Changing Front Differential Fluid, I screwed up.
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Mar 10, 2024.
  1. Mar 10, 2024 at 5:57 AM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    So, I just stripped that stupid 10 mm drain bolt trying to change my front differential fluid.
    I even purchased a Lexus drain plug to replace the stupid Toyota drain plug.
    What are my options at this point?
    Basically, the 10 mm fitting is just a round metal hole at this point.
    Are there shops that specialize in fixing things like this?
  2. Mar 10, 2024 at 6:06 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I took mine to my favorite shop and asked them to weld a bolt to it and crack it loose for me.
    CaptRussia253, bulldog93 and 2mchfun like this.
  3. Mar 10, 2024 at 6:19 AM
    bfunke
    bfunke Tundra Curmudgeon
    Beyond the hex is a torx fit. Try using a large torx socket from HF. If that doesn’t work weld the nut.
  4. Mar 10, 2024 at 6:28 AM
    Retired...finally
    Excuse my ignorance here but is this the drain plug or fill plug. Are these pipe thread?
  5. Mar 10, 2024 at 6:43 AM
    bfunke
    Not pipe thread. Might also try an easy out from HF
  6. Mar 10, 2024 at 7:12 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    To clarify, you stripped the plug itself NOT the transfer case right?
  7. Mar 10, 2024 at 7:16 AM
    Retired...finally
    Thanks. A little late for this tip. Before doing your Col. Steve Austin impression trying to muscle the cap off, try tapping the cap with a small ball peen hammer for a few minutes to shock it loose. If there is enough room to swing a hammer use a hand held impact with a very good hex bit. Using heat before and after the ball peen tap dance helps too.
  8. Mar 10, 2024 at 7:54 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Weld the hex into it
    Slag_Dynamics and 2mchfun like this.
  9. Mar 10, 2024 at 7:55 AM
    2mchfun
    At this point your best option is probably to just have a muffler shop weld a short bolt in the stripped plug. After the weld, hit it with penetrating oil and begin to wrench it in both directions while tapping on the area around it with a hammer. Once loose, snug it and go home to change your oil. Be sure to remove the fill plug before draining any oil!
    myt1[OP], bulldog93 and Mr Badwrench like this.
  10. Mar 10, 2024 at 8:28 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Sharp chisle and hammer?
    coldcanuk, huntertn and Mr Badwrench like this.
  11. Mar 10, 2024 at 8:29 AM
    2mchfun
    Not a great idea to remove material that can be welded to.
  12. Mar 10, 2024 at 8:34 AM
    Mr Badwrench
    Mr Badwrench New Member
    ^ This is how I removed mine. A little, just a little, heat from a propane torch, then turned a can of electronic duster upside down and shocked it with cold. Then a sharp punch and a hammer along the outer radius of the plug.
    I didn't remove material, I made a little pocket with the punch and walked it out.
    ZappBrannigan and coldcanuk like this.
  13. Mar 10, 2024 at 8:36 AM
    Mr Badwrench
    Or this... this is probably more "sure fire"
  14. Mar 10, 2024 at 8:56 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I have a Lexus plug ready to go for when I take mine out next. Even lying under the truck, you can take your time with a sharp chisel or punch and try and tap it out (room for a DIY guy), great advice on that above. If you take it to a great shop and trust the mechanic perfect but I'd be worried about some unknown gorilla welding things to my truck.
    ZappBrannigan likes this.
  15. Mar 10, 2024 at 9:43 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    I tried the chisel method, and mine was simply too tight for that to work (even with a solid amount of heat applied).
    So I went to a local welding shop and had them weld an old castle nut onto it. Well spent $20 (even tipped the guy another $20 because he really saved my bacon).
    Kinda looking forward to the next front diff drain and fill, now that I've got the Lexus plugs in there.
  16. Mar 10, 2024 at 9:52 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    glad you got it taken care of. What’s the part number on that Lexus bolt? I need to do mine soon and I’d like to have that replacement handy.
  17. Mar 10, 2024 at 9:58 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Lexus plugs:
    90341-24016 (drain)
    90341-18060 (fill)
    *You won't be able to order them from your local Toyota dealer or typical online Toyota parts retailers (strangely enough). And I found them to be most affordable at Partsouq.com (even though they ship from the middle east).
    CaptRussia253 and Shanet421 like this.
  18. Mar 10, 2024 at 10:12 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Did you order washers as well?
    2mchfun likes this.
  19. Mar 10, 2024 at 10:18 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Seriously? I can’t just go down to the local Lexus dealership? What’s that all about?
    BoyHowdy likes this.
  20. Mar 10, 2024 at 10:27 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    You should be able to get them from a Lexus dealer, I got mine from my local Lexus dealer parts counter.
  21. Mar 10, 2024 at 10:58 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Local Lexus dealer should work. We only have a Toyota dealer and they couldn't order it, which seemed stupid to me
  22. Mar 10, 2024 at 10:58 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    No I bought a big pack of crush washers off Amazon and have been using some from that for all my Toyota vehicles for the past couple years
  23. Mar 10, 2024 at 11:05 AM
    Shanet421
    San Diego,CA
    Ordered
    Couldn’t resist the price…thanks!
  24. Mar 10, 2024 at 2:44 PM
    Mr Badwrench
    Lexus had the right idea with that big hex.
  25. Mar 10, 2024 at 3:02 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Are those Lexus part numbers the same for the rear diff, or are they not necessary for the rear? I have not done mine yet. Thanks.
  26. Mar 10, 2024 at 3:10 PM
    Shanet421
    San Diego,CA
    Not necessary for the rear diff as they are already hex head
    Xcumminsguy[QUOTED] likes this.
  27. Mar 10, 2024 at 3:12 PM
    And it would protrude further than stock in a bad way
  28. Mar 10, 2024 at 3:21 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I honestly was pretty disappointed in Toyota when I bought my 2018 and noticed the front diff still had those crappy Allen socket bolts. I have an '03 Tacoma that I daily drove until buying my Tundra and was sure Toyota would have switched to hex head bolts for that diff by now.
  29. Mar 11, 2024 at 11:14 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well I just left my local Lexus dealer and they naturally didn’t stock the plugs but they did order them for me.
    Retired...finally and Red&03Taco like this.
  30. Mar 11, 2024 at 12:05 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    I just checked Bell Lexus out of Scottsdale, AZ, and the plugs are $18.67 delivered (no shipping for some reason). So these will fit a 2018 diff as well? I wanted to verify before I go ordering anything.
