Help! Leveling kit has caused all kinds of problems! 2023 Limited w/ TRD pkg
Discussion in 'Suspension' started by UofAkicker1, Apr 18, 2024.
  1. Apr 18, 2024 at 6:59 AM
    UofAkicker1
    UofAkicker1 [OP] New Member
    2023 Tundra Limited CrewCab 4X4 TRD
    2" leveling kit
    I'm sure this has been addressed ad nauseum, but could use some advice that I can't find. Had a leveling kit installed yesterday by a shop that has done multiple kits for us in the past (1st one on a newer Tundra. This truck is a previous Canadian vehicle, but now in the U.S. with conversion to miles, etc) After the kit was installed, we now have warning messages concerning pre-collision system malfunction, braking power low, and parking support brake malfunction. My question is, can we simply remove the leveling spacers and take the truck back to original specs or does it have to go to a Toyota dealer to have the system reset? I understand the problem is changing the sensor/camera angles, so the other question is, can we raise the back slightly to put the angle back to the "original" rake? I'm also concerned whether or not a previous Canadian truck can "communicate" with U.S. software to reset the system. Sure appreciate any help.
  2. Apr 18, 2024 at 7:05 AM
    The TSS or whatever the system is now called requires a re-calibration for the new ride height. Dealer and some other shops should be able to perform.
  3. Apr 18, 2024 at 7:13 AM
    UofAkicker1
    2" leveling kit
    KNABORES....thx for the response, but do you happen to know if we simply remove the leveling kit and take it back to factory specs, will the system reset itself or does something still have to happen at the dealer end?
  4. Apr 18, 2024 at 7:29 AM
    UofAkicker1
    2" leveling kit
    I disconnected the battery last night for a couple hrs and then started the truck. All warning stuff still on. Any idea if the system will reset itself if the truck is put back to factory suspension specs?
    ryanwgregg[QUOTED] likes this.
  5. Apr 18, 2024 at 7:39 AM
    I’m not sure on that. It threw it out of what when it was adjusted, so even if u did put it back to stock, it may still need to be re-calibrated.
  6. Apr 18, 2024 at 7:40 AM
    Do you want it back to factory? If not, just get it recalibrated.
  7. Apr 18, 2024 at 7:44 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I did a 1.75" level on mine and had no issues with any sensors. Then I changed my grille to the heritage style and which had me play with the front camera and still issues.
    Then I put a 1" Westcott lift in the rear and still no issues.
    I haven't had to touch the sensors or go to the dealership for any of this.
    Markus likes this.
  8. Apr 18, 2024 at 9:15 AM
    tuns_o_fun
    tuns_o_fun New Member
    JR
    23 SR5 Off Road
  9. Apr 18, 2024 at 9:17 AM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Also did the RC 1.75 on my 23' 1794 with zero issues. What lift did you use? Doubt it matters, only curious
  10. Apr 18, 2024 at 7:46 PM
    UofAkicker1
    2" leveling kit
    Just an update. Took the truck into the local Toyota store. They got it in today and recalibrated the system to the tune of $200. No more warning lights, so lesson learned. Probably shoulda gone with the 1.75" leveling kit rather than the 2 incher. Thanks for your help in your posts.
    KNABORES and T-Rex266 like this.
