LED Tail Light Swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Jun 14, 2022.
  1. Aug 17, 2022 at 6:51 AM
    #61
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
  2. Aug 19, 2022 at 8:47 AM
    #62
    jonjc23
    jonjc23 New Member
    Jon
    Pittsburgh, PA
    2015 Tundra Limted White CM
    Just installed the Hotshot tail light conversion and love it! Looking at headlights next.
    Taco-Spike likes this.
  3. Aug 19, 2022 at 8:55 AM
    #63
    Taco-Spike
    Two Trucks
    Which option you go with and what headlights? Just curious.
  4. Aug 19, 2022 at 8:59 AM
    #64
    jonjc23
    jonjc23 New Member
    Jon
    Pittsburgh, PA
    Haven't changed out the OEM headlights yet, but I'm starting to research them.
    Taco-Spike[QUOTED] likes this.
  5. Feb 25, 2024 at 2:45 PM
    #65
    WestKY_Tundra
    WestKY_Tundra Dont let your meatloaf
    Randall
    West KY
    2016 Metallic Grey SR5
    2018 OEM Headlights with @ihacker's wiring harness, Blacked out LED tail lights, A.R.E. color matched camper shell.
    Please dont kill me for asking rookie questions, but I have never had a newer truck and I am new to the LED game lol
    I ordered these the other day off of Ebay. I want to swap out the regular bulbs for LED's but I am lost in the sauce as to what I will need. Again, Im new to LED lighting so can someone point me in the right direction on if I will need resistors or any special harness? Just whatever I will need so they work right and doesn't hyperflash.
    Also, what are some good LED's that wont break the bank. Are the Sylvania ones any good?
    Thanks in advance!!
    #65
  6. Feb 25, 2024 at 2:51 PM
    #66
    eagleguy
    eagleguy [OP] New Member
    The lights should need nothing extra for install but they will affect your radio reception. My signal stinks and the dealer stated it was because I swapped out the lights. To check I put the old ones back in and everything was fine. Liked the lights so I am living with it.
  7. Feb 25, 2024 at 2:54 PM
    #67
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've never heard of that before...
  8. Feb 25, 2024 at 3:05 PM
    #68
    Same here.
  9. Feb 25, 2024 at 3:07 PM
    #69
    WestKY_Tundra
    Randall
    West KY
    Really? Thats wild! Thats not a dealbreaker for me though because i rarely listen to the radio. Usually XM or just music from my phone.
  10. Feb 25, 2024 at 3:23 PM
    #70
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    #70
  11. Feb 25, 2024 at 3:29 PM
    #71
    WestKY_Tundra
    Randall
    West KY
    As far as I know it will connect right to the OEM sockets. I haven't received them yet, they should be in tuesday or wednesday. I was just wondering if there was anything else I need to get to prevent the blinker hyperflash because I plan on swapping out the original bulbs to LEDs.
    #71
  12. Feb 25, 2024 at 4:10 PM
    #72
    1lowlife
    DADA
    2014 MGM DC SR5
    Upon looking at those plugs, they probably just plug into where the bulbs plug in now.
    Some aftermarket tail lights still use a bulb for reverse, but these don't seem to be that way.
    It doesn't say anything about internal resistors, you'll just have to install them and see if they hyperflash.
    If they do, VLEDs make some nice resistors.
    You can mount them behind the tail lights.
    g0uw0iy9_cb97e2ca21c32f29848c5903dea93b9505ce7a8c.jpgwnmu2z5a_cbfd61148927f48fe11b9e53938f0477943ae036.jpg
    Just for rears.
    2 LED TURN SIGNAL HYPERFLASH FIX (vleds.com)
    You might consider getting this one if you have any intention of putting LED turn signal in front and rear.
    4 LED TURN SIGNAL HYPERFLASH FIX (vleds.com)
    Good luck
  13. Feb 25, 2024 at 4:27 PM
    #73
    WestKY_Tundra
    Randall
    West KY
    Man, thank you so much!! I ordered some 2018 OEM headlights with the LED DRL's to upgrade the front of the truck as well so I will be getting the 4 LED Turn signal hyperflash fix.
    For the front of the truck I was going to order the OEM headlight conversion kit from headlight revolution which i put a link for. Do you know if VLEDs has the same thing? If so ill just do one big order from them.
    Apologies for another dumb question Im about to ask but im assuming I will be putting a resistor behind each light on the front and back?
    https://www.headlightrevolution.com...conversion-2009-2018-H-TUNDRALED_2?quantity=1
  14. Feb 25, 2024 at 8:23 PM
    #74
    1lowlife
    DADA
    2014 MGM DC SR5
    This will cover 4 LED turn signal bulbs.
    There are 2 and you mount them behind the tail light.
    That will cover the fronts as well.
    I haven't had much luck with anything Headlight Revolution makes.
    I can't recommend them.
    Did you purchase 2018+ OEM LED headlights?
    I did and used an @iHacker harness.
    I also added an LED bulb for the turn signal DRL.
    All the info is in this link.
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0] | Toyota Tundra Forum (tundras.com)
    From this..
    94B1C49A-A66D-4F31-99DA-6BD45F492426_zps_1880508731d819dfee9b9f1441c35f1a10921424.jpg
    To this.
  15. Feb 25, 2024 at 8:41 PM
    #75
    WestKY_Tundra
    Randall
    West KY
    Damn dude, that truck is bad ass!!!
