No more volume on OEM radio?
Discussion in 'Audio & Video' started by DarknessReigns, Apr 29, 2020.
  1. Apr 30, 2020 at 6:20 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Did you remove the factory amp too?
  2. Apr 30, 2020 at 7:40 AM
    DarknessReigns
    DarknessReigns [OP] New Member
    This is exactly what I am experiencing.
    Thanks for chiming in and letting me know this!
  3. May 9, 2022 at 1:51 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Sorry for bringing up an old thread. I have this exact issue, upgraded the speakers and amp in my 2020 TRD PRO and started to have this problem few months ago. Is there a fix to this, is the HU going bad, aftermarket amp causing the issue or did you all just live with it?
    KB_2021TrdPro likes this.
  4. Mar 16, 2024 at 3:09 PM
    Mattone3
    Mattone3 New Member
    2017 Silver Sky SR5 4x4
    20" Methods with 33" Tires OME BP-51 Lift- "incoming" Led interior ambient lighting Self made underseat storage Full truck sound deadening W/ sound system install
    Hello, I know this is an Old thread but I experienced this problem as well and just found a work around that may help. After installing an LC7i and 2 amps myself I couldn't get any volume from head unit at all....
    I spent a couple weeks scratching my head checking for continuity in my harness, until I discovered that when using the remote out from the harness would cause there to be no volume meter and no output from the HU.
    I just used the GTO(Great Turn On) feature from the LC7 to turn on both amps and now im up and running. Thanks for all the info here and I know this won't work for everyone but I hope someone can benefit- peace.
    DarknessReigns[OP] likes this.
