Exhaust Leak/ Gasket Leak?
Discussion in '1st Gen Tundras (2000-2006)' started by 2000TundraKid, Mar 7, 2024.
  1. Mar 7, 2024 at 4:12 PM
    2000TundraKid
    2000TundraKid [OP] New Member
    2000 AC SR5 4.7 V8 2WD
    Grill Guard and 16" 398 Vision Manx Competition
    Recently I've had this ticking noise come up that is intense when the vehicle is cold but once warmed up a decent amount (just shy over the lowest line marker) Will be less intense and fade away faster and its lead me after just some random google searches to be the Manifold Gasket or worn out Cats.
    You can listen here:
    https://www.youtube.com/shorts/c729acM_UNU
    The whole exhaust is basically rusted both driver and passenger so its probably ideal to get that replaced but the ticking I want to make sure is what's correct or not.
    Driver side
    Passenger Side
  2. Mar 7, 2024 at 4:15 PM
    Could be your manifold. They’ve been known to have poor welds that crack where the pipe is welded to the plate.
    2000TundraKid[OP] likes this.
  3. Mar 7, 2024 at 4:16 PM
    shifty` Ten EV 12's so you know I raise hell
  4. Mar 7, 2024 at 4:21 PM
    2000TundraKid
    Thanks for the Info!
  5. Mar 8, 2024 at 10:26 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If it is your manifolds it is a very labor intensive and expensive job. Best to leave it be, it isn't causing any real harm.
  6. Mar 8, 2024 at 11:59 AM
    2003DC
    2003DC New Member
    P.S. - your exhaust system looks pretty solid to me. Surface rust, of course, but not sever corrosion. You even still have your heat shields! I wouldn't spend money replacing working components that aren't supposed to be clean or shiny in the first place (and will never be rust free unless you go stainless steel).
  7. Mar 8, 2024 at 1:16 PM
    2000TundraKid
    I mean if anything I've noticed I'm going through gas at lot more than normal. I usually get up to around 177 miles before I get to just under half a tank but now I'm getting 120 miles before I'm under half a tank. Usually only have to fill up every month or so, but noted! I hear upwards of what 2-3k parts and labor?
  8. Mar 8, 2024 at 2:25 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    dang, I would check spark plugs and coil packs and then get a OEM air filter and see how your gas mileage is then. I had a nice jump in gas mileage after I changed my plugs and wires.
