Door lock actuator assembly
Discussion in '1st Gen Tundras (2000-2006)' started by Jose1800az, Apr 4, 2024.
  1. Apr 4, 2024 at 2:34 PM
    Jose1800az
    Jose1800az [OP] New Member
    Rob
    2005 1st Gen Tundra
    I've got a 2005 Tundra access cab where the driver door doesn't open. It won't open using the inside or outside door handles. Key fob locks and unlocks but nothing! Am I needing to replace the whole mechanism w/actuator or one or the other?
  2. Apr 4, 2024 at 5:28 PM
    shifty` Ten EV 12's so you know I raise hell
    Is this truck new to you?
    Is there any way to open the door at all?
    Do you know if anyone has replaced the latch assembly or door lock?
  3. Apr 5, 2024 at 10:44 AM
    Jose1800az
    Rob
    2005 1st Gen Tundra
    Truck was handed down to me, latches have never been touched. There is no way to open driver side door. I’ve seen videos on taking rear door panel off and cutting striker plate. I just need confirmation what parts to buy exactly.
  4. Apr 5, 2024 at 5:14 PM
  5. Apr 5, 2024 at 5:22 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My drivers door latch started to get funky at about 100k miles and 21 years old, I started having to pull it (outside) or push (inside) hard to open the door. I replaced the latch before it gave up the ghost entirely. I don't think the door panel will come off with the door in the closed position. I think you will need to first get the door open.
