  1. Apr 21, 2024 at 7:07 PM
    Tire out of balance. 100%. Chances are you need to have the tires re-balanced, road-force balanced. This is classic tire balance symptoms.
  2. Apr 21, 2024 at 7:23 PM
    So only $41.00 work at the machine shop? Seems like there’s a discrepancy of $4,059.
  3. Apr 21, 2024 at 7:25 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    4100
  4. Apr 21, 2024 at 8:52 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Pulled rear axle and took to machine shop for a reasonable price to press off/on bearing that was getting loud.
    The retainers provided to the shop looking pristine came back like this. Have no idea how that could happen, like maybe it fell on the floor or something during install ....
    Scratches/pitting top left can be felt but assuming any scratching however small that would be under the seal lip is unacceptable, so planning to ask for retainer to be heated off and another installed since need the truck back up and running ASAP and don't have time to wait for the SST by mail. Too picky or this is a problem right?
    Hopefully new seal wouldn't be damaged from just the handfuls of spins to do the sharpie/grease test.
    Placement isn't bad but probably could be pressed another 1/2 mm more...
    Ordered 2nd bearing Friday proactively for other side, and plan to get the HF shop press and SST for that intall ... instead of relying on a shop again for this.
  5. Apr 22, 2024 at 4:51 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    That’s what I was hoping it was. Looks like back to discount tire. I wonder if it’s the Baja boss AT’s that are hard to balance. They’re a pretty agressive tire for an AT
  6. Apr 22, 2024 at 5:43 AM
    Guys at the Toy/Lex shop who mounted me up and balanced me out said all the Mickeys need road force balancing. And all the BFG KO tires too. You won't get balanced w/o it. They road force balanced my Baja Legend EXP and I still get an occasional little teeny tiny bit of shimmy.
    oscardog86 and KTM_AJ421[QUOTED] like this.
  7. Apr 22, 2024 at 11:35 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is there a way to upgrade from a 2 bolt to 4 bolt main?
    Asking for a friend.
  8. Apr 22, 2024 at 11:38 AM
    VR6T
    Yeah it's called a 1UZ. But it's not needed as I plan on a bout 12 to 14 pounds max.
  9. Apr 22, 2024 at 11:40 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fair enough ...
    You know @Mr.bee's beef with 2 bolt mains :D
    VR6T[QUOTED] likes this.
  10. Apr 22, 2024 at 11:42 AM
    VR6T
    Engine internals will be rated for 800hp, I'm looking 525 max. 485 to 500 is my goal. Work truck power. That and Chinese whistle boi noises lol
  11. Apr 22, 2024 at 1:13 PM
    Who was asking about 13WLs in a starfish?
    G_unit3000, Pnwtundy, Voss and 5 others like this.
  12. Apr 22, 2024 at 4:18 PM
    VR6T
    That's what I'm talking about a tight fitting starfish ;):thumbsup:
    bmf4069[QUOTED] and FrenchToasty like this.
  13. Apr 22, 2024 at 4:54 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've heard or read somewhere that only the forged 16's will fit. That cast trash has to be bigger.
    unless you let em rub for a bit.
    VR6T likes this.
  14. Apr 22, 2024 at 5:25 PM
    VR6T
    Rubbing is racing #racecar
  15. Apr 22, 2024 at 5:53 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    I was asking about them in these obscure stock 16”, but they were from 05-06 so they had to fit. IMG_2097.jpg
    Anyone have two center caps for this wheel?? Hard part to find
  16. Apr 22, 2024 at 6:12 PM
    VR6T
    Those are pretty nice wheels
    Bed Tundy[QUOTED] likes this.
  17. Apr 23, 2024 at 7:18 AM
    importxpresions
    importxpresions New Member
    2001 SR5 AC Imp Jade Mica 2WD
    It would probably be time to give the old throttle body a cleaning. Might help it idle a little better as well if the throttle plate catches any of that residue. I found it helpful on a lot of GM engines.
