  1. Mar 7, 2024 at 8:25 PM
    Did the retainers look good still? I would assume that’s where it’s leaking, I think that’s what contacts the seal
  2. Mar 7, 2024 at 8:36 PM
    Everything still looked good. Only a few 1000 miles on them.
    mcharfauros and Jack McCarthy like this.
  3. Mar 7, 2024 at 8:46 PM
    Soooo……..
    I think the retainers have a bevel or chamfer if you will, and that’s supposed to be up towards the diff end of the axle. It looks like yours are facing away towards the hub end.
    oscardog86 likes this.
  4. Mar 7, 2024 at 9:25 PM
    Also maybe pop the abs sensor on the side that’s leaking and compare it to the other side if it’s not leaking.
    I don’t like the guys measuring technique in the video on the webs, he measures from a ever changing poijt(bad bearing) I measured from the axel tip instead as a known control.
    I’m not sure if anyone has that measurement for a AC, hahah I definitely don’t remember what mine was, but I also noticed; one side was a little deeper than the other looking thru the abs sensor hole…… knock on cardboard….. no leaks yet!
    oscardog86 and FirstGenVol like this.
  5. Mar 8, 2024 at 2:14 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I used the Rust oleum wheel paint too, looks pretty good after one winter/salt etc..
  6. Mar 8, 2024 at 3:11 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So…. It’ll look good pretty good 10 years from now in Texas :rofl:
    txagg, FrenchToasty and bmf4069 like this.
  7. Mar 8, 2024 at 3:19 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :)yup, fact.
  8. Mar 8, 2024 at 4:06 AM
    How’d your backing plate get so crusty rusty?
    You aren’t driving unprotected in the snow are you?
  9. Mar 8, 2024 at 4:11 AM
    I could be wrong but a lot of that looks like West Texas sand/crud stuck to gear oil. Not rust.
  10. Mar 8, 2024 at 4:16 AM
    Ah. Can't see that level of distinction on my phone. My bad.
  11. Mar 8, 2024 at 4:19 AM
    Makes sense. I just unpressed and repressed what was on there. I'm prepared to do it again, and use OEM this time. I'm thinking this time if I buy a press, I can shove it in the shed of shame, that way I can sharpie test the axle easily. Just thoughts at this point.
  12. Mar 8, 2024 at 4:20 AM
    Yup. Just dirt soaked gear oil.
  13. Mar 8, 2024 at 5:22 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Can we drive 33 miles without police intervention during the Friday morning commute, all highway, through downtown Knoxville?
    NUDRAT, bmf4069, BroHon and 5 others like this.
  14. Mar 8, 2024 at 5:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    :yes:
    NUDRAT and FrenchToasty like this.
  15. Mar 8, 2024 at 5:24 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    gonna zip tie the taillights to the bumper?
    NUDRAT, 455h0le_dachshund and BroHon like this.
  16. Mar 8, 2024 at 5:44 AM
    jpink
    Knoxville
    haha yeah zip ties like Dennis Reynolds.
  17. Mar 8, 2024 at 6:06 AM
    Pick up a sheet of 3/4” 4x8 MDF for your new flatbed there @jpink.
  18. Mar 8, 2024 at 6:18 AM
    Most states require fenders of some kind cover the tires. Think you'll be fine for a short drive. Gonna wire wheel and treat all the barnacled areas first, right? Love the team ramrod bed in the background at the JY.
  19. Mar 8, 2024 at 6:36 AM
    jpink
    Knoxville
    Yeah, gonna clean it up as best I can did a quick blast with the pressure washer down the street. Had to get to work but gonna go spend some more time there tonight.
    Not sure why they felt the need to drill a 2nd hole and weld but as @FirstGenVol keeps saying, if this truck could talk.
    After the quick run at it with the pressure washer. Will go back for more attention later.
    https://youtu.be/SXEskKKELd0
  20. Mar 8, 2024 at 6:44 AM
    So I tried a different alignment shop today. All they do is suspension and brake work. On the phone, the owner knew that our trucks do well with caster around 3.
    Instead of using the Hunter machine they went old school and did it manually. The truck drives straight but the wheel is slightly crooked which is frustrating. They had to completely reset the toe after I replaced the tie rods.
    This was the most expensive alignment I've ever paid for. $195. Literally double the price the 4x4 shop charges. I had high hopes but I'm not sure it was worth it. One positive thing is that I didn't rub at all. Went full lock to full lock and didn't touch the fender liners.
    I noticed this eccentric cam is is a completely different position than it was previously.
    Passenger side is not.
    bmf4069, Voss, BroHon and 2 others like this.
  21. Mar 8, 2024 at 6:53 AM
    Looks like you started with more camber on the driver's side and they had to adjust to zero it out. I would also take it back and make them fix the crooked steering wheel, not that hard.
    shifty`, BroHon, oscardog86 and 2 others like this.
  22. Mar 8, 2024 at 8:21 AM
    Go to Harbor Freight, get some cheap round brake lights for a trailer and install those. As long as you have brake lights they should be lenient.
    bmf4069 and Jack McCarthy like this.
  23. Mar 8, 2024 at 8:26 AM
    That's actually not asw bad as I was thinking, I don't see much delam/flaking (some accumulation, but looks superficial). 30 mins of mediablasting, blowoff, self-etch primer, then seal with a topcoat a couple passes within recoat window, it's good for another 10-20yrs.
    I guess in a pinch, you could wirewheel it, but ... it'll take a couple hours and won't be as thorough.
    That LSPV hsa seen better days ...
    FirstGenVol and jpink[QUOTED] like this.
  24. Mar 8, 2024 at 8:45 AM
    jpink
    Knoxville
    Yeah, for being a FGT kept outdoors in Minnesota and Iowa for the first 16 years, not bad all things considered. Bought a fair amount of the POR-15 degreaser/etch (gallon each) and will work through the process once I blast the frame some more.
  25. Mar 8, 2024 at 8:56 AM
    I agree. With a little TLC I think the frame will be good for a while. The issue is that damn coating they put on it. I noticed when under the truck a few weeks ago it's peeling off. We just need to knock as much off as possible so we can treat the rust with POR-15.
  26. Mar 8, 2024 at 9:02 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    My factory skid is ready for Valhalla
    JasonC., txagg, oscardog86 and 11 others like this.
  27. Mar 8, 2024 at 9:10 AM
    Witnessed
  28. Mar 8, 2024 at 9:36 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  29. Mar 8, 2024 at 9:37 AM
    oscardog86, Tlar25, artsr2002 and 5 others like this.
  30. Mar 8, 2024 at 9:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    nailed it
