Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Apr 5, 2024 at 9:09 AM
    #1111
    Willard
    Willard New Member
    2024 F250
    The reality is that it is not the cover that's leaking. It's the design of the plastic bed rail caps and gaps between the front and sides of the bed box. At the back end there are giant gaps between the tailgate and bed sides, too.
    I have touched on this before, but over time the pressure applied to the bed rail caps by the cover, along with the bed flex that occurs when driving, will cause the ribs on the underside of the caps to wear into the paint on the top of the bed rails.
  2. Apr 5, 2024 at 10:18 AM
    #1112
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Yeah I bought mine used. I am not worried about it but would like to get it to leak less.
  3. Apr 5, 2024 at 1:00 PM
    #1113
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    For sure. The tundra isn’t great for this cover to not leak. I’ll do the best I can to plug up those holes with silicon and live with it. I wonder if bed stiffeners would help with that wear at all? Probably not
  4. Apr 5, 2024 at 1:57 PM
    #1114
    shawn474
    MoCo, Maryland
    I have bed stiffeners…..don’t help
  5. Apr 6, 2024 at 2:34 PM
    #1115
    Bergy24
    Bergy24 New Member
    Since I bought my Tundra, I could hear a squeak when the rear window was down. I thought for sure it was the window itself but today I put the window down for the first time with the Diamondback cover installed and noticed the squeak is gone. I guess it was the old cover. Another bonus to switching to the Diamondback.
    NewImprovedRon likes this.
  6. Apr 11, 2024 at 8:04 AM
    #1116
    Outbound
    Aaron
    Northern Alberta
    Anybody had any issues taking your Diamondback off and putting it back on multiple times?
    I have some projects to do this spring and I'd like to use my truck bed for hauling materials vs renting or buying a trailer.
  7. Apr 11, 2024 at 8:17 AM
    #1117
    shawn474
    MoCo, Maryland
    It isn't hard or that time consuming. Easier with help though the panels are particularly heavy. The hardest part is lining it back up when you're reinstalling. I used a silver paint pen and marked the middle panel on my rails prior to removal. Made it much easier to reinstall.
  8. Apr 11, 2024 at 8:21 AM
    #1118
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I would protect the threads on the clamps with a ceramic spray of some sort like "Walter Rock and Roll". And like @shawn474 said about marking the center section position.
    Outbound likes this.
  9. Apr 11, 2024 at 8:43 AM
    #1119
    Outbound
    Aaron
    Northern Alberta
    Yeah, I don't see it being hard to do. Good tip about marking the middle panels, thanks!
  10. Apr 11, 2024 at 9:09 AM
    #1120
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    That will work well. Also apply some masking tape on each end of the middle section to mark where it needs to be reinstalled will work.
    shawn474[QUOTED] and Outbound like this.
  11. Apr 11, 2024 at 2:27 PM
    #1121
    Willard
    Willard New Member
    2024 F250
    I also marked exactly where the center panel sat on the bed rails so it was very easy to reinstall.
  12. Apr 12, 2024 at 10:56 AM
    #1122
    therealjonwick
    JR
    2019 OR
    Did a little silicone work to fill the gaps in the bed rails. Seems to have stopped rain from leaking on the sides. Just have to figure out the bulkhead. Used some leftover thin neoprene foam rubber I had. Perfect thickness. Stuck it on and pained silicone on top.
    Ray D likes this.
  13. Apr 12, 2024 at 1:18 PM
    #1123
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    @therealjonwick. On a side note, I like your Wavian jerry can install and I'd like to do the same install with mine. What hardware have you mounted on the bed side walls for securement of the jerry can? Also, I have had issues with multiple pour spouts for my Wavians as they all leak at the metal/plastic joint. Have you had any leakage issues?
  14. Apr 12, 2024 at 4:15 PM
    #1124
    therealjonwick
    JR
    2019 OR
    Thanks! I just got it so I have not used it. I will keep an eye out for that. I purchased the can holder recommended through Amazon: https://www.amazon.com/dp/B0BGSP7HX2 I used vibratite on all the screws.
    I mounted it to my molle panels. Cali raised. I used their mounting kit hardware through the holes of the can mount. Two in the top holes, then zip ties on the bottom. Can is full and is secure while driving. I did notice a bit of paint wearing off on the mount. Nothing too crazy. I might add some more neoprene rubber to those areas.
    NewImprovedRon and Ray D[QUOTED] like this.
  15. Apr 13, 2024 at 4:30 PM
    #1125
    therealjonwick
    JR
    2019 OR
    What bed stiffeners do you have? Trying to get a set. Not sure what are the best out there. Also want to cut my bed mat as little as possible.
