Restoring Rock Warrior/Tomahawk Shift knob leather
Discussion in '2nd Gen Tundras (2007-2013)' started by peteullo, Aug 24, 2020.
  1. Jul 31, 2023 at 6:27 PM
    #61
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Here’s what I came up with:
    Black Cerakote
    SS black hardware
    Perforated black leather
  2. Jul 31, 2023 at 6:31 PM
    #62
    RobertD
    Robert
    DFW, Texas
    Looks very clean!
    Shanet421[QUOTED] likes this.
  3. Jan 10, 2024 at 9:56 PM
    #63
    crbr
    crbr New Member
    Do you have a link to the fasteners you used?
  4. Jan 11, 2024 at 3:55 AM
    #64
    Shanet421
    San Diego,CA
    bulldog93 likes this.
  5. Jan 27, 2024 at 7:01 PM
    #65
    crbr
    crbr New Member
    Is the Tomahawk shifter made out of steel or aluminum? Also wondering if it's possible to replace the two plastic parts or if you are hosed when those break?
  6. Jan 27, 2024 at 8:12 PM
    #66
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    the body is aluminum, as far as the plastic parts, there is only one, is it the semi-circle that holds the leather on but it is also what threads on to the shaft of the shifter. So I have been toying with a spare shift knob and I could come up with one possible way of fixing it. I would JB weld a nut into the handle where the plastic part enters, just make sure it is the correct thread pitch M8x1.25. then I would find a solid round of aluminum the same diameter as the plastic, then easy enough to drill and tap the threads for the hardware. Might also look cool un wrapped and finished a contrasting color to the handle.
    I post some pics if i am not clear
    crbr[QUOTED] likes this.
  7. Jan 28, 2024 at 8:48 AM
    #67
    crbr
    crbr New Member
    I discovered the two plastic pieces and thought of harvesting the connection point from a normal shifter knob if it breaks. Would love to see where you got with it.
    Any tips for removing the existing paint before I get it cerakoted? I've got some rust and oxidization around the screw holes
  8. Jan 28, 2024 at 11:27 AM
    #68
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    bulldog93 and crbr like this.
  9. Jan 28, 2024 at 11:29 AM
    #69
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    So this is my spare that I am experimenting with as far trying to replace the plastic with solid metal stock.
    @crbr what two pieces of plastic are you referring to? Mine is one solid piece of plastic. Also as far as removing paint I would suggest sand blasting, or a chemical spray and some light sanding
    this was also the first tomahawk I came across that didn’t have leather on it and it came with a polished black insert
  10. Jan 28, 2024 at 12:26 PM
    #70
    crbr
    crbr New Member
    The plastic part that it screws into on mine is an insert into the half cylinder.
    Shanet421 and bulldog93 like this.
  11. Jan 28, 2024 at 12:30 PM
    #71
    Whitey55
    Whitey55 New Member
    Glenn McGee
    2021 Platinum tundra
    Just finished installing the leather today. Powder coated and need new screws and done ..
    Shanet421, bulldog93 and crbr like this.
  12. Jan 28, 2024 at 12:38 PM
    #72
    crbr
    crbr New Member
    I got replacement screws from pro-bolt. They have a few color options.
    PB308
    Aluminium Allen Bolt M3x(0.50mm)x8mm
    bflooks, bulldog93 and Whitey55 like this.
  13. Jan 28, 2024 at 5:19 PM
    #73
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Did you powder coat yourself or have a shop do it? If a shop did it how much did they charge you?
  14. Jan 28, 2024 at 5:23 PM
    #74
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    oh wow, i feel foolish, I have taken apart a dozen or so of these doing restorations since doing mine and have never known that!
    bulldog93, Shanet421 and crbr[QUOTED] like this.
  15. Jan 28, 2024 at 5:55 PM
    #75
    crbr
    crbr New Member
    I'm assuming because they know it's going to break is why they kept it separate. If I could just find that piece (hoping it's some universal part), then we are in good shape. I know I'm going to over-torque it one day and have to replace. Trying to get ahead of that. Plastic bits seems like a weird choice here...wish it was 3d printable. Probably going to have to fabricate something at my buddies shop and use aluminum. Just not sure how to do the threading and all that, so will need his help. Going to take a while but not in a rush while my plastic is still good (knock on wood).
