Where's the horn for the door locks?
Discussion in '3rd Gen Tundras (2022+)' started by Bourbonator, Feb 24, 2024.
  1. Feb 24, 2024 at 10:29 AM
    Bourbonator
    Bourbonator [OP] New Member
    North ID
    '23 LE CM 6.5
    It was easy to find on my old tundra and 4Runner. I wrapped them in high temp tape to muffle the noise. It sounds like the beep is coming from the driver's side headlight..
  2. Feb 24, 2024 at 10:37 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Horn?
    Mine only beeps once when I lock, twice when I unlock.
    Edit: Sorry, I didn't read your post carefully. I see you are talking whatever makes the beeping noise, correct?
    Out of curiosity, why do you want to muffle the beep?
  3. Feb 24, 2024 at 10:41 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    You're arguing semantics.
    Whatever you want to call the device that produces noise when locking and unlocking the doors. I want to muffle it.
  4. Feb 24, 2024 at 10:42 AM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    There was a thread just last week.
    Look at this post 16 if that's what you're looking for.
  5. Feb 24, 2024 at 10:46 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Yeah, I realized that after I posted. Sorry.
  6. Feb 24, 2024 at 10:48 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    That's probably what I'm looking for. Thanks for the link.
    No need to apologize.
  7. Mar 28, 2024 at 4:37 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I am not getting the 1 beep chirp when hitting the lock button using the smart key fob. I have turned it off somewhere, somehow and now cannot find where to turn this on. I would like to have the audible notification as confirmation the truck is locked when I press the fob with my back turned. I have read the manual completely, studied both the multimedia and the multi-info displays settings, looked at the customization features.... but cannot find where to set this. Thanks in advance for any tips.
  8. Mar 28, 2024 at 7:38 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    It's in the head unit settings somewhere.
    DRP likes this.
  9. Mar 28, 2024 at 7:41 AM
    DRP
    DRP Old Member
    Dave
    Get to the Toyota screen on the big display then:
    Settings (Little gear icon)
    Vehicle Customization
    Door Control
    Scroll down on the right side of the door control section and you'll see a slider for Feedback Tone.
    I initially turned mine off as well because I thought it would get rid of the engine running walk away beeps but it didn't. It's nice to hear the lock beep when using the FOB while walking away from the truck just to confirm it's locked... Hope this helps.
  10. Mar 28, 2024 at 9:39 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    That is exactly where I thought the adjustment resided and I have been adjusting the Feedback Tone numerous tries and at different levels, but when locking with the fob, no tone is played. The lights blink once as part of the locking (and twice when unlocking) but there is no tone. I need to try something else. I have the new v2170 and your mail sorta confirms the upgrade did not affect this feature.
  11. Mar 28, 2024 at 9:57 AM
    DRP
    DRP Old Member
    Dave
    I just went to the truck and confirmed that's the right setting at least for my truck. Turned it all the way down and no beeps, turned it back up, got beeps. I did go back to settings each time I made a change. Is it possible you have to do that to "save" the new setting? I suppose there could be a bug in 2070? I'm on 2050.
  12. Mar 28, 2024 at 10:12 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Thanks for your assistance. I did exactly as you described a half dozen times and no beeps. The DRLs flash properly but no chirps. I need to look somewhere else.
  13. Mar 28, 2024 at 10:51 AM
    DRP
    DRP Old Member
    Dave
    All I have left to suggest is check out the s/w update thread. There are a few that also have 2170. Maybe one of them could help determine if it's a problem with that version or not.
    https://www.tundras.com/threads/off...d-unit-update-details-updated-3-13-24.139030/
