  1. Apr 5, 2024 at 11:50 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Come on guys. A $20 stud finder would be a good thing to have in your toolbox anyways. Right tools for the job make life easy.
    also, I vote 2nd wall since it appears to be the front of the garage and would be easily seen when wrenching on any side of a vehicle but the back.
    bmf4069, jerryallday, txagg and 3 others like this.
  2. Apr 5, 2024 at 11:54 AM
    It's funny to me that your mind went there. That was not even a consideration for me. Are home burglaries common there? Pretty low risk here.
    des2mtn likes this.
  3. Apr 5, 2024 at 11:55 AM
    I have a stud finder. That was not my concern. What about the electrical on that stud. Low risk of hitting it with a screw?
  4. Apr 5, 2024 at 1:13 PM
    Don’t stand in a puddle or touch anything conductive while driving screws.
    bmf4069, CodyP and Festerw like this.
  5. Apr 5, 2024 at 1:13 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I have trust issues with my stud finder. It's a notorious liar so sometimes I verify.
    CodyP[QUOTED] and whodatschrome like this.
  6. Apr 5, 2024 at 1:46 PM
    daveeasa
    I like option 2 next to the door (to the house I presume?). That’s where I’d put it.
    CodyP and txagg like this.
  7. Apr 5, 2024 at 1:48 PM
    daveeasa
    For mounting a TV in a garage I’d find the optimum location height and width. Mark the outside of the mounting bracket with pencil. Cut along pencil line with multi tool or drywall knife or box cutter. Remove drywall. Take photo. Add extra blocks as needed or just replace with 5/8 plywood. Yes it’s more combustible but f it. Peace of mind and no risk.
    BroHon and FirstGenVol like this.
  8. Apr 5, 2024 at 1:52 PM
    Who breaks into a garage and the goal is to take the most common, least valuable item that’s bolted down. Probably no one.
  9. Apr 5, 2024 at 2:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    right? You just take the remote or the power cable.
  10. Apr 5, 2024 at 2:01 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'd cut a small hole that's big enough to fit your arm behind where you want to mount the TV, and just locate any hazards, then patch the hole.
    FirstGenVol likes this.
  11. Apr 5, 2024 at 2:08 PM
    daveeasa
    I understood the “thief” as “poaching free content” rather than actually stealing the TV…
  12. Apr 5, 2024 at 2:12 PM
    That’s evil. haha
  13. Apr 5, 2024 at 2:13 PM
    des2mtn
    SW
    Tonto cover
    General idea, not sure how your specific TV mount would work. The wiring for that outlet probably runs along the side of that stud to the ceiling.
    daveeasa, FirstGenVol and Mr.bee like this.
  14. Apr 5, 2024 at 2:17 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I used to have a tv remote control app on my phone that let you program and save to several tv's, and i'd saved maybe a dozen different tv's to it & could mute em secretly. Worked like a champ.
  15. Apr 5, 2024 at 5:25 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Not really where I'm at, but I don't trust people.
    NUDRAT[OP] likes this.
  16. Apr 5, 2024 at 5:29 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Meth heads.
    Pretty easy to just pop a RV off the wall mount. They usually have quick releases. Only the mount is actually bolted on to the wall
  17. Apr 5, 2024 at 5:30 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Easily replaceable
  18. Apr 5, 2024 at 8:34 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    KNABORES and artsr2002 like this.
  19. Apr 5, 2024 at 8:49 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Is that wrap on the roof I peek?
  20. Apr 5, 2024 at 9:28 PM
    daveeasa
    Wait, is that black platform a tank for the toilet? Is the idea to have a toilet facing the TV? Killer plan!
  21. Apr 5, 2024 at 10:50 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    BroHon likes this.
  22. Apr 6, 2024 at 5:53 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I just had my annual. Gained about 20# in last 2 years, lost 3" in height. Guess I need to get some exercise. Main difference in my life is sitting at a desk last 2 years whereas I'd been working 3 jobs until then, the other two being purely physical labor. I'm'a gonn'a need'a find a better balance.
    Okay, starting to play catch up since... 30March. This is gonna take a minute.
  23. Apr 6, 2024 at 6:19 AM
    The comments on this are good. Poor Tundra looks like a stretch limo.
  24. Apr 6, 2024 at 6:37 AM
    NUDRAT
    SW CT
    I'd say on the block wall. I think you'll get less sun glare than you might on the drywall wall.
  25. Apr 6, 2024 at 6:38 AM
    Also, easy bulletproof install. Masonry bit, couple holes, and tapcons ... that shit is going NOWHERE.
    bmf4069 and FirstGenVol like this.
  26. Apr 6, 2024 at 6:42 AM
    I was thinking the same thing. I like both locations but the tv would blend into the dark walls better when not in use.
  27. Apr 6, 2024 at 6:48 AM
    Paint is cheap. But I'd go there, exterior wall.
    If there's any power feeding a light in the ceiling, you may be able to easily drop a conduit from the ceiling (or flex/bx) down the wall, you'll only need to drill for a conduit hanger/standoff every 36", which means maybe two for stability? Drop a quad-box on the wall for good measure, behind where the TV will mount.
    bmf4069 likes this.
  28. Apr 6, 2024 at 6:49 AM
    NUDRAT
    SW CT
    Did a thing this morning. Now to get it dirty.
  29. Apr 6, 2024 at 7:23 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    bmf4069 and Jack McCarthy like this.
  30. Apr 6, 2024 at 7:43 AM
    Well, didn’t get my eclipse glasses for Monday. Both two different Walmarts cancelled my order. The 2nd one just posted some online and within two minutes, I ordered it. Shows how lazy those mofos are in filling an order. Plan to hit up two Warby Parkers tomorrow when they open and then a Sonic Drive-In to see if any are still stocking free ones.
    Probably just as well on the Walmart Vision Scientific glasses. They have a fake website with a phone and email that are both disconnected and don’t exist. Huh. Must really be a non-certified made in China no name brand.
