Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Feb 27, 2024 at 8:46 AM
    #61
    Lmuggs
    Lmuggs New Member
    Tampa
    2014 Tundra CrewMax Limited 4X4
    Ordered an Xtool D7S that should get here today!
    ToyoMafia[QUOTED] likes this.
  2. Feb 27, 2024 at 12:26 PM
    #62
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Let us know how it goes please.
    I need to buy one of these but do not have an extra 400 to spend on it. I only realized I had the issue when my MPG dropped dramatically.
    Lmuggs[QUOTED] and ToyoMafia like this.
  3. Feb 27, 2024 at 2:05 PM
    #63
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Damn handy thing to have.
    Lmuggs[QUOTED] likes this.
  4. Feb 27, 2024 at 2:06 PM
    #64
    ToyoMafia
    Magic carpet.
    Well if ya drive down to Naples we will reset it for ya.
  5. Feb 28, 2024 at 4:52 AM
    #65
    ToyoMafia
    Magic carpet.
    Lightning deal on the Xtool D7 just snagged
    OldGuy03, AZTundra and Ohannon7 like this.
  6. Feb 28, 2024 at 4:59 AM
    #66
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I would make sure the D7 in your post has the same functionality to reset fuel alcohol calculation as the D7S that you have used.
    If so, that is a good price.
  7. Feb 28, 2024 at 5:04 AM
    #67
    ToyoMafia
    Magic carpet.
    It says it does the fuel density relearn so hopefully it’s good.
    Ohannon7 likes this.
  8. Feb 28, 2024 at 5:22 AM
    #68
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Tampa to Naples isn't far so that would be really appreciated but this lighting deal has me really thinking about buying it, especially since this seems like an ongoing thing I will need to do from time to time.
    :spending:
    ToyoMafia likes this.
  9. Feb 28, 2024 at 5:28 AM
    #69
    ToyoMafia
    Magic carpet.
    These units are very useful. Between both my trucks it will be beneficial. I already ordered two key fobs to try that programming feature.
    Ohannon7[QUOTED] likes this.
  10. Feb 28, 2024 at 5:57 AM
    #70
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I've been trying to buy it but it's $329 for me. Idk how you got it for $269. This isn't the first time Amazon won't give me the lower price that others see either, it's very odd.
  11. Feb 28, 2024 at 6:19 AM
    #71
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    When originally posted, there was a $75 coupon in addition to the lightning deal price.
    ToyoMafia and Ohannon7[QUOTED] like this.
  12. Feb 28, 2024 at 6:52 AM
    #72
    ToyoMafia
    Magic carpet.
    Correct
  13. Feb 28, 2024 at 10:37 AM
    #73
    Lmuggs
    Lmuggs New Member
    Tampa
    Performed the "Fuel Density Learning Value Reset" using the D7S scan tool just now and truck started up great on cold start. I drove to the gas station about 4 miles away and the Ethanol learned percentage was reading 5.3% (It was at 85% prior to resetting). I filled up with 87 unleaded and checked when I got home and the percentage is reading 14%. Not positive if its normal to fluctuate like that but my guess is that's fine. Turned ignition off and on a few times and its starting better than it has in several weeks since the issue started happening again.
  14. Feb 28, 2024 at 10:40 AM
    #74
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    did your scan tool also reset the fuel trim values?
    It is two separate steps with Techstream; one step with the Launch scanner. May depend on the software the D7S uses.
    OldGuy03 and ToyoMafia like this.
  15. Feb 28, 2024 at 10:48 AM
    #75
    Lmuggs
    Lmuggs New Member
    Tampa
    Yes, those values were reset also. The long term fuel trim was -23. After the reset it's 0.
  16. Feb 28, 2024 at 10:56 AM
    #76
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Mine fluctuated a while after reset.
    By the 3rd fill up it stabilized.
  17. Mar 2, 2024 at 5:47 PM
    #77
    Dkheaddo
    Dkheaddo New Member
    Boston
    I just bought the Launch X431 Elite for Toyota Lexus, $169 on Amazon, was able to read and reset my fuel density in less than 5 mins….
    It was at 85%…
    Ohannon7, Skew12, Lmuggs and 4 others like this.
  18. Mar 7, 2024 at 1:21 PM
    #78
    Theraddad89
    Theraddad89 New Member
    2013 White Tundra
    Anyone in Oklahoma City or in the state of Oklahoma that wouldnt mine letting me buy them a case of brews in exchange for letting me come to them to do this reset? I have a 2013 SR5 and have the exact same issue. Thought it was just normal for the truck! Turns out it isnt!
    Okie1 and ToyoMafia like this.
  19. Mar 7, 2024 at 1:48 PM
    #79
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just pulled the trigger on one too. $10 off right now.
  20. Mar 8, 2024 at 2:55 PM
    #80
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Do y’all have a direct link to it? Any seem to find the Toyota version.
  21. Mar 8, 2024 at 3:51 PM
    #81
    Dkheaddo
    Dkheaddo New Member
    Boston
  22. Mar 8, 2024 at 3:54 PM
    #82
    Dkheaddo
    Dkheaddo New Member
    Boston
    Dang, I just looked, that was the one I bought but it doesn’t show the Toyota Lexus anymore, just Ford and Honda.
    Skew12 likes this.
  23. Mar 8, 2024 at 7:17 PM
    #83
    Skew12
    Skew12 New Member
    I’ll give it a shot. If it doesn’t work, it’ll go back. Thanks bud.
  24. Mar 8, 2024 at 8:46 PM
    #84
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It was sold out as of yesterday but it looks like there are 2 available.
  25. Mar 8, 2024 at 8:47 PM
    #85
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It won't work if you buy a Ford scan tool. There are 2 Toyota/Lexus versions available.
    Skew12[QUOTED] likes this.
  26. Mar 10, 2024 at 11:49 AM
    #86
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just arrived.
  27. Mar 10, 2024 at 3:45 PM
    #87
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    @texasrho83 What is the UPC/Part Number on the one you received? There are a bunch on Ebay, not sure if there any different models.
    #87
  28. Mar 10, 2024 at 7:28 PM
    #88
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    #88
    kbahus[QUOTED] likes this.
  29. Mar 14, 2024 at 10:59 AM
    #89
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Did the D7 work? Standing by to order one now.
  30. Mar 15, 2024 at 6:06 AM
    #90
    pablo89
    pablo89 New Member
    pablo
    Miami
    2018 tundra platnium
    Rollnlock amp steps fuel wheels nitto ridge led lights
    this is crazy that Toyota knows about this issue since way back and they are just letting us suffer with this. been having same issue since 30k miles been to the dealer 5 times and no solution ordered the computer yesterday.how often are you guys resetting ?
