Initial Development And Prototyping Of A 102 mm GM LS Throttle Body On A Supercharged Tundra
Discussion in 'Performance and Tuning' started by ViktorG, Oct 3, 2020.
  1. Mar 11, 2024 at 12:21 AM
    #331
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm not sure how it would work on mine. I have the valve body accumulators (C2, B3, C3) locked up where they only move about 1/4 to 1/2 inch. It creates a direct shift with no clutch overlap for 2-3-4 (poor mans shift kit or 1970's muscle car shift kit:D). So it is a harsh shift in its self for those gears. :burnrubber:
  2. Mar 11, 2024 at 8:06 AM
    #332
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    That's a good question
  3. Mar 12, 2024 at 4:10 PM
    #333
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ViktorG or anyone in the know. Im testing different throttle position angles and shift rpms.
    If I have tow/haul setup for one throttle position and lower rpm than my main tune will that be an issue. Just trying to make it easy to be able to test different parameters. But don't want to brick anything. Thoughts?
  4. Mar 12, 2024 at 5:23 PM
    #334
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I can't see any way for that to be an issue.
    Mdl[QUOTED] likes this.
  5. Mar 13, 2024 at 5:06 PM
    #335
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I adjust the throttle position angle to a reduction by 40% and shifting rpm's by 200 for shift speed. Reduced tcc setting a little too much as it shifts from 3-4 pretty quickly and will lock in 4th gear. I believe the cold settings are ok but once at 185-195 deg the hot settings need to be increased from where i reduced them. Shifting to 6th needs a bit of adjustment still. A work in progress for sure. Submitted a ticket to hptuners to be able to do inverse tables for torque load and desired air load as hpt for GM has that function.
  6. Mar 14, 2024 at 5:01 PM
    #336
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @armyoffoo anyway to let hpt know that the adaptive reset is not coming up on the beta version?
  7. Mar 14, 2024 at 5:14 PM
    #337
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I emailed them back, waiting on a reply.
  8. Mar 14, 2024 at 5:32 PM
    #338
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    armyoffoo likes this.
  9. Mar 15, 2024 at 6:38 PM
    #339
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Getting closer to decent shifting. Got 6th gear back where it won't down shift at the slightest grade. Still haven't gone WOT! I'm inching closer got to 78% in 4th gear.
    Wynnded, snivilous and reywcms like this.
  10. Mar 15, 2024 at 8:28 PM
    #340
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Hopefully have the new intake setup soon with the 5” and 103. See how it all works out
    ViktorG[OP] and Mdl[QUOTED] like this.
  11. Mar 15, 2024 at 9:14 PM
    #341
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    This was interesting. Today I received a response from hpt stating that doing an inverse table is not applicable to Toyota. They were going to close my request when I replied with a picture that they offer it for Ford and GM plus that I was following slownstock's advice to have the desired air-load be an inverse of optimum torque load, they escalated it to their engineers.
    Not sure if it can be done for Toyota though...
    It is shifting better without the airload adjusted but it could be better.
  12. Mar 16, 2024 at 7:46 AM
    #342
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    And that's not the only inverse table. Transmission optimum and inverse are explicitly called that.
    Mdl[QUOTED] and reywcms like this.
  13. Mar 16, 2024 at 10:37 AM
    #343
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It'll be a start if they can bring this to Toyota's editor as it seems like we are the bastard that is forgotten. They to respond with Toyota is archaic in their programming of ecu's.
    When I read the Ford hpt forum they asked for an inverse function in 2018 and they got it on Dec 2023 but I believe only for 4th gen on up.
    Then after they do all the math/conversions/table adjustments....the final dialing in is based on how it feels/responds to adjustments that deviate from the tables.
    And here I am trying this out when I could hardly understand adjusting my ltft's.
    But a hearty thanks for your guidance!
  14. Mar 16, 2024 at 10:49 AM
    #344
    snivilous
    SW UT
    Can you download one of the files for a vehicle that has the inverse converter working and use that?
    Considering it's just interpolating and flipping data I would think it'd be a generic tool
  15. Mar 16, 2024 at 11:07 AM
    #345
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I tried a few from the GM but were older files and not available and hpt kept redirecting my sign in so I gave up. I saved a few posts that have the info. Will try and see. Plus I always seem to mess up excel files.
    snivilous[QUOTED] likes this.
  16. Mar 17, 2024 at 12:22 PM
    #346
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  17. Mar 27, 2024 at 8:55 AM
    #347
    snivilous
    SW UT
    I just got @reywcms new TB from @ViktorG and it's gorgeous!
