2005 AC 2wd rotor holes are about 1/16 of inch oversized
Discussion in '1st Gen Tundras (2000-2006)' started by mpaler, Apr 13, 2024.
  1. Apr 13, 2024 at 1:21 PM
    mpaler
    mpaler [OP] New Member
    Vladan
    2005 Tundra 4.7l
    none
    Hello all , my 2005 Tundra has 85,000 miles on it, lately I started to feel a bit of slop in the steering when going over less than smooth surface. I am not talking about off road here, but think of an extended rough patch of roadway. before I bought the car , it spent its life in the California desert area as a daily driver to the elderly couple I bought it from, so a lot off dry rubber to deal with. I dont see any tease around the obj, the strut bushings are pretty dry, the anti sway bars links are shot, drivers side tie rod end has grease. Beside the obvious rubber pieces to replace, any suggestions on how far to take the rebuild?
    Another interesting thing- the rotors were replaced, but I notice the holes are at least 1/16 of inch oversized compared to the studs. Is this normal?
  2. Apr 13, 2024 at 3:13 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    that's normal
    des2mtn and KNABORES like this.
  3. Apr 13, 2024 at 3:43 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
