Check engine light permanently off??
Discussion in '1st Gen Tundras (2000-2006)' started by Bryanhernandez00, Mar 27, 2024.
  1. Mar 27, 2024 at 10:53 PM
    Bryanhernandez00
    Bryanhernandez00 [OP] New Member
    2006 tundra sr5
    Total chaos upper forms 2.5 coil over shocks in the front no lift in the back kmc wheels 315/70/17s
    My 2006 tundra has some cut wires under the dash and my machine said that when he scanned the truck with the obd2 scanner a lot of codes poped out. I think the previous owner did something to not make the check engine light come on does anyone have a clue what it could be??
  2. Mar 27, 2024 at 11:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Probably took the bulb out. Does the symbol illuminate when you start the car?
    ZappBrannigan likes this.
  3. Mar 27, 2024 at 11:46 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    They should all come on when the key is in accessory mode.
  4. Mar 27, 2024 at 11:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    2006 is LED instrument cluster. No way to pull the bulb out
    That shit sucks.
    shifty` likes this.
  5. Mar 28, 2024 at 3:44 AM
    DesertCreature
    DesertCreature New Member
    2012 Tundra Rock Warrior
    If there’s evidence of cut wires, then either splicing them back together (cheap option), or a new harness (expensive option) seem to be the only two solutions. Or keep a cheap OBD2 scanner in the door and scan once a week or so. I had the same issue (no CEL), on my pathfinder and kept a scanner in the door.
  6. Mar 28, 2024 at 5:01 AM
    shifty` Ten EV 12's so you know I raise hell
    @Tundra2 is right. This is why it's important to look at people's truck info carefully before listening to what they're saying :rofl:
    Pics of cut wires would probably be really helpful - it's possible they simply removed an alarm, or you still have the guts of an aftermarket alarm in there. Over here, around the 4th or 5th paragraph, you'll find a series of links in one sentence. One of those links points to wiring diagrams. In there, you can backtrace wiring: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It's 100% possible a previous owner went into the cluster and physically replaced the surface-mount LED, or they may've taken a black Testor's marker and put a few blobs over the LED. I'm not sure how they would've cut a single wire to kill the light though.
    Tundra2 likes this.
  7. Mar 31, 2024 at 6:24 PM
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    This would be my guess as well.
  8. Mar 31, 2024 at 6:44 PM
    2005-2006 has on-board LED for the cluster.
    Tundra2 and meeseeks55[QUOTED] like this.
