General Supercharger Thread
  1. Apr 4, 2024 at 7:18 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Back somewhere in the thread I posted the FFV & Walbro 450 side by side and they look identical.
    kbahus[QUOTED], Mdl and ARES35 like this.
  2. Apr 4, 2024 at 7:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes. The walbro 450 #267 fits nicely in the FFV canister with no mods. How I wound up with a spare pump. If anyone is in need. Let me know.
    reywcms, kbahus, ARES35 and 1 other person like this.
  3. Apr 4, 2024 at 7:43 PM
    ARES35
    ARES35 New member for life
    Mile high
    My kit was a non FFV. Called Magnuson and they confirmed kit was fine, id just get the extra FP. Then confirmed once my ECU# was pulled the tune they sent for the RTD was a FFV tune. Truck ran good on their tune but liked being in the mid 11's WOT, confirmed via the PSB1. So dumped that tune and went MPVI -3, 750s and 76mm pulley lol. Maybe they sent me a regular Non FFV tune unbeknownst to me. Not sure though because the tune are on lock down never was able to check the tables :notsure:
  4. Apr 5, 2024 at 3:43 AM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Thanks guys! @Mdl pm sent on that fuel pump.
    Mdl likes this.
  5. Apr 6, 2024 at 7:44 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    You guys with the HP Prolink+, what did you attached the ground wire to? Same ground as the gauge? Want to hook up to log AFR off a PSB-1
    ARES35 and Mdl like this.
  6. Apr 6, 2024 at 8:02 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I leveraged the ground bolt behind the drivers kick panel. Gauge is home run to the battery.
  7. Apr 6, 2024 at 10:26 PM
    blenton
    blenton New Member
    I ran an oversized ground out the firewall and tied it to the battery ground on the fender. It's not 1000 watt amplifier over-sized, but maybe 10 or 12 gauge for the small accessories up front to ground to - not including the head unit or any stereo stuff. Innovate specifically asks you NOT to tie in to the radio ground. I considered @bflooks solution but didn't chase it to see that it home runs tot he battery. Good to know.
  8. Apr 7, 2024 at 12:14 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just ran prolink to AEM ground which goes to battery.
    helidave[QUOTED] and bflooks like this.
  9. Apr 7, 2024 at 7:59 AM
    ARES35
    Mile high
    I put mine where the kick panel trim is located. Pull it and you'll see a existing ground point.
    HulkSmurf14 and bflooks like this.
  10. Apr 7, 2024 at 8:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Oh, no no, I didn't chase that ground bolt to confirm it goes to the battery. It is a factory ground location, so I used it, but only for the prolink since it is a more simple, lower voltage, passive device. The gauge itself I ran straight to the battery with a dedicated wire through the firewall because I don't want to worry about potential electrical issues/anomalies in my controller.
    Apologies if I was misleading
    blenton[QUOTED] likes this.
  11. Apr 7, 2024 at 9:42 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    The way I understood the ProLink documentation is that the ground isn't for the ProLink, it's to provide a sensor ground for the 5v input you are connecting to the red and blue wires. I have 2 AEM wideband gauges. With AEM, you get a white wire for the 5v sensor input, a brown wire for sensor ground, and red/black for power/ground for the gauge...I connected the red and blue wires to each input and split the ground wire to both sensor grounds.
    The MPIV is already grounded through the OBD2 port, you don't need to ground the ProLink harness to the chassis, it's to be used to ground the signal. Grounding to the chassis can introduce noise and inconsistent values.
    helidave, reywcms, Wynnded and 3 others like this.
  12. Apr 7, 2024 at 12:58 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Jowett, e30cabrio, ARES35 and 6 others like this.
  13. Apr 7, 2024 at 1:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    e30cabrio, VWTim[QUOTED] and Silver17 like this.
  14. Apr 7, 2024 at 1:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ARES35, VWTim[QUOTED] and Mdl like this.
  15. Apr 7, 2024 at 1:27 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
  16. Apr 7, 2024 at 1:36 PM
    VWTim
    Corvallis, OR
    Harrop, but won't matter what's downstream. Airflow is airflow.
    ARES35, reywcms and Mdl like this.
  17. Apr 7, 2024 at 2:48 PM
    helidave
    flagstaff
    2015 DC 4x4
    Yeah that's what I was curious about. The PSB 1 doesn't have a sensor ground, just has a ground. So do you ground the prolink to that or something else or nothing at all? The pro-link instructions aren't very helpful
    ARES35 and HulkSmurf14 like this.
  18. Apr 7, 2024 at 3:02 PM
    NatesNightMare
    Pinetop Az
    I was just wondering because id like to have the 80mm over the 76 im running but ive got the 2650 maggy
  19. Apr 7, 2024 at 3:11 PM
    VWTim
    Corvallis, OR
    2650 shares the same or similar rotor pack to the Harrop, only small changes with intercoolers. They appear to respond very similarly to mods.
