Tailgate latch issue
Discussion in '1st Gen Tundras (2000-2006)' started by vercetti, Mar 13, 2024.
  1. Mar 13, 2024 at 9:47 PM
    vercetti
    vercetti [OP] New Member
    2001 Tundra 4.7
    i bought this truck without a uninstalled tailgate…strikers/hooks that bolt on the bed that hold the gate were broken. replaced and also a new handle…didnt go oem.
    when i try to push into the bed in the hooks wont latch. i messed with the latches and sprayed them down with wd40 and no avail. i also noticed pulling the handle wont pull the latche mechanism on either side. like the new handle mechanism doesnt have enough force even tho theyre on there. the only way i can make the latches move is by manually pulling the rods. i also have to say one side of the latches has a broken rod holder and keeps popping out. need some guidance. even with both rods connected properly the handle mechanism is like not strong enough to move the rods, tho pulling the rods does move the latch arms but doesnt move the actual latches that click into the hooks.
  2. Mar 13, 2024 at 9:59 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Can you add a photo to the back of the latch
  3. Mar 13, 2024 at 11:01 PM
    vercetti
    2001 Tundra 4.7
    will fine a way to link the videos
  4. Mar 13, 2024 at 11:46 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Is it possible the latch is in the lock position ?
  5. Mar 13, 2024 at 11:52 PM
    vercetti
    2001 Tundra 4.7
    how so if lock isnt installed?
  6. Mar 13, 2024 at 11:58 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Flip the lever/ nipple in the opposite direction
  7. Mar 14, 2024 at 4:12 AM
    The rods going into the ends of the tailgate don't look like they're in the right spot. Did you replace the latch parts in the tailgate? Maybe they're on the wrong sides?
    MEWaters likes this.
  8. Mar 14, 2024 at 4:32 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Almost looks upside down from when I replaced mine 1 week ago. But I know you wouldn’t have been able to put it in if it was. It definitely looks off
  9. Mar 14, 2024 at 5:08 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This has been an issue in the past for another member or two. Ended up just being locked.
    vercetti[OP] likes this.
  10. Mar 14, 2024 at 6:55 AM
    vercetti
    2001 Tundra 4.7
    i didnt. only replaced the handle
  11. Mar 14, 2024 at 6:56 AM
    vercetti
    2001 Tundra 4.7
    will def look into this thanks!!!
  12. Mar 14, 2024 at 8:10 AM
    I replaced mine with one off rockauto. I have to pull the handle all the way up, then jerk it up a tad to get it to open. Could be the same with yours if the lock thing doesn't work.
    vercetti[QUOTED][OP] likes this.
  13. Mar 14, 2024 at 8:33 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Yeah, those grooves about 2" away from the rods are where they're supposed to ride. Maybe they're installed upside down/backwards/switched (i.e., driver side needs to go to passenger, etc.)?
  14. Mar 14, 2024 at 3:09 PM
    shifty` Ten EV 12's so you know I raise hell
  15. Mar 14, 2024 at 3:36 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    bmf4069 and shifty`[QUOTED] like this.
  16. Mar 16, 2024 at 3:18 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fix any rod holder that's broken and if the cover panel is dented in, smash it flat with a mallet. It sounds crazy, but it worked for me. Also, adjust your strikers all the way back (away from the cab).
  17. Mar 16, 2024 at 5:47 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    shifty` likes this.
  18. Mar 16, 2024 at 6:22 AM
    @vercetti you gotta update us on this, did you shift the lock lever into the unlocked position so it'd latch properly?
  19. Mar 16, 2024 at 7:39 AM
    vercetti
    2001 Tundra 4.7
    will be updating soon.
  20. Mar 18, 2024 at 12:31 PM
    vercetti
    2001 Tundra 4.7
    so yeah that did work, but my main issue still persists and i probably made it worse. i put the tailgate back on and it still would not latch on. now the issue is that i used force to push it in and one side somehow went in and the other halfway but no fully. but now my tailgate wont open at all. not even in full force. didnt even get to strap on the wire handle things because i wasn’t expecting for it to get stuck.
    https://streamable.com/i25cs2
    https://streamable.com/idcsuc
    https://streamable.com/feyqbk
    https://streamable.com/xrxtrt
    https://streamable.com/ph0pn3
    https://streamable.com/e016vj
    sorry about the format guys. this is the best way i found to post videos.
