  1. Apr 12, 2024 at 10:19 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah apparently. Just needs more sealant. It lasted a few years I guess.
  2. Apr 12, 2024 at 10:35 AM
    I put sealant on the metal opening before clicking the clips in so the base of the clip is sealed. Then a dab over the screw hole before putting the screw back in. No leaks in 10 years since.
  3. Apr 12, 2024 at 10:37 AM
    NickB_01TRD
    KY
    I'll probably go that route then.
  4. Apr 12, 2024 at 10:43 AM
    Ok, so ... edited my post above to say: You've got two used (but solid condition) clips incoming, and there's absolutely no way the OEM clips can drip from the screw/fastener hole in the clip, there's no exit hole. So water purely comes from the seal between the plastic clip and cowl hole. I think you just need a better sealant, and it won't really help putting sealant over the hole if there's no way for water to pass thru.
    I think the little piece of cheap, thin foam they prodive is a huge part of the problem, especially if you don't snap them in far enough. As I saw from the ones I pulled out also, you can't really re-use, half of mine were brittle enough to crack off one of the retention clips during removal.
    Meh, I dove in w/o. You'll be fine.
    Don't use silicone, at least not with ammonia, it'll promote/cause rust. PHM swore by Fuze It, which is a Liquid Nails adhesive product.
    Whatever you put on there, use a plastic razor or something to cut it off, then go over the area extensively with rubbing alcohol before next application.
  5. Apr 12, 2024 at 10:53 AM
    NickB_01TRD
    KY
    Yeah I just hoped the rubberish seals on the new clips would be good enough.
    Hmm hadn't heard that before, was thinking of just sending it with some RTV because I already have it. Maybe I should go with something different.
  6. Apr 12, 2024 at 11:00 AM
    daveeasa
    Yeah I was thinking RTV too. Geez. This is like brain surgery.
  7. Apr 12, 2024 at 11:01 AM
    I think somethign that hardens but remains semi-flexible would be perfect. I think that's what PHM said that stuff is. "Flexible adhesive".
  8. Apr 12, 2024 at 11:14 AM
    I believe I used red RTV. It's what I had.
  9. Apr 12, 2024 at 11:31 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Yeah I think 2005-06 had it. unless I'm misinterpreting what "trac" and the little car sliding light means. I had never heard of the Auto LSD this truck has either until I picked it up yesterday. I wonder if its better or worse than just a mechanical LSD.
    Both? it seems to be mostly black cloth, maybe fading a little. I'm actually going to miss my bench seats and the middle space, it was a great safety feature for my big dog too. In sudden braking he never flew to the front
    Thank you for the tips n tricks Shifty, I will let you know what I find.
    I will try that product out thanks, my topper still has a good amount of shine, it would look weird with the dull white.
    bmf4069[QUOTED] likes this.
  10. Apr 12, 2024 at 11:52 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I recommend it to everyone at least in the front. If you hit a pothole and go “oh f***” and clench cause you know what it’s about to feel like…. Buy good bump stops haha.
    oscardog86[QUOTED] and des2mtn like this.
  11. Apr 12, 2024 at 11:53 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I bought the truck 4 months ago at 275k miles with the damaged seat. It's stock height with no running boards.
    VR6T likes this.
  12. Apr 12, 2024 at 11:59 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Probably added an easy 10-12HP with the new grill badge that I’ve had sitting in the garage for almost 6 months.
  13. Apr 12, 2024 at 1:16 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Damn rust belts for real, I forgot from not living in Upstate NY for the last 22 years
  14. Apr 12, 2024 at 1:24 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Thanks man, the paint definitely has some unseen issues, drivers fender has some surface iron rusting all over it and there are plenty of scratches that need to be taken care of but the photo hid them well.
  15. Apr 12, 2024 at 2:41 PM
    fk bud
    fk bud New Member
    jj
    2005 DC V8 4x4
    flatbed
    got the last part to my roof rack sorted and also the new emblem came in the mail :oldglory:
  16. Apr 12, 2024 at 3:46 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I’ve got an Ethics question for the group. I wanted to buy a Tundra from a guy 10 hours away. We’ve been going back and forth about when/where we can meet. 2006 limited (wood/leather) AC. 150,000 miles and very clean inside and out for $11,000. I told him it had to have a new timing belt- he checked and it was the original so he replaced it. found out it needs new brakes and tires, but will keep the price the same as he paid for the timing belt.
