Which bulb for fog lights?
Discussion in 'Lighting' started by RasTafari48, Sep 12, 2017.
  1. Sep 12, 2017 at 8:27 PM
    RasTafari48
    RasTafari48 [OP] New Member
    I'm sure this has been answered before but I need quick answer.
    I want to install HIDs in my fog lights (2017). Stocks say H16 but I know that other companies list H16s with 5202 which is NOT gonna work. Anyway, what bulb do I need? I'm guessing H11? Thanks!
  2. Sep 13, 2017 at 6:01 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    There are 2 different types of H16 bulbs, make sure you choose the right style. The H11 can be modded to fit but are much higher wattage, running a risk to the OEM wiring harness.
  3. Sep 13, 2017 at 6:13 AM
    I'm running Sylvania Ultra Star H11 I used a dremel to grind down the metal slots on the bulb that fit i to fog light housing
  4. Sep 13, 2017 at 7:11 AM
    Pudge
    CT
    No issues with higher wattage or heat in the lamp? Stock fogs are terrible.
  5. Sep 13, 2017 at 7:15 AM
    No issues...i run em dawn dusk night rain... I just didn't like the "yellow" look no issues with heat from them housing is fine I wanted bright white so i went with Sylvania Ultra Star
    Pudge[QUOTED] likes this.
  6. Oct 8, 2017 at 9:52 AM
    RasTafari48
    so....I installed HID 35w H11's in my Fogs. bulbs fit great. light output is fantastic. however, the fog light housing gets HOTTT. after about 10 minutes of driving with the lights on, I parked my car and felt the housing lens and I couldn't touch it for more than a second because it was so hot. anyone else have this issue? is H11 too much for the fogs? am I risking damaging my housing? thanks.
  7. Oct 8, 2017 at 10:29 AM
    Pudge
    CT
    H11 bulbs seem to be too high of wattage. The stock H16 are 19w and H11 are usually 55w. There are some guys who say they have run H11 with no issues but many have said they melted lense, wiring, or housing.
    NewImprovedRon likes this.
  8. Oct 8, 2017 at 1:14 PM
    RasTafari48
    should I maybe go with H11 LEds then?
  9. Oct 8, 2017 at 3:55 PM
    Pudge
    CT
    I believe the LED are lower wattage. Issue is the lights scatter and blinding oncoming drivers
  10. Oct 8, 2017 at 5:19 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    RasTafari48,
    Go with Morimoto LED H11. Gives 55w output but with no heat.
    Check it out at TheRetrofitSource.com
