General Supercharger Thread
  1. Apr 8, 2024 at 8:07 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Thought I’d share this post I saw on FB. Good numbers here I thought given a roller dyno, especially given the stock intake box. Maybe I should put it in the dyno thread. Hell even the base stage 1 is putting down some good numbers for just 6-7psi.
    Edit: look at that torque curve too. That is amazing. It’s like there is no peak to it, just straight gobs of torque all the way across the range.
    ZPhilip, ARES35, reywcms and 4 others like this.
  2. Apr 8, 2024 at 8:44 AM
    BlackSunshineYYC
    BlackSunshineYYC New Member
    Black TRD Pro
    I was wondering - and again, some ignorance here, but the 2019 + tundra's had the cooler removed and the engine temps started running way higher than the previous 2019 trucks. So setrab's were an option to get the cooler running temps again. I am wondering if the setrab helps negate some of that heat sink thereby eliminating (in your case) the heat sink that causes the extended crank. A theory...and another hail mary. I have no idea how the setrab affects ambient temps AFTER the engine is off, but another rabbit to the mix.
  3. Apr 8, 2024 at 8:47 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i don't think so....my water temp is generally ~194 degrees.
    which is probably what everyone's is.
    Mdl and Saltyhero13 like this.
  4. Apr 8, 2024 at 8:54 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    They said "you can ground the channel ground to the ground of the gauge that will work"
    ARES35, Mdl and armyoffoo[QUOTED] like this.
  5. Apr 8, 2024 at 9:02 AM
    BlackSunshineYYC
    Black TRD Pro
    Thanks VWTim - on my to do list.
  6. Apr 8, 2024 at 9:14 AM
    BlackSunshineYYC
    Black TRD Pro
    Thanks Sniv. I had the injectors tested prior to install - so didn't feel there were the problem...but maybe they are.
  7. Apr 8, 2024 at 9:19 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    @Wynnded went through the same thing. Injectors were tested, I think Five-O may have even sent him brand new injectors, same issue even though the manufacturer said they were flawless. But his TRD Green and Prospeed injectors didn't have any issues. It's almost like some trucks just don't play nice with a specific brand for whatever reason. Would be interesting to buy new DW650s and see if they changed anything, though that seems kind of insane to try the exact same brand.
    ARES35, Wynnded and Mdl like this.
  8. Apr 8, 2024 at 9:49 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have 5-0 650 injectors and no crank issue anymore, they are running higher at 50lbs though (after all that fuel pump fiddling last year)
    ARES35 and Mdl like this.
  9. Apr 8, 2024 at 10:03 AM
    BlackSunshineYYC
    Black TRD Pro
    Curious to know more about the fuel pump 'fiddling'...more pressure worked? Or more volume?...or both...
  10. Apr 8, 2024 at 10:10 AM
    BlackSunshineYYC
    Black TRD Pro
    Do you still have those TRD greens looking for a home?
  11. Apr 8, 2024 at 10:12 AM
    snivilous
    SW UT
    I think so, I'd have to look in the shop to find them but if I do you're welcome to have them for free. I know there's a handful of other people on here with the greens laying around too.
    Fastzdriver, ARES35, bflooks and 3 others like this.
  12. Apr 8, 2024 at 10:46 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Some of us have the fuel pump hot wired so it gets a full 14+vdc and bypasses the fuel pump controller. It primes at key on and not at start. Some are running an adjustable fuel pump regulator instead of factory, either standard 43psi(or more) or boost referenced to 50-60psi.
    ARES35 and snivilous[OP] like this.
  13. Apr 8, 2024 at 11:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm running a tvs1900, walbro450 hot wired, 6an supply return fuel lines, DW AFPR set at 43psi and boost reference to about 58psi, with fiveO Denso 750 injectors. I'll get an occasional extended start after it's warmed up. Although my fuel pump comes on in Acc posn I find a quick straight to on it starts right up. If I let it prime or wait a sec before starting I'll get an extended start.