    He asked me if I wanted to pay to replace the badly cracked windshield, I said yes, and his family replaced it for $500-700 including labour, of which I haven’t paid anything.
    Now I want to bail on this truck all together. I like the guy, and don’t want to fuck him over, but what do I owe him? Imagine you’re in his position- just paid for the windshield- and my position- paying for a windshield I will never see.
  17. Apr 12, 2024 at 4:03 PM
    He’s obligated to insure it’ll pass inspection unless selling “as is” goes up to the asking price. Sort of surprised he was willing to replace the belt when that should’ve been on you. Not sure what to say myself. Guess you have no choice but to give him the bad news.
  18. Apr 12, 2024 at 4:07 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I was intimidated by it too. I waited forever to do it and kicked myself for nott doing it sooner, because I ended up having to replace my blower motor, due to the water ruining it.
    daveeasa[QUOTED] likes this.
  19. Apr 12, 2024 at 4:09 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Shoot the guy straight just like you did here. Theres a happy medium in there somewhere. He will likely make his money back selling a better truck than he had before, but if I were in that situation I would be willing to throw the guy a couple hundo for his time/troubles.
  20. Apr 12, 2024 at 4:19 PM
    @FirstGenVol, my brother in mangling, grant me your protection in the battle to come, for tomorrow with be a day filled with cursing, learning, mich ultras, and many trips to the supply house.
    oscardog86, Kimosabe, BroHon and 7 others like this.
  21. Apr 12, 2024 at 4:22 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Yeah, I wouldn’t have been interested if I had to drive home on that 20 year old belt.
    I feel obligated to pay for something, he asked me and I said yes. I couldn’t just not pay if this was an any sort of business, but he will still own it afterwards.
    I see 4 options.
    #1.) Pay full ($700)
    #2.) pay materials not labor ($460)
    #3.) pay 50/50 ($350)
    #4.) or pay nothing. (probably still $100)
    I’ve got major guilt over this and will go with what the group majority thinks haha
    Should I put you down as #3.) 50/50?
  22. Apr 12, 2024 at 4:32 PM
    What is the reason you no longer want to buy the truck?
  23. Apr 12, 2024 at 5:12 PM
    daveeasa
    I have time this weekend so maybe if I find the box of parts it makes the cut. I want to get the Gentex mirror done in the Tundra as well and I’m tempted to try to get seat heat or heated mirrors going in the tundra and maybe heated mirrors in the Tacoma. I’ll review the list of mods.
    Also super intent on yellr box for the ‘05 and doing permatex gasket on both trucks to seal the harness entry up.
    Definitely want to clean up a couple of things on the ‘16.
    probably won’t get very much done at all but always good to make some progress.
  24. Apr 12, 2024 at 5:23 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Reminds me I need to wire my gentex one of these days... And my ditch lights.
  25. Apr 12, 2024 at 5:23 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I impulse bought a shittier one for half the price. Doesn’t look as nice but can have the other $5k in tires and suspension now
  26. Apr 12, 2024 at 5:26 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yeah, you at least owe the dude then for time and broken promises. I’ll jump on that 50/50 train. Besides, he made the truck better and more valuable for the next interested buyer
    oscardog86 and FrenchToasty like this.
  27. Apr 12, 2024 at 5:29 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Can’t tell if you’re telling me to jump on or off the 50/50 train. You’re the coin toss, I’m going to do it.
  28. Apr 12, 2024 at 5:35 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Would a conditional offer make everyone happy that covers the cost if it can't be recovered from another buyer by selling the better truck at a higher price?
    oscardog86, NUDRAT and JakeJake like this.
  29. Apr 12, 2024 at 5:41 PM
    JakeJake
    2000 Tundra AC 4X4
  30. Apr 12, 2024 at 5:47 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I like this idea, but I feel like it would come across as more BS if I don’t actually pay him anything.
    Yeah, I’m trying not to be haha