    But this got me thinking (and coincidentally I had read about someone making their own TBs the other day but didn't put 2 and 2 together), why don't I just design us a TB that uses the Tundra electronics? Sell it as a kit where you get the billet TB and plate and shaft, and then take your stock TB and swap the electrics over and voila. Bolt up to the Tundra bolt pattern, no need for the signal converter, would effectively be a stock unit.
    Did we already talk about this and I forgot and that's why no one has looked into it? I would probably need to machine it overseas to keep the price in reason (like sub-$300?). Would anyone be interested in that?
  18. Mar 27, 2024 at 8:56 AM
    #348
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Hell yes! Put me down for one.
  19. Mar 27, 2024 at 9:06 AM
    #349
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes lol
    ViktorG[OP] likes this.
  20. Mar 27, 2024 at 9:07 AM
    #350
    snivilous
    SW UT
    I just looked at my stock TB, the electronics hold down plate is riveted, so I'm definitely not taking my apart that I need :D Rey is trying to get his hands on a stock one to send me.
    ViktorG[OP] and Mdl like this.
  21. Mar 27, 2024 at 9:08 AM
    #351
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Do you want a stock one, or a RCF? I have both that I can send.
    ViktorG[OP] and reywcms like this.
  22. Mar 27, 2024 at 9:15 AM
    #352
    snivilous
    SW UT
    I'd rather a stock one, in the event the RCF internals are different. I want to be able to use as much stock hardware as possible.
    If you have it on hand and can send it that'd be awesome! I'll pay for it and shipping too.
  23. Mar 27, 2024 at 9:17 AM
    #353
    armyoffoo
    armyoffoo Member
    Cypress, TX
    PM me your address and I'll drop it off at UPS today. Consider it credit towards whatever you come up with.
  24. Mar 27, 2024 at 9:20 AM
    #354
    snivilous
    SW UT
    That works out! And what I'll do actually is build one here with the parts from yours, and then I'll just send you the whole thing already assembled plus the remains of the stock throttle body. So you'll just end up paying for material cost (assuming it all works out and is an acceptable price) and you'll end up with an already assembled billet throttle body.
    ViktorG[OP], Wynnded, Mdl and 2 others like this.
  25. Mar 27, 2024 at 9:23 AM
    #355
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Shit yes
    ViktorG[OP], Mdl and snivilous like this.
  26. Mar 27, 2024 at 9:25 AM
    #356
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Perfeck!
  27. Mar 27, 2024 at 10:39 AM
    #357
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The tuning will still be the final hurdle but can be done. When I ran the GM 103mm (a crappy friends one) it acted like a on/off switch. But when it was in the range it was gobbling the air and scooted big time! Using the GM 95mm, its not perfectly tuned on the shifts and is 90% better than before. After I changed my shift rpms, throttle position angle (reduced by 45%) torque and air loads I was hitting my Rev limiter. Hopefully after @snivilous suggestion to change it up it should be sweet!!
    **I did encounter a hard start situation when I reduced the throttle angle by 50% but it did start after a cool down. I believe it was truck related as I tried 40% then 45% and 50% again and it ran and started fine. I just settled on 45% for now as is close to the stock increase TB from 76mm to gm 95mm TB.
    Good times!
  28. Mar 27, 2024 at 10:44 AM
    #358
    snivilous
    SW UT
    My hope is going with the Tundra body will remove the variable of "throttle body quality" as well as the multiple adapters and configuring needed to make the GM one respond correctly. Maybe even make tuning easier since the TB control isn't running through the wiring adapter.
    If I get it to work I'll install one on my own truck so I can help you guys figure it out too.
  29. Mar 27, 2024 at 12:24 PM
    #359
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    YES! A project I too have wondered about. One hurdle will be the motor, as it is directly in the way of expanding the throttle plate diameter too much, less so on the RC-F. If you find a work around, do post about it! Flopping the motor over 180 is a possible solution, but one of the sensors is in the plastic cover. The other 1/2 of the sensor is built into the end of the throttle shaft with a gear on it.
    They open up easily…
    Wynnded, ViktorG[OP], Mdl and 3 others like this.
  30. Mar 27, 2024 at 12:29 PM
    #360
    snivilous
    SW UT
    Looks like an additional idler gear could be added to offset the motor more?
    EDIT: Or just upsize the idler gear in there actually
    Wynnded, ViktorG[OP], Mdl and 2 others like this.