  18. Apr 23, 2024 at 7:32 AM
    flipoffartist
    flipoffartist New Member
    Jeff
    03 Gold AC 4x4 4.7 SR5
    Did my plugs and oil yesterday. After running Seafoam for 500 miles, the oil looked pretty gross. Will probably do a short interval for this next change and run Seafoam again. Also looks like I have some seepage on the very rear passenger spark plug tube. So tubes along with the valve covers will be added to the list, though it's a low priority at this point.
    Also my plugs were quite worn. Maybe originals? Idk.
    IMG_20240422_120221.jpg IMG_20240422_120232.jpg IMG_20240422_121108.jpg IMG_20240422_121125.jpg
  19. Apr 23, 2024 at 7:34 AM
    flipoffartist
    Jeff
    Do you have a build thread for this? I would be interested to follow along.
  20. Apr 23, 2024 at 8:05 AM
    importxpresions
    Here's the PN's for the hose, grommet, pcv valve, clamps, and pcv valve cover for my 2001. I believe yours would be different due to the VVTI and secondary air injection.
    These are the numbers for a 2005 (V8 AC 2WD, should be the same for 4wd) based on toyota parts now, which is a good reference.
  21. Apr 23, 2024 at 8:11 AM
    Just a note to @Bed Tundy though - your 2005 won't use the grommet, it's thread-in. Thus, your part number is going to be different also. Your 'o5 will probably match my '06 with a thread-in unit. Part number here - there's only one digit diff'ce between thread-in and non-thread-in.
  22. Apr 23, 2024 at 8:24 AM
    VR6T
    No not yet. But in the near-ish future. I have a few things that need fixed first
  23. Apr 23, 2024 at 8:36 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Isn't a build thread a thread of you fixing it?
  24. Apr 23, 2024 at 8:40 AM
    VR6T
    Lol
    It is a Toyota good sir, there are no repairs, only advanced maintenance.
  25. Apr 23, 2024 at 9:34 PM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    Been having what felt like the ABS kick in randomly when coming to a stop with the wheel turned. Turns out the passenger side ABS sensor was loose; quickest fix i've done yet!
    I also finally tracked down why my fog lights don't work. I thought it was originally due to the LED projector headlight mod, but even with stock bulbs they weren't working. No blown fuse, fog light relay was functional. When the switch was turned on, i couldn't hear the relay click. Hoping it was the switch and not a broken wire somewhere, i found this little nugget in the FSM:
    Sure enough, no continuity between pin 10 & 11 when the switch was ON. Ordered a used one off ebay for $35. i can't stomach the near $200 toyota wants for a new one at the moment.
  26. Apr 23, 2024 at 9:41 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    How long are those extended links I'm trying to put in the the same coil overs as you and feel like my new links aren't going to be long enough but haven't gotten that far yet
  27. Apr 23, 2024 at 10:01 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    When your new switch arrives, pop the old one off and try to get to the guts of that switch. Maybe a good cleaning will get it back in working order and you'll have yourself a spare.
  28. Apr 23, 2024 at 10:03 PM
    Pnwtundy
    Pnwtundy New Member
    Excellent idea, I'll make sure to do that!
    Tundra2 and artsr2002[QUOTED] like this.
  29. Apr 23, 2024 at 10:21 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Thanks! That hose looks about right.
    Thanks shifty, I have a new pcv and hose coming soon n the mail.
    Things I did today, Got the new wood door inserts today and they popped right in. It does look ok without the center bezel, but not great. I’m going to need more wood. Fresh oil change after 200mile Seafoam, alignment is perfect, new Wix air, $5 magnetic oil plug because why not? Greased Zerks, and did the DIY paper clip zero point calibration for the VSC. Got rid of every abs code I had.
    I had a shop check out the front suspension to make sure I’m not missing anything. Power steering has a tiny bit of play, boots throw a little grease but not much, however the driver LBJ has moderate 1/8” play. I thought this was super bad but my mechanic says I should be good for a few months until I lift and replace it. Leaving on a 500mile turkey hunt tomorrow, should I worry? I’ve seen the pictures
    JasonC. and shifty`[QUOTED] like this.
  30. Apr 24, 2024 at 7:56 AM
    Extended are +1"
    You should ultimately install extended links on any lift that's 1¼" or more.