    Five-O says tune but @snivilous tune is golden. I live with it...
    Fastlane47 and ARES35 like this.
  14. Apr 8, 2024 at 12:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have a set of 5-O 750s that I'd send out to anyone who's a big enough glutton for punishment to change out to see if they work in their truck. These being the second set that were sent to me. Technically I don't even think I put miles on them, I merely ran the vehicle while in the shop. As soon as the engine was up to temp and I got the long cranks, I said fuck it and immediately changed back to the Prospeeds that were working fine.
  15. Apr 8, 2024 at 12:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hmm. Maybe to just test to see if it happens on my engine. So I can get back in contact with Five-O. Would send them back after testing. It's good to have spare parts...
  16. Apr 8, 2024 at 12:47 PM
    Silver17
    Eastern PA
    I always felt my extended crank (which has been greatly remedied with tune adjustments) was due to too much fuel at start, not too little. I thought I could smell gas when experiencing the extended crank. I think opening the throttle helps the situation as it helps dry out the cylinders and provide more air for starting, not more fuel. I could be wrong though!
  17. Apr 8, 2024 at 12:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Makes sense to me and correlates to what I randomly experience.
    Silver17[QUOTED] likes this.
  18. Apr 8, 2024 at 12:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Think he was referring to supercharger pulley.
    Geez to think back then when we got the TB's bored from 76mm to 80mm it was the coolest...haha
  19. Apr 8, 2024 at 2:06 PM
    bflooks
    bflooks New Member
    Metrowest MA
    If there are a set of greens laying around, message me. I don't need them at the moment, but if the price is right, I'm not opposed to having them on hand while I'm working through the turbo adoption.
  20. Apr 8, 2024 at 2:09 PM
    e30cabrio
    I had a new bought from Walbro bad 450, then I kept having the hose between the pump & basket come off, and I had FPR issues. Can't say which resolved the weird start but all that together did.
    Mdl and reywcms like this.
  21. Apr 8, 2024 at 2:13 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Pulley not TB :rofl::facepalm:
  22. Apr 8, 2024 at 2:36 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Lol! I should have known that.
    There’s still an 80mm sitting on my shelf from 15 years ago.
  23. Apr 8, 2024 at 3:08 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    You certainly got hosed on that cycle...
    reywcms and Mdl like this.
  24. Apr 8, 2024 at 3:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks for the reminder of how we're aging...
    Jowett[QUOTED] likes this.
  25. Apr 8, 2024 at 4:21 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I have some trd greens looking for a home. 3k miles on them. looking brand new. pm if interested.
  26. Apr 8, 2024 at 4:46 PM
    ARES35
    ARES35 New member for life
    Mile high
    Dreaded P0101 has came back, and now more consistently. Changed to the AFE and cleaned the sensor a few weeks back but no cigar. Have had bouncing idle, odd changing fuel trims and power enrichment A/F's. Threw in a new OEM MAF sensor hoping the old one was on its way out with the old oiled filter. A few of the elements look bent compared to new also, have 75k on it.:fingerscrossed:
    Mdl likes this.
  27. Apr 8, 2024 at 4:52 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I had to do the throttle relearn procedure after I swapped my MAF out.
    Mdl and ARES35[QUOTED] like this.
  28. Apr 8, 2024 at 5:10 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What’s the relearn process?
  29. Apr 8, 2024 at 5:11 PM
    ARES35
    Mile high
    Swapped them and let it idle. Idle bounce was gone and trims shifted -6 at most in low airflow volts, it was a mix of neg/pos trims. Also truck rpms would jump good 2/300 rpm when activating A/C. That's also stopped. I'll see how it reacts to some pulls, if wonky throttle relearn will be my next step.
    HulkSmurf14 likes this.
  30. Apr 8, 2024 at 5:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Here is what I have.
    Saltyhero13, reywcms and ARES35 like this.
