General Supercharger Thread
  1. Apr 8, 2024 at 5:16 PM
    ARES35
    ARES35 New member for life
    Mile high
    @Saltyhero13 I'm assuming you were throwing P0101s and maybe 0102/0113 codes? I also had the P0420 for catalyst efficiency below threshold code...... Basically all codes you get when you pull the MAF.
  2. Apr 8, 2024 at 5:19 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If it persists you could try adding honeycomb air straightener screen before the MAF. I’ve never gotten a P0101 again after doing that with the SABM, AFE and magnuson airbox.
    Mdl, HulkSmurf14 and ARES35[QUOTED] like this.
  3. Apr 8, 2024 at 5:25 PM
    ARES35
    Mile high
    Honeycomb has crossed my mind for used to run one in my nitrous Se-r sentra way way back in the day lol. I may throw one in now that you suggested/mentioned it, thanks man!
    koditten and Silver17[QUOTED] like this.
  4. Apr 8, 2024 at 7:00 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I had a P0101 from an oiled filter I presume. Cleaned the MAF but only fixed the issue temporarily. When I replaced the MAF I was having surging idle so I did the throttle relearn. That fixed the issue.
    ARES35[QUOTED] likes this.
  5. Apr 8, 2024 at 9:32 PM
    ARES35
    Mile high
    Surging idle was the most annoying issue imo. Atm surge is completely gone thank God.
    Mdl and Saltyhero13[QUOTED] like this.
  6. Apr 9, 2024 at 7:01 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I am sporadically getting a P0101, I have the SABM, TRD Accelerator & AFE dry, what honeycomb should I get?
  7. Apr 9, 2024 at 7:35 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Or try the new maf from turbokits.com
    ARES35 and Silver17 like this.
  8. Apr 9, 2024 at 7:36 AM
    Silver17
    Eastern PA
    Mdl, ARES35 and PolishedTRD like this.
  9. Apr 9, 2024 at 7:43 AM
    e30cabrio
    I bought a new maf last year, is this still better?
  10. Apr 9, 2024 at 7:47 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    They have made one that adds I believe 30% more head room. @snivilous can explain it better
    ARES35, snivilous[OP] and Silver17 like this.
  11. Apr 9, 2024 at 7:55 AM
    Silver17
    Eastern PA
    I like the idea of it, sounds like a good solution. My biggest gripe is I would want to buy 2 and carry a spare since you can’t just throw in a random one from an auto parts store in a pinch and have it be compatible with the tune.
  12. Apr 9, 2024 at 7:57 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    same exact concern here
    ARES35 and Silver17[QUOTED] like this.
  13. Apr 9, 2024 at 7:58 AM
    e30cabrio
    ARES35 likes this.
  14. Apr 9, 2024 at 8:00 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
  15. Apr 9, 2024 at 8:39 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Questions, are we running these super rich to keep the pistons and tight ring gap from overheating and thus wreaking havoc? With proper pistons, ring gap, and big fat oil to air oil cooler to supply the piston cooling jets with cool oil, can we lean things out a smidge?
  16. Apr 9, 2024 at 8:45 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That's how it's explained to me. Weak-ish ring lands along with tight ring gaps are theorized to cause mechanical failure when hot. Richening past the normal 12:1 is strictly for cooling.
  17. Apr 9, 2024 at 9:14 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Back in 2008 Lextreme did a tear down of the 3ur exposing its shortcomings when supercharged. Then when were experiencing failures it was found the short piston skirt and tight ring lands had little room for expansion. Matt Smith came on scene talking about the cooling system. Thanks @Silver17 for info on Matt as I'm not on FB.
    If your going to tear down might as well go with a true forged built engine.
    @ViktorG and myself had catastrophic failures.
    https://www.lextreme.com/forums/threads/3urfe-engine-exposed.9701/
  18. Apr 9, 2024 at 9:18 AM
    snivilous
    SW UT
    @Fastlane47 new engine is built by XAT and has corrected pistons and ring gap, he's making 15+ psi and right now we're targeting in the ~12:1 range for most of the rpm band. None of that I would attempt on a stock setup based on what @Mdl said.
  19. Apr 9, 2024 at 9:38 AM
    ARES35
    Mile high
    Fastlane47, Silver17[QUOTED] and Mdl like this.
  20. Apr 9, 2024 at 9:39 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Jowett I forgot you were on the lextreme forum back then too providing great info, as many other forums. Man time flies...
    ARES35 and Saltyhero13 like this.
  21. Apr 9, 2024 at 10:08 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    So did I!
    Saltyhero13 likes this.
  22. Apr 9, 2024 at 11:15 AM
    e30cabrio
    Ordered!
    Thanks!
  23. Apr 9, 2024 at 2:03 PM
    TurboKits
    TurboKits New Member
    Thanks for the interest in the MAF sensor we developed for our Turbo Kit. Keep in mind, ours is scaled to read a higher flow for the same 0-5v range, it does require rescaling of your MAF table. Included is a MAF scale sheet, with voltages plotted along with the corresponding flow, with flowing done on a 3.5" ID sample size. You will have to adjust up or down (probably not down) from there based on your MAF tube size using simple math and then monitor fueling to dial it in 100%. Thanks again for the support! :thumbsup:
    Wynnded, reywcms, ARES35 and 3 others like this.
  24. Apr 9, 2024 at 2:16 PM
    e30cabrio
    Thanks! I ordered about 2 hours ago. I already have tracking!
  25. Apr 9, 2024 at 2:27 PM
    mralanle
    mralanle New Member
    reywcms and VWTim like this.
  26. Apr 9, 2024 at 2:54 PM
    ARES35
    Mile high
    I may go this route and keep this OEM I just installed as back up!
  27. Apr 9, 2024 at 3:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You'll have to let us know how it goes.
    I haven't had any MAF issues since going to the 95mm TB and 4.5 inch intake. @reywcms are you going 5 inch intake with the 103mm TB? Going to use the turbokits MAF? Will be standing by...
  28. Apr 9, 2024 at 3:06 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Current plan is the 5" tube and 103mm TB. If we feel we need more headroom I'll add the maf from turbokits.com
  29. Apr 9, 2024 at 3:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    e30cabrio, ARES35 and reywcms like this.
  30. Apr 9, 2024 at 3:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! I think I think I'm good with the tvs1900 and my setup for now.
    e30cabrio, HulkSmurf14 and ARES35 like this.
