Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Jul 8, 2023 at 7:24 PM
    #181
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I wanna say it comes more from the front but it's a good question. I leveled out the front and did the ras identical both sides and I'm dead even
    DZ_[QUOTED] likes this.
  2. Jul 8, 2023 at 7:36 PM
    #182
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    I did a little, didn’t take much for the 26 gallon tank, but I’m planning to upgrade to the transfer flow so I’m sure I’ll need a bit more then.
  3. Jul 15, 2023 at 8:44 PM
    #183
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Well I had to haul about five and a half tons of concrete to the dump a couple days ago. I hauled it in a double axle dump trailer with the bulk of the weight centered over the axles which really reduced the load on the hitch. It was well with in the rated tong weight for the truck but she squatted a bit but wasn't anything I felt I needed to be concerned about. I made two trips and kept the speeds down and there where no speed bumps or pot holes to hit but after everything was said and done and after taking the trailer off the truck the truck did not return to it's previous ride height. If I thought it was sagging before it is definitely sagging now. The leaf pack is resting on the overloads. So I guess I will definitely be replacing the leaf pack now. Apparently I have the heavy duty tow package leaf pack that has 4 leaf's and an over load as opposed to the 3 leaf no overload regular no tow package leaf pack. Toyota what are you thinking? If I can destroy the "heavy duty" leaf pack without even over loading the truck it ain't a heavy duty leaf pack. It's a crap pack and has no business being put in a pick up truck.
    Anyone have any recommendations for a replacement leaf pack? I won't be replacing them with OEM at this point plus I want to get rid of the lift block and use the leaf pack to get the needed lift. I am open to suggestions.
  4. Jul 15, 2023 at 10:13 PM
    #184
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    Were you getting shuddering at 1700-2000 rpm’s when towing? I’m getting that towing 4000lb trailer with about 400-500 lbs in the bed.
  5. Jul 17, 2023 at 2:49 PM
    #185
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You need to get sumo or timbren to help with those heavy load
  6. Jul 18, 2023 at 5:14 AM
    #186
    Jack_A_Lope
    Aaron
    I will check it out.
    Does anyone have any opinions on ICON leaf packs or Dobson?
  7. Jul 18, 2023 at 10:07 AM
    #187
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Having installed both I would put them in the same family of quality. They're based on similar designs. Icon has more leafs so they'll generally ride a little better. Dobinsons has thicker leafs so should stand the test of time slightly better, albeit at a cost to ride comfort. They also offer greasable bushings. Also, Dobinsons leafs are going to come in at more expensive to get to your door. It's a toss up, but aside from the noise that RXTs make after a little time (which we have a fix for) we sell them all of the time and people like them especially for the price point.
  8. Jul 18, 2023 at 2:05 PM
    #188
    Jack_A_Lope
    Aaron
    How about the Old Man Emu leaf packs? Are they any good? From what I've seen they will get me 2" of lift over stock. I think that's about where I want to be. If I need more a RAS should get me there. Right now I'm squatting about 3" from where I want to be. Will the Icons give me three inchs with the RAS?
  9. Sep 22, 2023 at 9:03 PM
    #189
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I installed the CB 0-2” carrier bearing drop kit and still have the same amount of driveline vibes at takeoff. Didn’t help at all.
    It’s annoying me even more now, anyone have any ideas?
  10. Oct 14, 2023 at 11:54 PM
    #190
    Yargerbomb
    Yargerbomb New Member
    Andy
    2019 White TRD Pro
    Been reading this post and a few of the airbag posts and at a crossroad. I have a stock 19 Pro. Just purchased a 7000lb travel trailer with 700lb tongue weight. I am expecting quite a bit of squat and trying to figure out the best option here. Anyone have a setup they really like that won’t completely damage my springs? RAS looks like a good option but just read about the factory spring issues. I don’t plan on a cross country trip but may go tow a couple longer trips each summer. Mostly around the state . Thanks in advance.
  11. Oct 15, 2023 at 12:43 AM
    #191
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd run the Roadmaster HDs, a decent weight distribution hitch (properly set up) and trailer anti-sway control bars (connected into the weight distribution hitch) :thumbsup:
    Also, I did not read through this thread completely, but if I recall, the folks having issues w/the Roadmaster setup causing spring problems also had additional lift set-ups in their rigs such as blocks, shackles, etc... and the combination of the 2 systems was causing the problem.
    If you are stock ride height, RAS should not cause a problem for your springs....
    bulldog93 and CoffeeAddict like this.
  12. Oct 15, 2023 at 5:56 AM
    #192
    Yargerbomb
    Andy
    2019 White TRD Pro
    Thanks, this what I was hoping for. I have a Blue Ox that came with the trailer so I should be in decent shape with the RAS HD. Think I will give them a try. Seems pretty straight forward of an install. May call around to check on pricing for both just to be on safe side. Thanks!
  13. Oct 16, 2023 at 8:06 AM
    #193
    Yargerbomb
    Andy
    2019 White TRD Pro
    The company that works on my truck stated that they use the Super Springs SSA27 over the RAS HD. Anyone have direct knowledge or run the Super Sring SSA27? Thanks!
  14. Oct 16, 2023 at 2:32 PM
    #194
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I ran super spring on my Tacoma, you need to cut the pump stops, and install their bump stops on top and need C clamp to adjust spring rate, so I left it in the top setting. It’s bumpy when empty bed, but I have tools in my bed most of the time so it’s not too bad. If you ride empty bed or need to adjust the spring rate all the time, I’ll get something else.
