Engine stutter or stalling when putting in park
Discussion in '3rd Gen Tundras (2022+)' started by molson7, May 10, 2022.
  1. Oct 17, 2023 at 1:17 PM
    Breathing Borla
    AZ
    this ^.
    turn that shit off, problems solved, its on my pre-flight checklist every start
    Mattedfred likes this.
  2. Nov 5, 2023 at 8:21 PM
    emale33
    emale33 New Member
    eric
    My truck always shuts off just when I put it into park. Then, once it is shut down in park, it turns back on just in time for me to have to shut it off a second time. This is so annoying. I am not pressing hard on the brake when I shift it into park and the location of the button that stops this is in an inconvenient location. Toyota needs to put the auto start\stop button on the steering wheel.
    kirkb and PNW Tundra Mike like this.
  3. Nov 5, 2023 at 9:26 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    *Update-Reported this at my 5K maint visit and the Serv Writer said he never heard of it (could be, was a young green guy). I still believe it’s a software issue I hope will be fixed. I refuse to disable S/S every time I start the truck so my work around is when I come to a stop and am ready to Park, I shift to Neutral for just a couple seconds and then to Park. The truck never shuts off, stumbles, or dies and restarts. After doing this a dozen times it just becomes natural muscle memory and you don’t even think about it.
  4. Nov 5, 2023 at 10:50 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I have same issue - when shifting to park, the auto start stop feature on the truck will shut off briefly and then start again.
    Most of the times I can make it not do that if I keep my foot on the break pedal when shifting to neutral, then hitting the parking brake button, then shifting to park slowly and slowly releasing brake pedal. This is my usual custom before shutting off truck.
  5. Nov 6, 2023 at 5:14 AM
    Leatherhead237
    Leatherhead237 New Member
    Massachusetts
    2023 1794 TRD Off-Road
    This is 100% related to stop/start.
    For whatever reason, the logic for stop/start disables it when the seatbelt is not clipped in so what is happening is the truck sees you put it in park, shuts down the engine for stop/start, and then restarts the engine (or you get the stumble if you do it quickly) when you unbuckle to leave the truck.
    The only way to keep this from happening is to disable stop/start during your trip, unbuckle your seatbelt before shifting to park, or park-shut truck off with the button-then unbuckle.
    Matt2015Tundra and Mattedfred like this.
  6. Nov 6, 2023 at 5:35 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
  7. Nov 6, 2023 at 11:11 AM
    Jixer77
    Jixer77 New Member
    2023 Ice Cap Tundra
    Are installation instructions included?
  8. Nov 6, 2023 at 11:17 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Clean your mass air flow sensors…
  9. Nov 6, 2023 at 1:48 PM
    PNW Tundra Mike
    Back in So Cal
    My truck was doing this with 5 miles on the clock
  10. Nov 6, 2023 at 1:49 PM
    PNW Tundra Mike
    Back in So Cal
  11. Nov 6, 2023 at 2:28 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    Check my pervious post. I have pictures
  12. Nov 6, 2023 at 2:52 PM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    This doesn't truly disable S/S. It just shuts it off once the engine starts. You can still press the button and turn it back on. It's really just defaulting S/S to off, but otherwise works the same.
  13. Nov 6, 2023 at 3:31 PM
    Black widow TRD
    Manuel
    After cleaning the mass air flow sensors? My Tundy was doing it also, great service by my dealership. I was fixing to go on vacation, on my to my destination my Tundy started acting up. I gave my guys ring at the dealership l, explained my conundrum and he said bring it in immediately.
    I got there and the master tech was waiting for me. I took it to the back, spent like an hour with it. Fixed the issue.
    He stated he cleaned the mass air sensors. My truck was running bad. ( disclaimer) I was servicing my truck prior to my departure. New oil, cleaned the TRD air filters. I was waiting for air filters to dry, so I used the old filters, which were severely dirty, I left em laying around when they we’re remodeling my house and the filters must got fine dust from sheet rock on them.
    Anyways kiddos my guys at the dealership, outstanding service, saved my vacation!
  14. Nov 6, 2023 at 11:32 PM
    PNW Tundra Mike
    Back in So Cal
    Wow, I like that feature/mode a lot more. I’ll check into it. Thanks!!
  15. Nov 7, 2023 at 4:03 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    The device just remembers the last setting. If you set the A s/s to off, the last time you drove then it will be off when you start your vehicle next time. The "Car care nut" on YT has a great explanation of the smart A s/s. The feature is designed to reduce emissions. Not increase fuel economy. And the starter has a factory programmed number of starts its allowed to do. Then it disables itself and you need to buy a new one. It could take ten years before you reach the set number. Your mileage may vary:)
  16. Mar 7, 2024 at 12:00 AM
    arosas85
    arosas85 New Member
    Andrew
    2022 Tundra Limited
    I turn off the stop/start feature every time I get in my truck and there are still times that at a stop light the revs go down and feels like it's about to stall and picks back up to normal idle. I was also pulling up to a light a couple months ago and as I was coming to a complete stop my truck bucked so hard i really thought i had gotten rear ended, until i didnt see a car behind me...