  16. Jan 28, 2024 at 6:25 PM
    #76
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    a quick search I found these
    nuts | McMaster-Carr
    the M8 have all the same specs as the original nylon toyota part, the only thing is that the one I linked is opened ended so you would be torquing the handle until the shifter bottoms out against the plastic leather part of the shifter.
    bulldog93 and crbr[QUOTED] like this.
  17. Jan 28, 2024 at 6:43 PM
    #77
    crbr
    crbr New Member
    Ty for linking that. You could plug the end with something or weld an end on and it would be fine if doing a full rebuild.
  18. Feb 3, 2024 at 6:05 PM
    #78
    Whitey55
    Whitey55 New Member
    Glenn McGee
    I had some one do it. I’ve use him regularly he did it when he was doing other stuff for another customer charged me $20
    bulldog93 and Shanet421 like this.
  19. Feb 7, 2024 at 3:35 PM
    #79
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    Just got this tomahawk shifter back from powder coating. Unsure what color leather I want to go with. Black or Red is where my head is at.
    Going to post it for sale soon.
  20. Feb 7, 2024 at 3:42 PM
    #80
    RobertD
    Robert
    DFW, Texas
    If selling, go with black. More universal.
    AZEric[QUOTED] and bulldog93 like this.
  21. Feb 8, 2024 at 2:44 PM
    #81
    RobertD
    Robert
    DFW, Texas
    @brando.graves is looking for this shifter. Maybe you guys can talk before you pick a leather color and you can work out the details of sale.
    bulldog93 and brando.graves like this.
  22. Mar 4, 2024 at 5:58 PM
    #82
    bflooks
    bflooks New Member
    Metrowest MA
    Is everyone installing back to stock height or counting turns? I found the instructions (for an FJ, but the same shifter) and it said to install to 1/2" height above the shifter gate. It's seems to be how both of the ones I got were installed, and they were both 15-17 full turns to remove.
    Dropping them both off for "brushed aluminum" Cerakote tomorrow. Have an upholsterer friend helping with the replacement leather. Fun little project. One of them was nearly perfect, the other has some putting and needs blasting.
    Thanks to all for blazing the trail.
    Edit: place called it brushed aluminum but maybe they meant satin aluminum (Cerakote name). I now need to look at it vs battleship grey (Cerakote name). Regardless, keeping it classic.
    bulldog93 and WFD473 like this.
  23. Mar 10, 2024 at 12:07 PM
    #83
    bflooks
    bflooks New Member
    Metrowest MA
    Progress. Went with one of each color, and while this photo washes the tungsten out a bit, they both came out great. New polished aluminum heads for the silver (factory look), I got black bolt heads for the tungsten. Both will be getting new leather, which I'm hoping to get done this week.
    Thanks to @RainMan_PNW for his build thread. Following his lead, my local firearms shop turned them around in just a couple of days.
    Mater, RainMan_PNW, RobertD and 2 others like this.
  24. Mar 10, 2024 at 2:19 PM
    #84
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you run them down too far they will hit the shift gate trim in park and mark it up. I’ve had it happen in the 08 and the 21 - both times when a service tech twisted them down to a full bottom out. :mad:
    bulldog93 and bflooks[QUOTED] like this.
  25. Mar 22, 2024 at 7:10 PM
    #85
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Finished the shifter restoration.
  26. Mar 23, 2024 at 4:44 AM
    #86
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Looks great!! That would go nicely with a blacked out interior.
    AZEric[QUOTED] likes this.
  27. Mar 23, 2024 at 5:49 AM
    #87
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Interested in purchasing...
  28. Mar 23, 2024 at 6:44 AM
    #88
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    message me an offer
  29. Apr 8, 2024 at 10:34 AM
    #89
    bflooks
    bflooks New Member
    Metrowest MA
    Just finally got around to doing my first leather replacement. Went surprisingly well once the adhesive cured enough for install. Zip PXL_20240408_153111735.jpg tie marks have all relaxed with time and after being used.
    The silver one I'm debating doing the smooth leather on since I'm selling it, but curious as to everyone's thoughts on the "diamond" I put on the titanium.
    PXL_20240408_142316611.jpg PXL_20240408_142305318.jpg PXL_20240408_151846583.jpg PXL_20240408_151848619.jpg PXL_20240408_151855177.jpg PXL_20240408_151859772.jpg PXL_20240408_151913782.jpg
    WFD473, bulldog93, RobertD and 2 others like this.
