1st Gen Tundra Jtekt Steering Rack
Discussion in '1st Gen Tundras (2000-2006)' started by Tarsis, Mar 20, 2024.
  1. Mar 22, 2024 at 6:48 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I did the flush with valvoline high mile atf. It appeared to help with the lack of assist, but I think it was just because it had warmed up outside. Couple cooler mornings here and it basically the same. Not sure if the rack is original. No major leaks, though I did see wetness on the boot when I installed the new OEM lower ballz.
    Tarsis[OP] likes this.
  2. Mar 22, 2024 at 8:27 AM
    Tarsis
    Tarsis [OP] God, Family & Country
    Gioni
    Tennessee
    01 AC Tundra Limited 4x4 v8
    New chasis
    Makes sense, I’m sure your approach correlates with your end goal.
    The rack I purchased is new from Toyota, I’m a little disappointed with some of what I’ve found out about them. Hoping mines doesn’t leak, since it seems like they are hit and miss, some leak, some don’t. After doing a little research, I’m keeping my fingers crossed in hopes the one in my truck is the original, seems like they are better build. I want a spare as part of my build, either way it’ll all work out at the end.
    des2mtn likes this.
  3. Mar 22, 2024 at 8:33 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    It's worth noting Toyota's 12-month warranty also applies to remanufactured parts. If you get a dud somehow, it shouldn't be too big of an issue to replace it, especially if you bought it in person.
    BroHon, FirstGenVol and Tarsis[OP] like this.
