OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. Mar 13, 2024 at 6:17 AM
    #361
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Actually, OBD Fusion does support CarPlay now (as of v6.0.0 that came out about a month ago), doesn't say anything about AndroidAuto though so I'm not sure. You can't view graphical gauges on CarPlay but you can view the gauge name and value. I saw it on my car the other day and opened it, had a couple basic PID's setup like RPM and coolant temp, I just haven't had time to try adding more like voltage and transmission temp but you are supposed to be able to.
  2. Mar 13, 2024 at 7:02 AM
    #362
    koditten
    Kirk
    Midland of the Mitten
    Thankyou. That is good to hear.
    Gaston[QUOTED] likes this.
  3. Mar 13, 2024 at 9:32 AM
    #363
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    OBD Fusion Support for CarPlay:
    If you have OBD Fusion downloaded on your iPhone (not sure about Android) Fusion should show up on your home page in CarPlay. If it's not make sure to enable it from your phone settings.
    @Gaston is right about no gauges we are limited to numerical values.
    You add can PIDs to Display on CarPlay by following these steps:
    Go to Settings.
    Go to Preferences.
    Go to CarPlay.
    Now you can see your pages and their PIDs. To add a sensor click configure. To change the logo of the page select an image. To change the name of the page select edit.
    To edit existing PIDs simply click on them and follow the next step. You can customize the display name logos and names of pages.
    This is the list of sensor groups available for me.
    After this, you can see the sensors available for your truck. Select the one you want displayed and it’ll be added to the page.
    This is one of my pages as an example:
    I believe OBD Fusion isn’t supported on AA yet hopefully that changes soon as well as gauges and its ability to be multiscreen with maps or any other app.
    bulldog93, Gaston and koditten like this.
  4. Mar 13, 2024 at 9:37 AM
    #364
    koditten
    Kirk
    This seems odd to me.
    It seems it would be less distracting to have actual gauges appear vs text that needs to be read. Even in a 10" screen, more concentration would be required, I would think.
    mayan likes this.
  5. Mar 13, 2024 at 9:43 AM
    #365
    mayan
    Mayan
    DFW
    I agree gauges plus peripheral vision would be more helpful but we are limited to CarPlay's input-output regulations according to Fusion. Max PIDs per page is limited to 10 but this is a solid foundation to build off of hopefully they add more features.
    koditten[QUOTED] likes this.
  6. Mar 13, 2024 at 9:47 AM
    #366
    coTony
    Tony
    Montrose, CO
    I have not looked but can you add the app to the HU?
  7. Mar 13, 2024 at 10:00 AM
    #367
    mayan
    Mayan
    DFW
    Yeah only thru CP for now.
    koditten likes this.
  8. Mar 13, 2024 at 12:26 PM
    #368
    Gaston
    Gaston New Member
    Gary
    SE MI
    @mayan thank you for the quick tutorial. When I get some time I'll use it to get mine setup how I want it.
    mayan likes this.
  9. Mar 13, 2024 at 12:28 PM
    #369
    Gaston
    Gaston New Member
    Gary
    SE MI
    I believe I read somewhere that it is a limitation to CarPlay not allowing the display of the gauges and if that ever changes OBDFusion does plan to work on gauges being displayed through CarPlay :fingerscrossed:
  10. Mar 13, 2024 at 12:34 PM
    #370
    DRP
    DRP Old Member
    Dave
    I contacted OBD Fusion tech support today about the possibility of adding Android Auto support for their app and here's the response:
    Unfortunately, our app currently doesn't support Android Auto. We are looking into it, but Android Auto is currently somewhat limited in the information that can be displayed, plus Google is only allowing certain apps on Android Auto.
    Very impressed in this day and age how quickly they got back to me.
    I did find an app in the Google Play Store called DashOBD that does support AA and it does work but seems to have a limited number of PIDs to display. You can add custom PIDs so now I need to figure out where I can get the info to be able to do that.
  11. Mar 13, 2024 at 12:44 PM
    #371
    koditten
    Kirk
    Thankyou for that effort.
    I'm going to stick with obdf for the present. I was planning on running it off my phone anyways.
    Just all the info being bantered about, I thought it would be a simple process.
    Just like normal. I'm wrong.
  12. Mar 13, 2024 at 1:06 PM
    #372
    DRP
    DRP Old Member
    Dave
    Ha! Simple... we can only wish. Actually I think I'm going to pester OBD Fusion a little more. I found the DashOBD app info in Reddit where the developer was announcing the availability of his app. Someone replied asking how he got it to be AA approved and it had something to do with it being published under the Internet of Things (IoT) category in the Play Store which hasn't been around very long.
    I've been using the Car Scanner app but it's a bit clunky and I'd prefer having the info displayed on the big screen IYKWIM.
  13. Mar 13, 2024 at 4:20 PM
    #373
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    thanks for that! But,I don’t understand….. fusion told me the 22+ tundras weren’t supported. (Still can’t download vehicle add on) but yet we can get this stuff to display on CarPlay?
    can you explain this? (Feel free to dumb it down for this dummie)
  14. Mar 13, 2024 at 8:38 PM
    #374
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's good information. I have an old iPhone that would show Fusion so that why I assume it wasn't supported. It would be nice when Android auto becomes available. My new phone is a Samsung.
  15. Mar 14, 2024 at 6:30 AM
    #375
    mayan
    Mayan
    DFW
    Oh, I see what you mean. I didn't purchase any extra addons through OBD Fusion. I wonder if I could get away with purchasing a Toyota/Lexus 2017-2018 addon since that's probably when our ECU and TCU came out.
