  1. Apr 24, 2024 at 8:02 AM
    I have play in my rack too. OEM/factory bushings. More slop than I like, but not a job I want to tackle right now.
    I just replaced my hoses also. I dunno why Vent hose #1 doesn't match what @importxpresions posted. My part ends in 70, not 50. This is one of those cases where I'd really urge you to use the EPC DATA website to source your part based on VIN rather than relying on me or others. It's super easy, plug your VIN into search box, search, hardest part from there is drilling down thru exploded pictures to find what you need. It's the most logical system I've been able to find.
    importxpresions likes this.
  2. Apr 24, 2024 at 10:00 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Finally did something with the battery hold down @DarkMint sent me a while back. Cleaned it up nice and painted any of the rough areas. Note my old ass battery that keeps hanging on, knock on wood.
    Figured I better get mine off before it gets worse.
    Guess I fat fingered both these pics.
    Gonna clean up my original so it can go on my father in laws truck. It's supposed to be back from "paint" soon after nearly 3 years.
  3. Apr 24, 2024 at 11:02 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    This is much better than how I was searching before. Thanks again. I really just want to make a delete or catch can for those pcv vapours but I can’t decide if it’s risky or not. I will look into it again when I clean/bypass the throttle body
    good work! Mine is dissolving and I need to do this also. And clean underneath the tray and hit it with some paint.
    Anyone have a photo of their 4.7 TB coolant bypass? Thinking about doing it for summer driving but want to keep it reversible
    455h0le_dachshund likes this.
  4. Apr 24, 2024 at 12:43 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Rust belt repairs. I remember fighting it growing up near Buffalo. Texas AZ NM are where it's at
  5. Apr 24, 2024 at 6:21 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I wouldn’t worry too much. I just replaced my bushings with energy suspension. Torqued to spec and they felt nice and tight for the first 20 miles or so now I can’t remember if they felt this loose or not. Probably marginally better but don’t feel as tight as the first ride. Maybe I’m getting used to them but still feel a little sloppy
  6. Apr 24, 2024 at 7:22 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So been having issue with turn signal not cancelling (turning off after turning left and then back straight). Been wondering if can just replace this stalk or if need to remove the steering wheel and replace the clock spring assembly. Have removed and verified the turn signal assembly seems to work but likely is not interfacing with clock spring? Read up and saw maybe there's a mod to just make the tab longer so it gets hit and cancels when the steering wheel spins back but seems like that involved a non permanent bit of black tape IIRC!? Any additonal advice appreciated.
    Edit: pretty sure its not the blinker fluid level so thank in advance for sparing that recommendation :thumbsup:
  7. Apr 24, 2024 at 7:47 PM
    VR6T
    It's definitely this
  8. Apr 24, 2024 at 7:49 PM
    Looks like something good for cleaning out the colon.
    VR6T[QUOTED] likes this.
  9. Apr 24, 2024 at 8:13 PM
    ToyotaDude
    ToyotaDude Member
    That won't work on the Topaz apparently.
  10. Apr 24, 2024 at 8:14 PM
    VR6T
    Well if you don't have a Topaz then no worries
  11. Apr 24, 2024 at 10:12 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Probably the stalk needs to be replaced. I replaced my OEM with a unit from Amazon or eBay because I wanted the stalk with the fog light switch built-in. The new one is very clicky when turning on the turn signals. Almost feels like I'm going to break it right before it actually clicks over. I figure over time it will wear and become less clicky. I think there is a spring in there that pops the stalk back when you finish the turn. Maybe yours is too worn now.
  12. Apr 25, 2024 at 3:33 AM
    ToyotaDude
    ToyotaDude Member
    Yes probably easiest to just try that. Then if that doesn't fix it r&r the clock spring next.
  13. Apr 25, 2024 at 3:25 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    Replaced 2 more hard brake lines (the 2 on the driver side in front by the frame rail) and bled the brakes (RR, PV, RL, FR, FL, then master bleed port with the truck running). Also changed the oil, spliced together a harness for my radio (PO used a pre-made harness with no provision for the parking brake which was needed to remove his phones from the radio and add mine).