    Mdl likes this.
  20. Apr 7, 2024 at 4:02 PM
    NatesNightMare
    Pinetop Az
    No one makes an 80mm for the maggy yet though. Sniv would have had some made but no interest from anyone but me. More to order gets the cost down
  21. Apr 7, 2024 at 5:02 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I would check with Innovate support on what they recommend, they might suggest to ground to the same spot as the gauge, or might specify it has to be separate from the gauge's ground point. The sensor ground might be internally grounded to the gauge ground...something support could confirm. The ProLink itself doesn't need to be grounded, it just provides a sensor ground for the 5v sensor input to complete the circuit.
  22. Apr 8, 2024 at 7:01 AM
    e30cabrio
    Looks like I blundered into the "right" combo too! yEa ME! LOL
    Wynnded[QUOTED] and VWTim like this.
  23. Apr 8, 2024 at 7:17 AM
    BlackSunshineYYC
    BlackSunshineYYC New Member
    Black TRD Pro
    FPR question for this thread. It's known that the Harrop supplied FPR is just an OEM FPR that is 'pinched' to increase pressure to the rail / injectors. IIRC, Harrop in their first go round of SC kits had the installer actually pinch the OEM FPR using supplied tools to do so. However, they instructed installers to NOT pinch the FPR if they were going to install stage 2 injectors (dw650's). I have recently gone from Stage 1 to Stage 2 with DW650's, Magnuson Air box and a 77.5 pulley (boost referenced). I am now experiencing the dreaded extended crank with a heat sunk engine. Here is the quesion - I am wondering if the Harrop supplied FPR is the issue. Increased pressure decreases the volume entering the system post FPR. We know that a stock FPR regulates at 43psi. I am wondering if the decrease in volume during a heat sunk engine somehow creates a situation that causes a lack of fuel for the BIGGER injectors to push the appropriate volume for a strong start. We do know that pumping the gas pedal can at times mitigate the extended crank. This is a pressure vs. volume question in a boost referenced SC where I have NO idea how a tune / ECU manages heat sink ignition in this situation. Any thoughts greatly appreciated.
    Land Bruiser and Saltyhero13 like this.
  24. Apr 8, 2024 at 7:23 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    pondering...
    I am Harrop/650's/77.5mm
    I am using the Harrop fuel pump.
    and I do not have any extended crank issues.
    or any issues for that matter.
    which leads me to believe it's tune related. (I am not actually qualified to make that stmnt, but, whatever)
    I was initially tuned by D3 Performance in League City TX - no issues.
    now tuned by Peitz Performance (HPT) in Katy Tx.
    Saltyhero13 likes this.
  25. Apr 8, 2024 at 7:23 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The stock throttle body can easily be over bored to 80mm.
  26. Apr 8, 2024 at 7:34 AM
    BlackSunshineYYC
    Black TRD Pro
    yeah, I know that there are some out there who have no issues with the same set up - likley equal to those who DO experience this issue. Many have spent many hours with tuners to find a solution and others have spent none (lucky you!) - I am hoping that his could be a possible contributor given the mind numbing small differences in all of our trucks which make them 'unique'. I cannot afford to chase ALL of the rabbits. Going back to Stage 1 will likley be my next move if this hail mary is moot.
    nobodyintexas[QUOTED] likes this.
  27. Apr 8, 2024 at 7:39 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I see you filled in the spreadsheet. If that spreadsheet proves anything it seems to be that there is no common pattern. @Wynnded did extensive tune testing and could never get his setup to start consistently, then swapped injectors and it was fine.
    I think your best bet is to change injectors (which is the same thing as going to the stage 1 essentially). I think if you got different 650s you could directly swap them in without changing the tune probably too.
    ARES35, Wynnded, Mdl and 3 others like this.
  28. Apr 8, 2024 at 7:40 AM
    BlackSunshineYYC
    Black TRD Pro
    By any chance - do you have Setrab cooler installed?
  29. Apr 8, 2024 at 7:53 AM
    VWTim
    Corvallis, OR
    Very frustrating indeed. I'm Harrop SC, Harrop FPR, Harrop supplied Fuel pump, DW650's, 80mm pulley (but shouldn't affect cranking), but self tuned in HPT. No cranking issues so far... Maybe throw an inline fuel gauge to see what's happening? https://www.racetronix.biz/p/adapter-qdf-5-16qdm-5-16-1-8-port/qda-56f56mp works great with the optional gauge.
    Antidote time, I had extended warm cranking in my old VW racecar running SDS EFI. Finally tracked it down to an incorrect fuel cell at warm temps, I don't recall exactly, but should have been 0, and accidently got toggled to -99 or something like that. While running the EFI would interpolate right thru it without issue but at warm crank, it would crank forever.
    ARES35 likes this.
  30. Apr 8, 2024 at 8:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes I do.