    I primarily used Car Scanner until I realized OBD Fusion was supported through CP so I'm still learning it too. I believe OF is still working to implement 22+ Tundra's computer units which is why they told you there is no support. That doesn't mean CP to OF connection isn't supported by 22+ Tundras. CarPlay is its own platform like AA so it controls what can be added and what not. Hope this helps.
  16. Mar 14, 2024 at 2:40 PM
    #376
    DRP
    DRP Old Member
    Dave
    An update on the DashOBD app I found yesterday.. It does work but it doesn't pop up in the AA list of apps on the truck consistently. I haven't figured out what sequence of connect/disconnect/bluetooth on - off gets it to work. I also got a message last night on my Samsung S22 that the DashOBD app was sucking my battery down quite fast so I removed the app.
    I did send another note to OBD Fusion letting them know there was another app out there on AA and I'll report back what they say.
    mayan and koditten[QUOTED] like this.
  17. Mar 14, 2024 at 4:49 PM
    #377
    Oldandfat
    Cannuckastan
    there no,add,ons,available,for the 22+ tundras
  18. Mar 14, 2024 at 6:30 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I don’t have the CarPlay setting under preferences on my IPhone.
  19. Mar 15, 2024 at 8:01 AM
    #379
    Gaston
    Gaston New Member
    Gary
    SE MI
    Which version of the app are you running?
  20. Mar 15, 2024 at 9:16 AM
    #380
    DRP
    DRP Old Member
    Dave
    Update on communication with OBD Fusion....
    Once again the support person got right back to me which is awesome. He said that based on my original communication with him (prior to me telling him about the other AA approved app I found) they had actually started looking into getting their app approved for AA. I don't want to get too excited yet just to keep the jinx factor low but it was pretty nice to hear they were considering it.
    BTW, I gave them a link to this thread so please only say nice things about OBD Fusion from now on:):D:thumbsup:.
    And also keep :fingerscrossed:
    kirkb, mayan and Ruggybuggy like this.
  21. Mar 15, 2024 at 9:18 AM
    #381
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm using 6.1.0.1319. I've uninstalled and installed it and still no carplay.
    mayan likes this.
  22. Mar 15, 2024 at 9:34 AM
    #382
    mayan
    Mayan
    DFW
    Since you are on the latest version. I wonder if iOS version has to do something with you not seeing it.
  23. Mar 15, 2024 at 1:40 PM
    #383
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe, I'm on Version 15.8.2. It's on an old iPhone 6 that I use for Carplay instead of my primary phone which is a Samsung. I like Carplay better than Android Auto so just use the IPhone in the truck.
  24. Mar 16, 2024 at 8:37 AM
    #384
    mayan
    Mayan
    DFW
    Im gonna try it with my old iPhone 7 and report back.
  25. Mar 29, 2024 at 7:35 AM
    #385
    Just got my VeePeak BLE and downloaded OBD Fusion. Have my first dash setup, interested to see some performance data on my next tow. Thanks to all on this thread that blazed the trail and shared some setup info! After I get done tinkering with it on my 2019, I might set it up for my 2000 also.
  26. Mar 29, 2024 at 12:46 PM
    #386
    Setup a towing screen for my next trip. The fuel available and MPG are only red due to an alarm value I set for low readings. Interestingly enough, I’ve got 77k miles and have pulled my 8k# travel trailer at least 15 times about an hour or so up to 3 hours in S4 with T/H and my ATF degradation is at 4900. Not bad for never having changed the fluid. Doing a drain and fill at the next oil change.
  27. Mar 29, 2024 at 3:59 PM
    #387
    DRP
    DRP Old Member
    Dave
    OBD Fusion has released a version that is compatible with Android Auto. They let me beta test for a couple of weeks and it seems to work well but it's only able to display text lines just like the CarPlay version. This is a limitation of AA and it's unknown if that will ever change. Also, they are working on PIDs for the 3rd gen but no release date set.
    The current version is 6.2.0.
    Gaston, koditten and mayan like this.
  28. Apr 1, 2024 at 7:57 AM
    #388
    Gaston
    Gaston New Member
    Gary
    SE MI
    I've played with the CarPlay version a bit and actually don't mind the text lines.
  29. Apr 14, 2024 at 10:53 AM
    #389
    DRP
    DRP Old Member
    Dave
    Has anyone been able to get a user defined PID for trans temp working with OBD Fusion on a Gen 3 Tundra? I tried these and they didn't work. Also tried changing Mode and PID to 21d9 as suggested in post #263 and no luck. Not the end of the world if I can't get it to work but thought I would try while we're waiting for OBD Fusion to release new PIDs for Gen 3.
    Mode and PID: 2182
    min value: 0
    max value: 350
    scale factor: 1x
    unit: F
    equation: ((((A*256)+B)*(7/100)-400)/10)
    ODB header: auto
    Mode and PID: 2182
    min value: 0
    max value: 350
    scale factor: 1x
    unit: F
    equation: ((((E*256)+F)*(7/100)-400)/10)
    ODB header: auto
    Any ideas, help, suggestions would be much appreciated. Thanks!
  30. May 1, 2024 at 3:51 PM
    #390
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    Noob question here…but is it normal with the OBDfusion and veepeak ble+ adapter to drop connection during a phone call. Every time I get a call it loses connection and I need to reconnect
