed up and headed to the lake. Kids were smashing it on the other side with power bait, but I’m not to much into bait fishing.
  3. Apr 28, 2024 at 12:22 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So there's not supposed to be a stair step but there is supposed to be? I don't know. Mine have one or two. Don't recall because I hardly drive it
  4. Apr 28, 2024 at 12:29 PM
    No stair step from the driver bulb up to the passenger. The top lines on both lights should be perfectly level.
    The step-down is purely to not blind oncoming drivers from the left half of the truck.
  5. Apr 28, 2024 at 12:32 PM
    For visual example, this is pretty wrong.
    This is almost right.
    G_unit3000, abcinv, 805Tundra and 5 others like this.
  6. Apr 28, 2024 at 1:13 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
  7. Apr 28, 2024 at 1:22 PM
    Voss
    Valod
    2003 AC TRD 4x4
    The folks who’ve removed theirs did so with 700lbs coils upfront. Disconnected mine and liked it a lot. Today I removed the bar.3DD156D7-3054-4B30-917F-7F84DD2AAEEE.jpg
  8. Apr 28, 2024 at 1:49 PM
    TacticalAnt
    TacticalAnt New Member
    2006 Tundra DC
    Headlight polish. After noticing the bad reviews on aftermarket headlight assemblies, and choking the price of OEM. I settled on polish and repair. One of the mounting tabs was broken off, so I reattached with an aluminum spine and a bunch of JB weld. Used a weighted 5 gal bucket and a bungee cord to hold the assembly while i sanded and polished the lens. 20240424_162949.jpg 20240426_103305.jpg 20240425_140205.jpg 20240425_123832.jpg
  9. Apr 28, 2024 at 1:52 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Think I’ve found what was causing the popping sounds from the front passenger side. EEB5B7DF-BD19-450A-ADEF-E4C8707F0F6F.jpg
    Came lose just by loosening the top bolt. Fairly sure the outer tie rod end needs a hammer to pop out from DIY video I watched.
  10. Apr 28, 2024 at 2:13 PM
    Looks like 98Nm to me. From 2003 FSM:
  11. Apr 28, 2024 at 2:15 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thank you
  12. Apr 28, 2024 at 2:15 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    72 ft-lbs (98 is nm). According to the pic/legend.
    455h0le_dachshund and Voss like this.
  13. Apr 28, 2024 at 2:17 PM
    Yup, Nm. I better go up and edit that before someone takes it for lbft.
    I always try to keep the legend in the screencap when I post those.
    Voss likes this.
  14. Apr 28, 2024 at 2:20 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ok so maybe Camburg does want 85. Had these on too tight then.
    Thanks
    shifty` likes this.
  15. Apr 28, 2024 at 2:38 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Those look almost as bad as mine were. Mine were factories with 209xxx miles on them. I don't know how the last 2 owners didn't notice that
    Voss[QUOTED] likes this.
  16. Apr 28, 2024 at 4:03 PM
    Voss
    Valod
    2003 AC TRD 4x4
    An alignment away from next weeks trip. Greased the UCA & ball joint, removed sway bar, replaced outer tie rods and I don’t know why but the most satisfying of reg maintenance, greased the driveshaft. Something about them 8 zerks that just hit different.
    Appreciate the help fellas
    jerb2, oscardog86, bmf4069 and 4 others like this.
  17. Apr 28, 2024 at 5:31 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Jba also calls for 85 ftlbs.
    Voss likes this.
  18. Apr 28, 2024 at 5:47 PM
    VR6T
  19. Apr 28, 2024 at 5:55 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I swear all you south Texas boys have the same backyard. Green square and a fire pit.
    Mr.Bee is the only outlier
  20. Apr 28, 2024 at 6:01 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i miss luscious soft grass when i'm at home. Even wandered around vr6t's backyard barefoot.
    grandpas backyard is more like home.
    Stole a rock from @bmf4069's hood for his collection.
  21. Apr 28, 2024 at 6:04 PM
    VR6T
    It's true he has and most likely will again. And I encourage him as I do the same
  22. Apr 28, 2024 at 6:07 PM
    VR6T
    Really You're going to post that comment and you live in Texas. How much of Texas that is owned is private land it's what greater than 90% correct. And if I could afforded a 45 to 55 minute drive from where I live now and if I had $320,000 to get 4 acres and a 1500 ft² house I would have. But I didn't so I bought within my means. That and it's not so bad where I live, ask @Mr.bee cul-de-sac no through traffic quiet neighbors and ample parking for all the tundra people that could come over all at one time if you also decided to.
    455h0le_dachshund and Mr.bee like this.
  23. Apr 28, 2024 at 6:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I dont miss having to mow once a week. 8 years ago you coulda been my neighbor. And had $50k to throw at a vagwagen. @VR6T you do live on the best possible suburban neighborhood street. Hopefully our trucks didnt disturb your neighbors.
    back on topic, i got to use my truck camping setup to make fajitas for the grandparents. Polo curled up under the truck & waited patiently, just like we were at hidden falls. He doesnt seem to mind where we go, just enjoys the trip.
  24. Apr 28, 2024 at 6:15 PM
    JakeJake
    2000 Tundra AC 4X4
    Not hating at all, your grass looks nice as fuck. Just very similar landscaping in that area from what I have seen.
    My "backyard" for reference. Bonus 1gt camper included to keep it on topic.
  25. Apr 28, 2024 at 6:17 PM
    My property consist of a 10x10 ft crabgrass lawn and 6” round tree root sticking 1/2 way out of the ground running across it.
    Due to HOA rules, I can’t even cut it out and get rid of it.
  26. Apr 28, 2024 at 6:25 PM
    VR6T
    Buffalo grass. It's not exactly cheap but itll grown in like 80% of Texas and it's a native grass.
  27. Apr 28, 2024 at 6:25 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @Jack McCarthy thats rough. Everyone needs enough yard for at least 2 junk cars.
  28. Apr 28, 2024 at 6:26 PM
    VR6T
    You can if it's ruining curb appeal or devaluing. Get 2 or more complaint and the devalue in writing and they'll have to let you remove it.
  29. Apr 28, 2024 at 6:31 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    that forklift a rental? Can it lift 9k lbs (40ft shipping containers)?
  30. Apr 28, 2024 at 6:37 PM
    JakeJake
    2000 Tundra AC 4X4
    Yes and yes. It really depends on the lift though. A 10k Telehandler only has that much capacity with the first section of boom out and within certain boom angles. The machine I need for the install is twice the capacity on paper, but 25' up and 40' of boom out it will only do 2,500ish pounds.
    VR6T, FrenchToasty and Mr.bee[QUOTED] like this.
