General Supercharger Thread
  1. Apr 21, 2024 at 6:43 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Those that watch and/or have a gauge for thier trans temps what do you use?
  2. Apr 21, 2024 at 6:44 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Mine is in my Kenwood HU.
  3. Apr 21, 2024 at 6:47 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    ultragauge mx. torque pro app is good too, and probably the cheapest way to do it
    HulkSmurf14 and NatesNightMare like this.
  4. Apr 21, 2024 at 6:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Pins 94, red wire and 93 green wire sensor 1.
    Pins 117 white wire and 116 black wire sensor 2 bank 1.
    Edit: just realized i looked on the 2010 diagram.
    e30cabrio[QUOTED] likes this.
  5. Apr 21, 2024 at 7:33 PM
    e30cabrio
    Thanks, I'd think they were the same.
    Mdl likes this.
  6. Apr 21, 2024 at 7:55 PM
    NatesNightMare
    Pinetop Az
    Where is that found? Play store?
  7. Apr 21, 2024 at 8:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yeah and the d53 module has the grounds.
    I chopped my thumb on a mandolin so I'm a bit bored...just relaxing looking at diagrams with this insane throbbing of pain.
  8. Apr 21, 2024 at 8:12 PM
    e30cabrio
    Sorry about the thumb. Thanks!
    Battery is sitting disconnected for the night, I really hope it isn't the sensors, they are expensive & a pita to get to.
  9. Apr 21, 2024 at 8:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I wouldn't think it be both sensors on bank 1 most likely at the ecu. Really only place that was touched was at the ecu plug.
  10. Apr 21, 2024 at 8:28 PM
    e30cabrio
    The codes are contradictory. O33D is no signal and 0228 is high signal.
    Wtf?
    Lol
    I'll pull the compressor out and check the connection after looking everywhere I can and sending Sniv a log.
    HulkSmurf14, snivilous[OP] and Mdl like this.
  11. Apr 22, 2024 at 7:45 AM
    helidave
    flagstaff
    2015 DC 4x4
    ultragauge is a screen that plugs into the obd2 port
  12. Apr 22, 2024 at 11:57 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I have a odd issue with starting. The issue started immediately after installing a set of 1000cc injectors form Prospeed. The truck will crank for a full cycle but wont start, will eventually start at the end of the second cycle and blow out a big puff of fuel smoke. The fuel pressure stays at 60psi and doesn't fall off after sitting. Other times it will start right up, warm or cold, doesn't matter, but not with the roar it had with the 750cc injectors. @snivilous and I are ready to set this thing a blaze and walk away, lol. I just wanted to put it out there to see if anyone else has had this issue. After start up it runs perfect, no issues at all.
  13. Apr 22, 2024 at 12:05 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    OBD Fusion app
  14. Apr 22, 2024 at 12:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Been there with no resolution. Glacially trying to gather data. I had the same starting issue with some Five O 750s. @Mdl offered to try them in his truck so he has them now and will report on his findings when he has the opportunity.
  15. Apr 22, 2024 at 12:10 PM
    Fastlane47
    Maryland
    2018 Platinum
    Yeah, it's nuts, I almost hate driving it now, lol almost.
    reywcms likes this.
  16. Apr 22, 2024 at 12:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I just shuddered when I had to start it, it was embarrassing. I tried a bunch of stuff, brainstormed with SlowNStock and Sniv. Different injectors, 750s from Prospeed, took care of it. The root cause is still a mystery though.
  17. Apr 22, 2024 at 12:25 PM
    Fastlane47
    Maryland
    2018 Platinum
    I may take them out and reinstall them tomorrow, move the cylinders around, I'm not sure if that will do anything.
  18. Apr 22, 2024 at 12:26 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    soak them bitches in cleaner and blow them out
    couldn’t hurt
    <don’t listen to me>
    Fastlane47[QUOTED] likes this.
  19. Apr 22, 2024 at 12:27 PM
    Fastlane47
    Maryland
    2018 Platinum
    They have about 300 miles on them, lol.
  20. Apr 22, 2024 at 12:43 PM
    e30cabrio
    No fun, hopefully Prospeed will help.
    No change from the battery off all night, except a single cylinder coil code that cleared. I have not moved all day from my computer, a client was hacked & I have been disabling systems since 4am PST. :p
    FUN!
    Mdl and Fastlane47[QUOTED] like this.
  21. Apr 22, 2024 at 1:10 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I had the exact same issue with my DW 650s. I wasted tons of time messing with airflow values in HPT and got nowhere. And then it just stopped happening in one of my tune revisions from @snivilous. I think it was just the right combination of injector constant and MAF values, but I don’t have a clue.
    ARES35, Wynnded, Land Bruiser and 4 others like this.
  22. Apr 22, 2024 at 1:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I found if I don't let the pressure build up it starts by third revolution.
    I chopped the side of my thumb off with a mandolin accident. Had to throw out a perfect sweet onion. Anyways hope to install and test soon.
    ARES35 and Wynnded[QUOTED] like this.
  23. Apr 22, 2024 at 1:46 PM
    blenton
    blenton New Member
    You must have been rockin hard to Beethoven for that mandolin to have gone medieval on your thumb like that… I can only imagine what sort of bloody power ballad you were strumming up :headbang: :sadviolin::drunk::duel::help: :headbang:
    bflooks, ARES35, Wynnded and 3 others like this.
  24. Apr 22, 2024 at 1:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Hahaha like deli sliced ham...or onion!
    ARES35 and Mdl like this.
  25. Apr 22, 2024 at 1:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I figured there would be one. Haha but it does suck as I can't play the bass strings with my thumb now...
    ARES35 and HulkSmurf14 like this.
  26. Apr 22, 2024 at 2:14 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    What's funny is that's what I pictured first when he said it. I was imaging him sitting crosslegged on a Persian rug and smoking a hookah while playing. Or is that a sitar?
  27. Apr 22, 2024 at 2:50 PM
    ARES35
    ARES35 New member for life
    Mile high
    I'm confused?? An actually Mandolin or a knife slicing an onion....WTFIGO lol
    snivilous[OP] and Mdl[QUOTED] like this.
  28. Apr 22, 2024 at 2:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok...so I guess I left off an "e" for mandoline... ol' Android keeps saying mandolin. But I wish my playing skills were that good to cause an injury.:D
    Wynnded and ARES35[QUOTED] like this.
  29. Apr 22, 2024 at 2:57 PM
    HulkSmurf14
    2014 Tundra Limited
    You guys need to get out more and make stuff!
  30. Apr 22, 2024 at 3:00 PM
    ARES35
    Mile high
    I had to look that shit up lol. I take it that it did not come with gloves lol