  15. Oct 16, 2023 at 3:04 PM
    #195
    Toytech6466
    Toytech6466 New Member
    Tracy
    Santa Cruz
    23 Tundra 1794
    I have installed about 200-250 RAS systems, 90% on Tacoma and Tundras. I have not any issues with them at all, but have not installed any on trucks with over a 2" lift blocks in the rear. I have been installing the RAS system for over 20 years. I think they are the best upgrade to a leak spring suspension system if you are going to be carrying any type of loads or towing.
    My only complaints have been that it does raise the rear end about .25 to 1". Those are from the customers that want a level truck! I have never had any of them come back failed.
    I have been running an independent Asian/Hybrid specialty shop for about 27 years
  16. Oct 16, 2023 at 5:08 PM
    #196
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I’m looking at installing one. With your experience, what is your take on the standard duty vs heavy duty version? Their web site suggests less than 2” of squat and/or 600lbs for standard, otherwise HD. That track with your experience? Is there a difference between the two in how much they raise the rear end?
  17. Oct 16, 2023 at 5:24 PM
    #197
    Toytech6466
    Tracy
    Santa Cruz
    23 Tundra 1794
    RAS assessment is pretty right on. If you are on the edge, you might go with the HD. You can always set the HD on the lighter side of the adjustments. The HD on the same setting will raise it just a bit more, not alot. These spring are progressive so that start working the more into their travel. When I bought them for my 1/2 tons they did not offer the HD.
    I have now a 2012 F-150 with the regular RAS, 5100s and tow a 30' travel trailer, and it rides great, tow great and takes the winds very well!!! The only wiggle I get from my truck is because of my tires, I switched from LT to P rates tires as I am selling and buying a 2024 Tundra(if I can ever find a 1794 with AVS)
    bulldog93 and Pmac like this.
  18. Oct 16, 2023 at 6:31 PM
    #198
    Pmac
    Pmac New Member
    Thank you.
  19. Apr 9, 2024 at 6:23 AM
    #199
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    RAS went on sale yesterday. $80 off, free shipping, no sales tax outside of NC. I placed and order for HD. Arriving today.:yay:
    Tundra Dude 45, Bergy24, DZ_ and 5 others like this.
  20. Apr 9, 2024 at 7:37 AM
    #200
    Tripleconpanna
    Thank you, sir!!! :fistbump:
    Order placed for the HDs as well!!!
  21. Apr 9, 2024 at 7:43 AM
    #201
    Retired Blue
    Steven
    Round Rock, TX
    :hattip:
  22. Apr 9, 2024 at 10:19 AM
    #202
    MGMTundra18
    MGMTundra18 New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    I added HD RAS and set it on the lowest setting. Perfect setup for me.
  23. Apr 10, 2024 at 4:45 AM
    #203
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    That sucks. I bought mine last week for $589.00. Par for the course for me. Oh well!!! I shouldn’t have clicked into this thread.
  24. Apr 12, 2024 at 1:01 PM
    #204
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I just got a set of these for free from a friend and he doesn't know if these are HD or standard. I recently got a lightweight truck camper installed it's around 350lbs plus camping gear I'm around 500lbs constant. My front was already lifted 1.5-2" and I'm just trying to get rear back up to at least level or slight rake. Hoping this gets me there! If not, new leaf springs are in order but I figured I'd try this first
  25. Apr 12, 2024 at 1:27 PM
    #205
    Retired Blue
    Steven
    Round Rock, TX
    According to the instructions that came with mine, HD: The head of the cap screw (the end of the threaded rod) is 12mm for standard duty, and 14mm for HD. The lock nuts closest to the cap screw are 22mm for standard duty, and 24mm for HD. I've not installed mine, yet, so I cannot confirm this.
  26. Apr 12, 2024 at 4:39 PM
    #206
    dirtnsmores
    Southern CA
    thanks for that. looks like it's the standard version unfortunately. wonder if i can still get 1-1.5" lift with this load with the setup
  27. Apr 12, 2024 at 7:47 PM
    #207
    dirtnsmores
    Southern CA
    I should've took a before picture, but I did take measurements. This standard pack at the nickel setting netting me nearly 2" on the stock leaf pack over the sag I had. I was at 21" hub to fender and now I'm at nearly 23". I'm running about 500-600lbs on the bed with the camper and gear. Just took it for a quick test drive and everything felt more planted instead of bouncy. I already have 1.5-2" Bilstein 6112 lift in the front.
    Any negatives to going with the nickel setting instead of dime or quarter? I off-road a decent amount and I'm hoping this won't affect articulation.
    Edit: found a similar before picture, with less weight in the bed.
    Before:
    After:
  28. Apr 12, 2024 at 8:49 PM
    #208
    Tripleconpanna
    Only 'negative' is that for some guys who are unloaded part of the time, the nickel setting provides a bit of 'rake or elevation' to the rear when comparing to an otherwise stock suspension... I'd imagine it may be a bit stiffer unloaded, but probably not enough to notice...
    Regarding articulation, maybe @RainMan_PNW can chime in here as I believe he had his on during his trip to Sedona last year and did a bit of 'crawling'.
  29. Apr 12, 2024 at 9:01 PM
    #209
    dirtnsmores
    Southern CA
    Good info thanks! The cool thing is right now I'm happy with the ride height and the bed is currently loaded for about 90% of my driving usage (fridge, some camping gear and recovery tools). The other 10% is a cooler of beer and the 80lb dog for road trips so I think this works out good. I technically will never be "unloaded"
  30. Apr 13, 2024 at 6:17 AM
    #210
    Retired Blue
    Steven
    Round Rock, TX
    You're welcome. Also, and from memory, I believe the instructions say that if you lose the white (1mm) and black (2mm) spacers, that using a dime and a nickel will work.
