1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Mar 7, 2024 at 2:22 PM
    #961
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    CL and FB are where we are normally seeing them
  2. Mar 7, 2024 at 3:29 PM
    #962
    shifty` [OP] You can call 1 (800) PP5-1-DooDoo
    I know where there's one in West Knoxville, is that too far away?
  3. Mar 7, 2024 at 5:54 PM
    #963
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I wonder if this would fit?
  4. Mar 7, 2024 at 5:57 PM
    #964
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  5. Mar 7, 2024 at 9:21 PM
    #965
    inv3ctiv3
    inv3ctiv3 New Member
    Jim Bob
    Finally got around to installing my leer and Sherpa crows nest rack! Scored this shell for $500 on FB.
    Wallygator, Bmktw2, txagg and 8 others like this.
  6. Mar 8, 2024 at 8:16 AM
    #966
    How are you going to prevent the shell from cracking when using the Roofnest? Like, is the roof of the shell reinforced in some way to allow for 150-250lbs of human weight shifting around, with the added weight of the steel crows nest, without cracking the fiberglass at the drillpoints of the crows nest?
    jerryallday and FrenchToasty like this.
  7. Mar 8, 2024 at 2:58 PM
    #967
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    How did you attached the roof rack? Iv been looking into one but dont have any rails and will have to drill thru the roof. It will have max 150lbs on it, more for just a swing out awning and light storage
    Or so i need a shell with tracks?
  8. Mar 8, 2024 at 3:01 PM
    #968
    Gotta drill baby. That's what I did. My roof basket came with brackets that allowed me to mount it.
  9. Mar 8, 2024 at 3:05 PM
    #969
    I can't speak for him but years ago I called ARE and they said my topper could safely hold a tent. Due to it's age I'm skeptical. I'm also too cheap to buy a RTT.
    I've seen other people add metal reinforcement inside their topper so it can take the weight of a tent.
  10. Mar 8, 2024 at 3:08 PM
    #970
    Mine is like 1” thick in the center of the roof; I followed the edge when I mounted my roof rails. But yeah I don’t know if id trust that much weight up top
  11. Mar 9, 2024 at 7:01 PM
    #971
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Agreed
  12. Mar 9, 2024 at 7:20 PM
    #972
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Maybe if you build a sweet bed cage for support. Also would improve safety. But then youre adding weight, plus the weight and top heaviness of an RTT.
    Only way I'd run an RTT is on a very short bed rack. But truth is, I'd never run an RTT.
  13. Mar 10, 2024 at 6:27 AM
    #973
    Freebie on the east side of ATL, looks like a Leer 100R despite the branding and rear door, which looks to be a replacement.
    You’ll be making up for the freeness replacing those windows and painting. I’d toss a windoor on the drivers side and a fold-down slider up front, slap some color on it.
    The Black Mamba and JasonC. like this.
  14. Mar 10, 2024 at 8:39 AM
    #974
    That’s one of those free ones that ends up costing more than a good condition one.
  15. Mar 10, 2024 at 9:01 AM
    #975
    Yup. But if you were resourceful, I could see you coming out ahead. Front window has a boot; if you stuck with a boot, and did what @FirstGenVol did with his side window (replace with diamondplate or similar), it's just a matter of spraying it your desired color, and unfuckering that back door.
    Seems like it's tough to find shells that don't need paint work, even the ones only a few years old. Losing battle on that.
  16. Mar 11, 2024 at 1:36 PM
    #976
    inv3ctiv3
    Jim Bob
    It was $500 if it cracks then it cracks I'm not that worried about it. Leer says it can technically hold the weight but we'll see.
  17. Mar 11, 2024 at 2:09 PM
    #977
    cody c
    cody c New Member
    cody
    blue 2006 tundra double cab 4x4
    retractable fog lights, dry box mounted winch
    Is there a list or a spreadsheet or something somewhere that says what other vehicle camper shells are compatible? Someone must have compiled a list somewhere by now!
  18. Mar 11, 2024 at 2:11 PM
    #978
    daveeasa
    It’s a very short list. See below :)
    Tlar25, rphass17, des2mtn and 3 others like this.
  19. Mar 11, 2024 at 2:13 PM
    #979
    cody c
    cody c New Member
    cody
  20. Mar 11, 2024 at 2:54 PM
    #980
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    He's saying the list doesn't exist because nothing else is fully compatible. There are a few close fits, but they will inevitably leak.
  21. Mar 11, 2024 at 3:40 PM
    #981
    Just make you some 2x4 jacks to prop up under it when you’re using it.
  22. Mar 11, 2024 at 5:25 PM
    #982
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Here’s one I found a few months ago. You’ll have to comb through it
    https://raybuck.com/pickup-truck-bed-size-dimensions/
    cody c[QUOTED] and FrenchToasty like this.
  23. Mar 12, 2024 at 9:02 AM
    #983
    cody c
    cody c New Member
    cody
    Thanks! I had a dig through, there's pretty much nothing listed that's even close. What a bummer but at least I have a conclusion to the question!
  24. Mar 12, 2024 at 4:25 PM
    #984
    This guy is either totally clueless of how much that back glass costs, or thinks very highly of his cap. White AC cap, maybe all glass intact for $350 north of ATL:
  25. Mar 12, 2024 at 7:18 PM
    #985
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    If you can habla, maybe he’ll part with the top
    shifty`[OP] likes this.
  26. Mar 12, 2024 at 7:21 PM
    #986
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  27. Mar 12, 2024 at 7:25 PM
    #987
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Here’s one for an access cab in Louisiana
    455h0le_dachshund likes this.
  28. Mar 12, 2024 at 7:28 PM
    #988
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    AC or maybe DC with the measurements in Springtown, Texas
  29. Mar 12, 2024 at 7:31 PM
    #989
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Hard cover (not a shell)
  30. Mar 13, 2024 at 10:17 AM
    #990
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Sick. I love this style. But my luck, I'd bust out the top window offroading and it'd be like $1M to fix it. Meanwhile, I'd have to ductape it as the freezing rain comes down on me and my stuff all night haha
    txagg likes this.
