SCS 17x8.5 -10 or Others
Discussion in '1st Gen Tundras (2000-2006)' started by prichardson, Apr 10, 2024.
  1. Apr 10, 2024 at 5:47 AM
    prichardson
    prichardson [OP] New Member
    Patrick
    2006 DC 4WD
    Timerland Mica Tundra SR5
    Anyone running the 17x8.5 -10 offset scs wheels? I had a hard time finding many concrete answers… if so would love to see them or any other size and offset to help me choose
  2. Apr 10, 2024 at 6:22 AM
    I'm running those. Are you just wanting pictures or something else?
    I have quite a few more on my Instagram. OG_Tundra
    I've posted a lot on the forum too.
    des2mtn and The Black Mamba like this.
  3. Apr 10, 2024 at 6:31 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Same wheels, same offset, different colors. Different angled pics for you as well.
  4. Apr 10, 2024 at 7:28 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    EvilMilkshake[QUOTED] likes this.
  5. Apr 10, 2024 at 8:18 AM
  6. Apr 10, 2024 at 3:20 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Checking in. I think they look great
    FirstGenVol and The Black Mamba like this.
  7. Apr 10, 2024 at 3:43 PM
    prichardson
    Patrick
    2006 DC 4WD
    What tires are you guys running? And any rubbing without cutting?
    KTM_AJ421 likes this.
  8. Apr 10, 2024 at 3:46 PM
    Well, AJ has his right under his username, 265/70R16 (Falken Wildpeak)
    FGV is running 285/70R17 (BFG KO2)
    EM is also running 285/70R17 (Cooper Discoverer Rugged Trek)
    I'll save everyone the effort, tire/wheel stalker over here. :rofl:
    The Black Mamba likes this.
  9. Apr 10, 2024 at 4:02 PM
    285/70/17 actually
  10. Apr 10, 2024 at 4:54 PM
    Typo'd on both of you 17'ers, sadly, with my size. Was rushing off to grab the kid at soccer.
  11. Apr 10, 2024 at 5:37 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I have to update mine but they are 265/70R17’s. I’m 2wd so I did have plenty of rubbing after install. Tires are Mickey Thompson Baja boss AT’s so a pretty agressive all terrain. I went with bilstein 5100’s on stock coils, notch 2 at .75” of lift and solved about 99.9% rubbing.
  12. Apr 10, 2024 at 8:32 PM
    prichardson
    Patrick
    2006 DC 4WD
    @shifty` @FirstGenVol played with tire dimensions today, currently on, 265/75/16 on stocks. Looking for a skinnier tire than 285's (wanting to keep mpg's up and less rolling resistance) yet larger than 265/70/17's thinking of 255/80/17's any experience or know anyone running them?
  13. Apr 10, 2024 at 11:36 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I think the 265/70r17 will be more than you think they are. In a lot of new trucks they are stock but paired with a 1 or 2” lift they are pretty big on our trucks
    shifty` likes this.
  14. Apr 11, 2024 at 2:44 AM
    Underrated size … 1” taller than the stock 265/65r17 size but same width so suspension rub is practically eliminated as a risk. Next reasonable size jump is 275/70r17 which only gives you ~0.6” diameter increase while adding 0.4” width. Same story going from 275/70r17 to 285/70r17, adding ~0.6” height and 0.4” width.
    The most dramatic 17” tire diameter height jump comes staying with the 265 but bumping up from 265/65 to 265/70. The gains after that seem minimized, you’re mostly getting fatter/more sidewall and adding more weight, eh? But maybe my perspective is flawed, or I’m missing something a tire expert could point out.
  15. Apr 11, 2024 at 3:21 AM
    I don't feel like debating tire size anymore. It has been discussed constantly for years. You'll get a lot of different opinions here. Do a search to get more info. 255/80/17 are a good option but make sure you check the weight. New tires keep getting heavier. The numbers surprised me.
  16. Apr 11, 2024 at 10:54 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I ultimately didn’t go with the 255’s since the scs wheels are 8.5” wide. That’s almost stretching it on a 255 tire doesn’t give you much sidewall to work with was my reasoning. Not dramatic but enough to keep me from getting them.
    FirstGenVol and shifty` like this.
  17. Apr 11, 2024 at 2:13 PM
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    255/80/17 isn't stretch at all on our 8.5" wheel.
    3C0CF656-95C7-4FAB-BE2E-065776184FE9_zps_a9f6441b38c7fc852f2ba6b267318c9d6556ad29.jpg
    BFE6BFE8-AB8B-4682-B8FD-660E780E8B78_zps_b02c4f829807bd974b4d5f0cd99f8986c30a9a73.jpg
  18. Apr 11, 2024 at 3:47 PM
    SCSPerformance
    Vin
    Bay Area, CA
    Here are some 1st gens with 17x8.5 -10mm
    B7208A03-66A4-494D-98F8-6A7D10AC8A69_zps_ad731d6468d0ae53f761f72a2c8292ee5cbdfeec.jpg
    This is 17x9 -38mm
  19. Apr 11, 2024 at 7:22 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    that’s good to know , those look great!