  16. Apr 13, 2024 at 4:37 PM
    #1126
    shawn474
    MoCo, Maryland
    I honestly forget the brand; no idea.
  17. Apr 13, 2024 at 4:40 PM
    #1127
    therealjonwick
    JR
    2019 OR
    They look like Total Chaos but a bit different
  18. Apr 13, 2024 at 4:44 PM
    #1128
    shawn474
    MoCo, Maryland
  19. Nov 11, 2024 at 9:36 AM
    #1129
    ZuzKu
    ZuzKu New Member
    2024 LTD Tundra Mex Edition
  20. Nov 11, 2024 at 9:56 AM
    #1130
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My Uptop racks sit on each cover section of my SE. It mounts to the cover cleats like the gettrukd does but has 2 separate sections so you can open the covers up without taking the rack apart.
    When the tent or bike racks are attached, this becomes more of a challenge to open. Not too sure how to answer the flimsy question, this is certainly not flimsy!
    littlebus01 likes this.
  21. Nov 11, 2024 at 10:13 AM
    #1131
    ZuzKu
    ZuzKu New Member
    I'm looking at the TRUKD brand bed racks because they're supposed to let you use fully the DB Cover. But since the bars on them go straight up, they make me wonder if they'll hold when rtt camping on high winds.
  22. Nov 11, 2024 at 10:48 AM
    #1132
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Sorry, I see what you talking about now. They attach under the cover to the bed rails. I would expect a little water ingress at those mounts but nothing is really waterproof anyway.
    They might move around a bit without cross bracing of some sort. With the heavy weight up top, I can see them sloshing around. Just my thought.
  23. Nov 12, 2024 at 4:28 AM
    #1133
    shawn474
    MoCo, Maryland
    So are you saying that you’re looking for a rack that will allow you to open the diamondback while a rtt or other accessory is attached to the rack?
    I have the Yakima overhaul hd clone rack and the Yakima rails that I installed onto the cover….i can open the cover when I don’t have anything on the rack but if I have bikes, kayaks, skis, etc attached it doesn’t allow for opening of the cover.
  24. Nov 12, 2024 at 7:14 PM
    #1134
    Willard
    Willard New Member
    2024 F250
    The trukd looks flimsy at the point where it bends 90 degrees to go under the edge of the cover. There’s no reinforcement at the bottom to limit side to side flex if there’s something heavy mounted on the rack.
    I do see what looks like a small triangular brace at the top corners. Maybe that’s enough?
    If it’s really important to be able to open the bed cover with a tent on top you might consider a retractable like a retrax with the T slot side rails. There are tons of rack options that use this interface.
  25. Nov 23, 2024 at 11:24 AM
    #1135
    wysongdog
    wysongdog New Member
    Love mine but should’ve gotten the switchback tho. Going to put a gooseneck ball in for pulling our little horse trailer.
  26. Nov 23, 2024 at 11:33 AM
    #1136
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have my second Diamondback (was on the Gen 3 Tundra 6.5 Bed for almost 2 years). This one is an SE which is a tab lighter than the HD.
    I took the cover off and was able to squeeze it onto the Chevy 1 ton and it fits. This was a big question for me and since I put it on, I saved about $3k. It is an inch smaller all around but the seal does make contact and the locking bars work too.
    The Diamondback cover is great and well worth any inconvenience
    IMG_2954.jpg ce especially if you switch to a Chevy :)
  27. Dec 13, 2024 at 7:04 PM
    #1137
    wysongdog
    Has anyone tried the switchback yet?
  28. Dec 13, 2024 at 10:30 PM
    #1138
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I haven't tried the switchback but it does look like it fills a need. The one I have allows me to mount my rack and stuff. Not too sure if the switchback would allow that?
  29. Dec 14, 2024 at 8:15 AM
    #1139
    wysongdog
    Yeah I’m not sure if you could mount a rack on it or not. If I could get rid of my 270 I would try it and see. But I’m kinda thinking it wouldn’t work with a rack the way they fold up to the front.
  30. Dec 16, 2024 at 8:12 AM
    #1140
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    I have a diamond back cover and use the BillieBar rack with it for a rooftop tent. Having a rack mounted to the rails under the diamondback does allow water to seep into the bed. The reason I like the setup though is that I’m able to open the part over the tailgate end about 5 inches. I know that doesn’t sound like much but when I slide out my fridge, I’m able to open the top of the fridge and access both compartments. In a perfect world, I’d like to mount my tent higher but my garage door is only 7 feet high; don’t like parking outside anymore. LOL!