    Hopefully Saturday I can swap the rear shocks.
  14. Apr 25, 2024 at 7:57 PM
    fk bud
    fk bud New Member
    jj
    2005 DC V8 4x4
    flatbed
    Changed up the roof rack today I found a old Thule basket but not sure how i feel about it yet.
  15. Apr 26, 2024 at 9:23 AM
    Finally had 30 minutes to swap out the screechy-ass non-OEM pads PO put on this damn thing with some OEM/Advics ceramics. But should've never started this at 8:30am before coffee, had to revers the pads on passenger side because I totally spaced on whether the screamer was inboard/leading or not. Meh. Noticed the paint marker indexes I had on my LBJ bolts came off, so re-tagged those and re-checked torque (all OK).
  16. Apr 26, 2024 at 9:31 AM
    Double springs. This is the way.
    G_unit3000, Tundra2, bmf4069 and 5 others like this.
  17. Apr 26, 2024 at 9:53 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I've always wondered if there should be one or two springs? Can't figure out if they intended to have two or not.
  18. Apr 26, 2024 at 10:01 AM
    I've seen both setups. I swore mine had two per caliper, but ... it was just one, on the high side. But since Advics pre-glues the shims on their kits and provides all new slide clips and springs, I tossed in the extras. Ain't killing anything. But I stuck with the OEM clips for the slides, I prefer that design better and they still had ample tension.
  19. Apr 26, 2024 at 10:12 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I've been curious if they help with preventing brakes from sticking and returning, but haven't been curious enough to try it. Maybe one day.
  20. Apr 26, 2024 at 10:41 AM
    I’m guessing you primarily only want it on the leading edge, similar to the screamer, i.e. only at the top of the caliper. The “springs” seem less like springs and more like retainers to me? They don’t really put a lot of force onto anything as far as I can tell.
    G_unit3000 and Kimosabe[QUOTED] like this.
  21. Apr 26, 2024 at 12:30 PM
    abcinv and kentuckyMarksman like this.
  22. Apr 26, 2024 at 4:51 PM
    artsr2002
    'Yonder
    Just ordered me a set of extended sway bar links from Suspension Maxx. Used MAXX10 discount code for 10% off. Noice!
    Pic attached before "pics or it didn't happen!" LOL
    bmf4069, Voss, RealTruck and 5 others like this.
  23. Apr 26, 2024 at 4:53 PM
    Have you tried no bar?
    #anti-antiSB
    oscardog86, bmf4069, Voss and 8 others like this.
  24. Apr 26, 2024 at 5:03 PM
    After driving my truck without the sway bar for the last 6-8 weeks, I honestly can't tell much difference. Maybe a slight change on the interstate but nothing concerning. I wish I had done it sooner.
    I had it off for a short time years ago and didn't like it but now I'm not sure why. I'm wondering if it was before I had ICON'S up front. I had those terrible Monroe's.
  25. Apr 26, 2024 at 5:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's why
    G_unit3000, Voss and shifty` like this.
  26. Apr 26, 2024 at 5:14 PM
    artsr2002
    'Yonder
    I've not. I could disconnect mine I guess n take her for a spin b4 installing the new ones.
  27. Apr 26, 2024 at 5:27 PM
    The only time I notice is if I need to steer going more than 40-45mph. It’s most pronounced if I’m needing to swerve to avoid something, or if I’m exiting a highway/interstate onto a ramp that does a 270° exit.
    Assdog is right. Monroes are squishy. That’s their claim to fame, if you want to call it that.
  28. Apr 26, 2024 at 5:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Where could i get an extra sway bar?
  29. Apr 26, 2024 at 5:32 PM
    You gotta be careful, if I understood correctly the passenger side mount is different for different years, some within the same year. Two diff’t parts guys and I were trying to make sense of it and failed.
  30. Apr 26, 2024 at 5:34 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What'd to do with yours?
    Hell we just scrapped mine the last time you were here.
    VR6T likes this.
