Which UCAs?
Discussion in '1st Gen Tundras (2000-2006)' started by Mymoddedgt, Mar 9, 2024.
  1. Mar 9, 2024 at 3:53 AM
    Mymoddedgt
    Mymoddedgt [OP] New Member
    2000 Tundra SR5 with TRD package
    In the process of leveling my truck and was told I should consider also getting UCAs for lifted trucks. What is a good set that won't break the bank?
  2. Mar 9, 2024 at 4:43 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Spc. Freedom off road is another option.
  3. Mar 9, 2024 at 4:44 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Spc or eibach for $700
    Jba for $600
    I have the jba & like the build quality, but have only put 1000 miles on em so far.
    @bmf4069 how are those freedoms holding up?
    freedom offroad for $400
    Elevatorguy likes this.
  4. Mar 9, 2024 at 5:06 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    shifty` and Radarninja like this.
  5. Mar 9, 2024 at 5:15 AM
    Elevatorguy
    James
    Yeah, I forgot about jba, I like the way those look the best actually.
  6. Mar 9, 2024 at 5:24 AM
    Mymoddedgt
    I will be lifting it 2.5".
    Wheel is
    Offset: -12
    BP: 6x5.5
    Tire is a 285x70x17.
    FishNinja[QUOTED] likes this.
  7. Mar 9, 2024 at 5:31 AM
    FishNinja
    Lee
    06DC2wd
    100% watch those vids. It'll help you choose the best UCA for you.
    I personally would stay away from adjustable. The wheel/tire set up your running isn't extreme enough to warrant it. Freedoms or something a long those lines that help move the ball joint and allow for better clearance at full lock. But yea you're on the right track my guy
  8. Mar 9, 2024 at 5:45 AM
    Mymoddedgt
    Thank you sir
  9. Mar 9, 2024 at 5:47 AM
    They're doing good so far. Beat on em pretty good in AZ this year. They're not adjustable though.
    Elevatorguy and Mr.bee[QUOTED] like this.
  10. Mar 9, 2024 at 6:04 AM
    Elevatorguy
    James
    You’re running jba too?
  11. Mar 9, 2024 at 6:19 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No, he has freedoms. Well, in tx we all have freedom, especially if you dont get caught.
    Elevatorguy, bmf4069 and FishNinja like this.
  12. Mar 9, 2024 at 6:24 AM
    FishNinja
    Lee
    06DC2wd
  13. Mar 9, 2024 at 6:46 AM
    I didn't watch the video but I have a similar set up. I've been running SPC arms since 2019 without issue. I don't love the price of them now. Greedy bastards.
    Some people had issues with the more expensive uniball arms rubbing the top of the shock bucket(I think that's the right term). They had to take an angle grinder to it.
    Read my post here.
    https://www.tundras.com/threads/ball-joints-vs-uniball-ucas-on-your-1st-gen.74516/#post-1904212
  14. Mar 9, 2024 at 7:52 AM
    shifty` Ten EV 12's so you know I raise hell
    Do yourself a big favor. Read the "Suspension, wheels & tires ..." section of this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It will give you the education you need on lifting these trucks and what you need to know in general, before you make a stupid mistake, many of which led to that content existing, people that came before you fucking up.
  15. Mar 9, 2024 at 7:59 AM
    I was originally running same wheel specs as you, 9" wide with 4.5 backspace, but with a ~0.6" smaller diameter tire (275/70r17) and a 2" lift. Overall, the truck sits ~4" higher off the ground, making it difficult for the kiddos (11, 13) to get in/out.
    I rubbed in the wheel well before reaching full lock, even with my mudflaps off. You too, will rub. At minimum you'll rub your mudflaps and likely need to remove completely. I ended up downsizing to a 8.5" wide wheel and 4.75 backspace and it's much more manageable (same tire size).
    Be sure you have the shop doing the alignment give as much caster as possible, dont' use a chain store for alignment. If you go with SPC uppers, don't clock to their recommended OEM setting. Center the UBJ in their slot, clocked at "C" for +1, or better yet B for +1.75 caster. It'll make the truck more driveable on the road, and hopefully mitigate at least some rubbing.
  16. Mar 9, 2024 at 8:13 AM
    And if it helps... some before/after on a truck with ~70k miles, so little suspension wear/fatigue. Pic angles do funny things, especially with the 1st/last pic:
    Elevatorguy and Mymoddedgt[OP] like this.
  17. Mar 9, 2024 at 9:06 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Those dark grey wheels look so damn fine.
