  1. Apr 8, 2024 at 5:32 PM
    shifty` has rust. I repeat, rust is shifty`, and there is shifty` rust. The shifty` is rusty.
  2. Apr 8, 2024 at 6:24 PM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I agree, I want those. One day I'll pull the trigger on either the countersteer or the six-shooter. On another note, I stopped by Triple C the other day and got Chris to scan my ECU and send it off the VFTuner. Fingers crossed they'll unlock it.
  3. Apr 8, 2024 at 6:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I did as well, on Sunday. But unfortunately my ECM couldn't connect with tech stream. So at this time my options are to pull the ECM and send it to OV/VF Tune for them to try to tune or swap ECMs, or lastly just wait and hope my Cal ID becomes supported some day. I think I'll just wait for now.
  4. Apr 8, 2024 at 7:11 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    IIRC besides regular maintenance (including pads, rotors, and timing belts), 1st gen taco only needed radiator and now looks like valve cover gaskets in 173K, while 1st gen tundra needed recall LBJs of course, radiator, and now looks like valve cover gaskets and a rear wheel bearing after 248K miles, but luckily no transmission issues. The valve body swap looks very straight forward and guess a harbor freight press would be needed to keep up with bearings every 60K?! How long do the boxer motors last?
  5. Apr 8, 2024 at 7:12 PM
    ToyotaDude
    ToyotaDude Member
    Cam seal?
  6. Apr 8, 2024 at 7:25 PM
    I told you it's really not impressive unless you're in the path of totality. I would not have driven 6 hours to see a partial eclipse. Watching the sky go from sunny to dark in seconds is wild.
  7. Apr 8, 2024 at 7:33 PM
    Actually it wasn’t that bad on the news. At least you could see the moon covering the sun like they said (in Boston). I really have no explanation as to why the sun was still so bright where I was located. I’ll bet I could see it to some degree if I had the glasses.
  8. Apr 8, 2024 at 7:36 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    The evening news here was still teaching people how to make their own eclipse viewing devices, very helpful.
  9. Apr 8, 2024 at 7:43 PM
    Haha. I got an email at 2pm that glasses were available at a library 15 miles away. A little late.
    I guess I’ll catch the next one in my next life.
  10. Apr 8, 2024 at 7:43 PM
    Yes, if you had the glasses you could have at least seen that aspect of it which is neat. Without the glasses you can barely tell something is going on until it gets close to a total eclipse and starts to get a little darker. Again, the real magic starts when it totally blocks the sun. Hard to explain how neat it is.
  11. Apr 8, 2024 at 7:56 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    '27 gonna be one in giza.
    I think the next one over the lower '48 is gonna be in 2045.
    bmf4069 and 455h0le_dachshund like this.
  12. Apr 8, 2024 at 8:00 PM
    Oh, cool. I can hang out on the rock of Gibraltar to see it.
    bmf4069 and Mr.bee[QUOTED] like this.
  13. Apr 8, 2024 at 8:35 PM
    bmf4069 Captain wtf
    I don't understand how we get 2 within 6 months then nothing for 20 years.
  14. Apr 8, 2024 at 8:38 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  15. Apr 8, 2024 at 8:57 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Have another one near me in 2044 or 2045 I believe.
  16. Apr 9, 2024 at 3:20 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    it’s easier than that. They are sealed hub assemblies. It’s 4 bolts.
  17. Apr 9, 2024 at 3:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Cam gear seal behind the timing cover. It’s not common but not unheard of on the FB20D for them to develop a leak. Only bitch is, there’s no room to work on it so you have to pull the motor to reseal.
    The design of the exhaust manifold has the cat converter sitting directly below the front timing cover. Once the leak developed, it dropped directly on to the front O2 and fouled it out. I wasn’t in a position to repair it and it drove like ass because of it so I sold it to our used car dept.
  18. Apr 9, 2024 at 4:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    But does @shifty` have @RUSTYNUTS ?
  19. Apr 9, 2024 at 5:00 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What are annular and hybrid eclipses?
  20. Apr 9, 2024 at 5:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  21. Apr 9, 2024 at 8:36 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  22. Apr 9, 2024 at 9:10 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Its all about perspective
  23. Apr 9, 2024 at 9:12 AM
    VR6T
    It was over cast at my house, but this was peak totality yesterday. Pictures were taken 13 minutes apart
    BroHon likes this.
  24. Apr 9, 2024 at 9:12 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I wish they made the v8 with a stickshifty.
    Butthole weinerdog is talking borderline blasphemy here. Best watch yo step boi.
  25. Apr 9, 2024 at 9:18 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    My auto-darkening welding hood wasn't working for me. Apparently the sun isn't bright enough to switch it on. However, 8 layers of 15% window tint was perfect. It's pretty amusing how much of a big deal people made about that. Unless it was a total eclipse, not that exciting to me.
    NUDRAT[OP] likes this.
  26. Apr 9, 2024 at 9:46 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    annular is a total eclipse, but the moon isnt close enough to cover the sun, and a hybrid is where it might start as an annular & becomes a total eclipse or vice versa.
  27. Apr 9, 2024 at 9:48 AM
    The total eclipse was truly breathtaking. A super normal moment that everyone with us was genuinely blown away by. It’s totality, or nothing.
  28. Apr 9, 2024 at 9:51 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    my old school non-auto welding helmet worked fine, but my brother showed up with some fancy glasses that were way better than the cardboard ones i ordered. In 80 years, that was grandma's first time in the darkness of totality.
  29. Apr 9, 2024 at 10:22 AM
    It's one of those things you can't understand until you experience it. We got lucky in 2017 that it came right over Knoxville. After seeing that one I said I was going to drive to see this one. This one was 4x as long(totality). If I'm still alive I may drive to Montana in 20 years for the next one.
  30. Apr 9, 2024 at 10:26 AM
    I would’ve only had to drive for 2 hours to northern NH to be in the path of totality. I’m surprised nobody around here made a big deal of it until the day before.
