New to me Tundra servicing!
Discussion in '1st Gen Tundras (2000-2006)' started by KSteng, Mar 28, 2024.
  1. Mar 28, 2024 at 10:36 AM
    KSteng
    KSteng [OP] New Member
    Kyle
    2006 Tundra SR5 DC V8 4x4
    Bilstein 5100s
    Two question post:
    1. Just got an 05 Tundra v8 with 95k miles on it and I’m assuming it’s got original trans fluid in it still. I wanted to get some opinions on whether I should flush the trans or just drain and refill? I’ve heard good arguments on both sides but let me know what you think!
    2. I'll also be replacing the radiator, water pump, and timing belt. I’ll probably just take it to the dealer for all this since I don’t have the time or even a garage to do it in. They quoted me a total of about $2590 for parts and labor for all these including the trans flush.
    WP: $764 labor, $231 parts
    Timing Belt: Labor included, $108 parts
    Radiator: $630 parts, $160 labor
    Trans flush: $425
    I know TB and WP is a tedious job but holy smokes.. anyway I can make this cheaper??
    Also planning on doing ball joints but I’ll do that on my own with oem parts.
    Oh and here’s the new rig:
    Leo's first likes this.
  2. Mar 28, 2024 at 10:52 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    1st thing I'd do to make it cheaper would be to replace the radiator yourself. The Denso (factory) radiator is about $140 from Rock Auto, and easy to install (drain, disconnect your trans cooler lines, upper and lower radiator hoses, overflow tank line, take the bottom of the fan shroud off, 4 bolts holding it in, and then lift it straight up out of the truck). if you can do your ball joints, you can swap your radiator.
    I would drain and refill your transmission, might need to do a few times though as you won't drain everything by doing it once. I don't think your truck as a transmission dipstick so my suggestion would be to use a fluid transfer pump to pump the fluid into the fill hole. My truck is a 2006, no dipstick, assuming the 2005 is the same.
    Nice looking truck BTW.
  3. Mar 28, 2024 at 11:00 AM
    shifty` Ten EV 12's so you know I raise hell
    They're gouging you on the radiator. If they're doing a complete flush and not just a drain/fill on the trans, that price is about right. The rest is reasonable.
    But before you invest any money, I see snow in your picture, you need to go over that frame with a fine tooth comb to make sure you're not dumping money into a truck with a rotten frame. The thread I linked in your other post about coolant should help identify the areas to really carefully check. Be sure to treat the frame at least annually with woolwax or similar if it'll be used on salty roads.
  4. Mar 28, 2024 at 11:38 AM
    KSteng
    Kyle
    Bilstein 5100s
    This is exactly what I was thinking about doing to make it a little cheaper. Thanks!
  5. Mar 28, 2024 at 11:41 AM
    kentuckyMarksman
    No problem!
    If you do end up having the dealership swap the transmission fluid for you, then swap your radiator first. You'll lose a little transmission fluid doing the radiator, but it's better to lose old fluid than new fluid.
    KSteng[QUOTED][OP] likes this.
  6. Mar 28, 2024 at 11:41 AM
    KSteng
    Kyle
    Bilstein 5100s
    I checked the frame out before buying it and it looked to be in good shape. Barely any surface rust as the guy before took very good care of it. But I’ll take your advice and look it over inch by inch just to be sure. Thank you!
    shifty`[QUOTED] likes this.
  7. Mar 28, 2024 at 12:18 PM
    Definitely do the radiator yourself. It is extremely easy. 4 bolts, disconnect the hoses, pull back the fan shroud, voila.
    des2mtn and KSteng[OP] like this.
  8. Mar 29, 2024 at 5:56 AM
    bfunke
    bfunke Tundra Curmudgeon
    If you’re reasonably handy and have a basic set of metric tools you can do all this yourself. There are some good videos on YouTube. Watch a couple showing TB replacement and decide if you can do it. Post pics here and we can help advise.
  9. Mar 29, 2024 at 6:37 AM
    I'll be the contrarian that says, "If you don't have a ton of tools, let the stealership do that, the water pump, tensioner, pulleys".
    Then you do the radiator.
    Then seek out a BG licensed dealer and have them do the BG Transmission Service. BG backs it with their Lifetime Protection plan, and it exceeds Toyota's OEM specs for service/fluids.
  10. Mar 29, 2024 at 9:50 AM
    KSteng
    Kyle
    Bilstein 5100s
    I definitely would buuuut A. I’m a baby and don’t have a garage up here in freezing South Dakota and B. Literately no time. Full time student, working, and we just had our second kid! Haha. I think I’ll just bite the bullet and have the stealership do the timing belt and WP then do the rest myself when I find time.
  11. Apr 2, 2024 at 9:06 AM
    KSteng
    Kyle
    Bilstein 5100s
    I am getting my truck scheduled for the timing belt, tensioner, pulleys, and water pump and they're suggesting I have a coolant flush done as well which adds another $250 or so. Would you say I should do that even though I'm going to be replacing the radiator myself? What would you suggest?
  12. Apr 2, 2024 at 9:55 AM
    Does it currently have the correct color fluid in it? (pink or red)
    $250 is a lot of money for flushing coolant.
  13. Apr 2, 2024 at 10:00 AM
    KSteng
    Kyle
    Bilstein 5100s
    Yes it’s got the pink coolant
  14. Apr 2, 2024 at 10:16 AM
    Pink is super-long-life and good for 10yrs/100k miles like timing belt. I think it's up to you. If that were my truck, I'd feel better about it if it were $150, I'd potentially do it knowing how much pre-mixed coolant is (cue criticism from people who buy concentrate...) and not having to deal with disposal, but given flushing is something I can do myself, and disposal isn't totally out of reach ... I'd be hard pressed. You do you.
  15. Apr 3, 2024 at 6:07 PM
    2003DC
    2003DC New Member
    They have to drain a lot of fluid to do a waterpump/timing belt job, and presumably replace that with new fluid when the job is done. So I'd question what benefit you get by a "flush", and I'd want to know exactly what they mean by "flush" for $250 (sounds dubious to me). I'd be satisfied with the replacement coolant they have to put in with the timing belt job.
    shifty` likes this.
