A build for speed and handling, I know it sounds crazy.
Discussion in '2.5 Gen Builds (2014-2021)' started by Fastlane47, Feb 5, 2021.
  1. Feb 6, 2024 at 7:03 AM
    #331
    nags
    nags New Member
  2. Feb 6, 2024 at 7:55 AM
    #332
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Did you change the cams or going stock cams?
    Fastlane47[OP] likes this.
  3. Feb 6, 2024 at 8:01 AM
    #333
    Fastlane47
    Fastlane47 [OP] New Member
    Maryland
    2018 Platinum
    Stock cams, I didn't see any increase in HP using the aftermarket cams.
    reywcms likes this.
  4. Feb 6, 2024 at 8:31 AM
    #334
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Agreed
  5. Feb 19, 2024 at 9:54 AM
    #335
    Fastlane47
    Maryland
    2018 Platinum
    PXL_20240220_160920545.jpg PXL_20240220_181808781.jpg Coming together. PXL_20240219_175336844.jpg
    I'm also glad I have a shinny radiator that you can't see, lol.
  6. Feb 19, 2024 at 12:19 PM
    #336
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Damn! I can’t wait to see the results
  7. Feb 22, 2024 at 12:31 PM
    #337
    Fastlane47
    Maryland
    2018 Platinum
  8. Feb 22, 2024 at 12:34 PM
    #338
    nags
    nags New Member
  9. Feb 22, 2024 at 12:36 PM
    #339
    Fastlane47
    Maryland
    2018 Platinum
    lmao.
    Mountun Goat likes this.
  10. Feb 22, 2024 at 12:51 PM
    #340
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Man, I'm jealous, what I wouldn't give for a day with a lift. You redoing your fuel lines, or just putting fire sleeve on them? Looking great!
    M3Tundra-JK and Fastlane47[OP] like this.
  11. Feb 22, 2024 at 3:16 PM
    #341
    Fastlane47
    Maryland
    2018 Platinum
    The fuel lines are new, Prospeed fuel system.
    armyoffoo[QUOTED] likes this.
  12. Feb 22, 2024 at 4:24 PM
    #342
    Fastlane47
    Maryland
    2018 Platinum
    Here is a full run down of this stage of the build.
    Built short block from XAT with ARP main studs.
    Ported and polished heads, installed BC valve springs and ARP head studs.
    Upgrade oil pump from XAT.
    XAT dampener with bigger crank pulley.
    @snivilous 2.0 supercharger pulley.
    Power Trax LSD.
    Stainless works long tune header's with high flow cats.
    Koyo Radiator.
    Misimoto Thermostat.
    ZZP high flow heat exchanger pump.
    Fingers crossed, the truck should be running tomorrow, just need to measure for a belt and put the body back on.
  13. Feb 22, 2024 at 4:46 PM
    #343
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    F*&ckin bada$$.
  14. Mar 1, 2024 at 5:00 PM
    #344
    Fastlane47
    Maryland
    2018 Platinum
    One project coming to a completion, another project arrives.PXL_20240301_111921291.jpg PXL_20240301_112100831.jpg it's a 2018 AMG E63 Edition One. I think I'll start with a tune and an intake.
  15. Mar 2, 2024 at 4:27 AM
    #345
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I keep up with this thread as a reminder that I could be livin’ better
  16. Mar 6, 2024 at 8:58 AM
    #346
    Fastlane47
    Maryland
    2018 Platinum
    nags, Black@Blue19, MTRock and 11 others like this.
  17. Mar 6, 2024 at 9:02 AM
    #347
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I don’t know how I have managed to miss thread but damn. DAMN!
    That’s one hell of a build you have going on there.
  18. Mar 6, 2024 at 9:05 AM
    #348
    Fastlane47
    Maryland
    2018 Platinum
    Thank you sir.
    ZappBrannigan likes this.
  19. Mar 7, 2024 at 7:36 AM
    #349
    Fastlane47
    Maryland
    2018 Platinum
    Well, I spoke too soon. After letting the engine warm up we found coolant weeping on the outside of the heads. A pressure test confirmed it, not getting into the cylinders, just on the outside. Today we are removing the valve covers and re-tightening the head bolts to spec. Hopefully that's it. The block was resurfaced and so were the heads, so I know they are true and flat.
  20. Mar 7, 2024 at 10:40 AM
    #350
    Fastlane47
    Maryland
    2018 Platinum
    Just in case, we are removing the heads and replacing the head gaskets and using a high temp sealant.
  21. Mar 16, 2024 at 8:44 AM
    #351
    Fastlane47
    Maryland
    2018 Platinum
    All back together, we will do a final check Monday.
  22. Mar 16, 2024 at 8:46 AM
    #352
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Did you find the cause of the leak?
    Wynnded and Fastlane47[OP] like this.
  23. Mar 16, 2024 at 8:53 AM
    #353
    Fastlane47
    Maryland
    2018 Platinum
    So a few things I noticed, but in the end maybe it was the gaskets themselves. The block has vertical style groves in it from the way it was cleaned, I don't think that had and effect because we razor edged everything to make sure it was flat. The heads and the block and they are both flat, so the groves I don't think did anything. Second was that the head studs backed off to 90ft pds, we set them too 100 ft pds, and the truck only had two heat cycles, for a total of 45mins of running. Third, we didn't use any copper sealant on the first set of head gaskets, this new set we did. So fingers crossed, we are all good.
  24. Mar 16, 2024 at 8:54 AM
    #354
    Fastlane47
    Maryland
    2018 Platinum
    If you zoom in you can see the groves. Again, I don't think it had anything to do with the leak.
  25. Mar 16, 2024 at 10:42 AM
    #355
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    That block finish “appears” to be, well, very rough. Like, appropriate for an old cast iron block with a composite gasket type of finish. Kind of difficult to say with a single pic. MLS gaskets require a fairly nice finish… if you have further issues, look close at that.
  26. Mar 16, 2024 at 10:57 AM
    #356
    Fastlane47
    Maryland
    2018 Platinum
    I thought the same thing, but the engine builder said it's normal, and when we checked it with a razor edge, it was flat.
    Jowett[QUOTED] likes this.
  27. Mar 21, 2024 at 4:15 AM
    #357
    Fastlane47
    Maryland
    2018 Platinum
    I have made a few shake down runs, the boost gets up to 12psi quick at 1/4 throttle.PXL_20240321_110050790.jpg PXL_20240321_110731008.jpg
  28. Mar 21, 2024 at 6:19 AM
    #358
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is a sweet ride and a badass build! Can't wait for the shakedown cruise.
  29. Mar 21, 2024 at 6:35 AM
    #359
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Lord I really need a built motor. Can’t wait to see this thing on kill
    nags, Mdl, Wynnded and 3 others like this.
  30. Mar 21, 2024 at 4:10 PM
    #360
    Fastlane47
    Maryland
    2018 Platinum
