Disable TPMS - I am fed up with the dashlight
Discussion in 'Wheels & Tires' started by TRXTER, Mar 23, 2022.
  1. Mar 16, 2024 at 6:19 PM
    #61
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    So thanks to you all for the pics and descriptions. My truck is 2007 SR5 RCLB 4.7 with tow package. My sensors were corroded garbage when I bought the truck. I removed them all when I put on new Coopers AT3’s. My wiring is identical to the one posted above. I cut the light lime green and yellow. Jumpered the green into the yellow from the truck side. Leaving the green cut off going into the plug. Lights gone. Took the Autel meter and cleared the TPMS code. All good. No flat tire light. IMG_0845.jpg IMG_0850.jpg
    BlueRibbon4x4 likes this.
  2. Mar 17, 2024 at 5:09 AM
    #62
    TRXTER
    TRXTER [OP] New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    Awesome !!! Glad it worked out for you.
    Cruiserpilot[QUOTED] likes this.
  3. Mar 17, 2024 at 6:40 AM
    #63
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    How many Tundra owners does it take to unscrew a lightbulb?
    Cruiserpilot likes this.
  4. Mar 17, 2024 at 8:02 AM
    #64
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    Try taking a flat blade screw drive, position it over the light, pound it into the gauge cluster with a 20oz framing hammer, several whacks will destroy that pesky light. No more obnoxious warning light distracting you. Very simple and effective.