  21. Mar 18, 2024 at 12:45 PM
    First off, on the latch. Did you go with OEM or the cheapest shit you could find on scAmazon? It makes a difference. Cheap shit is cheap for a reason. Many of the guys on here who bought cheap latches on scAmazon had them fail within a few months or year or two, only to buy another latch, and repeat 3-4 times until they've spent more than they would buying OEM.
    Second, it looks like the latches are frozen and could probably use some PB blaster, repeated soaks, just to free them up. On the latch that won't catch (passenger side?) what happens if you unhook the rod at the handle (purple clip), and manually pull the rod towards the driver side tail light? Does it unlatch? If so, the new tailgate handle is your problem. If should be doing a "twist" sort of movement where it pulls the driver side latch's bar toward passenger side, and the passenger side latch's bar toward the driver's side, which is what lets the latch loose.
  22. Mar 18, 2024 at 12:59 PM
    vercetti
    2001 Tundra 4.7
    so all i bought was the handle new from ebay, cheap one. the little lock thing you mentioned worked perfectly for it. i never bought new latches. the tailgate has the original latches and yeah they looked like they had better days. i also bought the hooks that go on the bed where the latches go. i could tell from the old ones that they had rusted off broken because all i found was 2 spikes on each side where there was supposed to be hooks.
    i sprayed pb blaster but no joy. now im hoping it doesnt open while im driving as i couldnt even connect the retention wires. im guessing im gonna have to get on it and kick off the latches off the hooks?
  23. Mar 18, 2024 at 1:13 PM
    vercetti
    2001 Tundra 4.7
    forgot to mention that the latches (the hooks on both far ends of the bedrhat attach to the bed hooks) did not move when pulling the new handle locked or unlocked. only the rods and the inside latch mechanism where the rods latch on would move, the latches that lock in to the hooks would not move.
  24. Mar 18, 2024 at 1:35 PM
    I'd remove the tailgate if you're worried about it flying off. You may just want to get some cheapo latches off fleabay, and rehab the whole thing with aftermarket parts at this point. Any idea what the cost is on aftermarket latches?
  25. Mar 18, 2024 at 1:36 PM
    Yeah, saw that in the video, and it's why I said it appears the tailgate latches are frozen solid. Not the catch inside the latch, that does move as it should it seems, but the mechanism of the latch itself that's supposed to trigger the catch, it doesn't appear to be moving. Frozen tight.
  26. Mar 18, 2024 at 1:57 PM
    vercetti
    2001 Tundra 4.7
    thats my conclusion at this point. tho pushing it in did make the latches move to the point where one locked and the other didnt. now the mission is how to open the latch.
    oem latches are like 100+…but what isnt these days right?
  27. Mar 18, 2024 at 2:10 PM
    If you've gone non-OEM on the tailgate handle, might as well pair it up with non-OEM latches too :D
    Seriously, the tailgate is pretty worn anyway at this point based on the videos. It'd be pretty silly to throw brand new OEM. If I were staring down the barrel of having to buy two new OEM latches, I'd seriously just hit www.car-part.com and find a matching tailgate. But given you've already got money invested in nearly every other part, I'd stay that course.
  28. Mar 19, 2024 at 7:21 AM
    NickB_01TRD
    KY
    I will argue on this point that my Amazon handle has been on mine for 3 years so far and still feels great. When I got my truck the handle was already broken and the seller included an Amazon handle. Of course after installing new it became pretty apparent that there was a reason the old was broken and that was because it hadn't been lubricated any time recently.
    Probably wouldn't hurt to put your clip and guide upgrade on my list of things to do though.
    shifty`[QUOTED] likes this.
  29. Mar 19, 2024 at 8:29 AM
    My words come from a place of scAmazon handles often being plastic in places where the OEM is plastic. Like you observed, having a properly lubed and maintained tailgate is crucial to having the aftermarket cheapie hold up. I'd feel confident buying anything Dorman puts out - at least with their stuff, there's a legitimate, reputable company behind the part to manage the warranty, which is better than the RANDOM WORD ALL CAPS NAMED COMPANY flooding scAmazon, which will stay alive just long enough to sell for 6-18 months, then fold, by the time your part dies.
    We've seen too many people on here get their driver/passenger doors stuck closed with aftermarket latches. It's not as crucial for the tailgate, so I'd probably install aftermarket there. I would absolute NOT use aftermarket latches in the cab doors.
    bmf4069 likes this.
  30. Mar 19, 2024 at 8:56 AM
    NickB_01TRD
    KY
    I agree on that last one. I would never cheap out on a door handle. My Amazon handle was free so I'll reassess if the time comes.
    bmf4069 likes this.