    Yes, I ordered the 2018+ OEM headlights https://www.ebay.com/itm/264573407607
    Thanks for answering my question about the VLED stuff as well.
    I will order the harness from @iHacker tonight.
    What LED bulb is that for your blinker and what LED's did you use for your headlights?
    #75
  16. Feb 25, 2024 at 9:38 PM
    #76
    1lowlife
    DADA
    2014 MGM DC SR5
    Those headlights don't have replaceable lo/hi beam 'bulbs'.
    They are part of the headlight.
    I used these LED bulbs for the front turn signal/DRL.
    Amazon.com: iBrightstar Newest 9-30V Super Bright Low Power 7443 7440 T20 LED Bulbs with Projector Replacement for Front Rear Turn Signal Lights, Amber Yellow : Everything Else
    You might as well, get an amber 194 LED bulb for the parking light for your new headlights..
    Amazon.com: BRISHINE 300LM Extremely Bright Canbus Error Free 194 168 2825 192 W5W T10 LED Bulbs Amber Yellow 9-SMD 2835 LED Chipsets for Side Marker Turn Signal Blinker Map Door Parking Lights (Pack of 4) : Automotive
    #76
  17. Feb 25, 2024 at 10:29 PM
    #77
    WestKY_Tundra
    Randall
    West KY
  18. Mar 1, 2024 at 9:51 PM
    #78
    WestKY_Tundra
    Randall
    West KY
    So I got those tail lights in and that connection that is the 2nd connection in that picture is for a resistor that came with it. I havent been able to install them yet with work but I was planning on doing it tomorrow.
    I got the VLEDs 4 bulb resistors in as well. Obviously those are better than the cheap little gold resistors they sent with the tail lights. Should I just use the VLEDs on the back or save them for the front if I need them for the headlights and if so, will that mess with the ones on the back?
    #78
  19. Mar 2, 2024 at 8:58 AM
    #79
    1lowlife
    DADA
    2014 MGM DC SR5
    The 4-bulb VLD resistor you will mount behind the tail light will cover the front and rear.
    One on each side.
    No need to put additional resistors on the front, it is the same circuit.
    All the resistors do is make the truck think it has incandescent bulbs in place.
    Hyperflash is caused by the flasher module detecting there is a burned-out incandescent bulb in the circuit.
    A burned out bulb changes the resistance in the circuit, and causes the hyperflash to let the driver know there is a burned out bulb..
    The resistors provide the 'resistance' with the LED bulbs to trick the flasher module.
    Not very technical but it's the best I can do.
    A few years after installing mine one side started to hyperflash.
    Come to find out there was simply a bad connection on the resistor.
    I fixed it and everything was fine again.
    Make sure you get a good connection with your resistor wire taps.
    The OEM wiring is so small you need to make sure it gets a good connection.
    Good luck..
  20. Mar 2, 2024 at 1:54 PM
    #80
    WestKY_Tundra
    Randall
    West KY
    Got ya, thanks again for the help!
    By the way, did you replace your whole front bumper or just get end caps to make it all black?
  21. Mar 2, 2024 at 2:31 PM
    #81
    1lowlife
    DADA
    2014 MGM DC SR5
    I just put those on last weekend.
    They are black TPO Bumpershellz they kinda match the center black OEM bumper parts.
    They are covers to go over your chrome bumper ends.
    Easy to install as well.
    @EC1 hooked me up.
    He also has them in paint to match body color, the price of the black TPO is hard to beat.
    If you order you need to designate if you have parking sensors or not..
    2014-2021 Tundra BumperShellz: DIY Chrome Delete Front Bumper Overlays – ChromeStoppers
    2014-2021 Tundra Rear Bumper Overlays - BumperShellz – ChromeStoppers
    With my 10-year-old truck, I applied some Adams VRT to the OEM plastic centerpieces and the TPO matches very well.
    Amazon.com: Adam's Silica Infused VRT Combo Vinyl, Rubber, Tire & Trim Dressing - Durable UV Protection and Water Repellent - Leaves a Crisp Freshly Detailed Look - Dress Tires or Trim Without Worry of Slinging : Automotive
    EC1 likes this.
  22. Mar 9, 2024 at 11:35 PM
    #82
    WestKY_Tundra
    Randall
    West KY
    Got my headlights, tail lights, the harness from @iHacker, LEDs and VLED resistors in and got it all installed and they gave my truck a whole new look!!
    Bumpershellz for the front and back are ordered and now Im moving on to the grill. I ordered the OEM hood bulge to color match and now I am hung up on the grill. Im thinking about getting a 2018+ TRD Pro Grille and I am finding mixed answers about it fitting my truck. The website in the pic below says it doesnt fit but is that because the 2016 doesnt have the TSS and thats why theyre saying it doesn't fit? If thats the case then obviously that's not an issue, I just cant find anything definite on whether it will physically fit my truck. It looks identical in overall size and holy shit, why is that garnish the same price as the grille? I found one on ebay for 17 bucks and it will just be to fill the square hole in the grill and I wont need it for what the garnish is actually intended for with that sensor.
    #82
  23. Mar 10, 2024 at 9:04 AM
    #83
    1lowlife
    DADA
    2014 MGM DC SR5
    Glad you got it all installed.
    Yes them saying a grille wouldn't fit your 2016 is because of the TSS stuff.
    You'd be better off finding an old-style MGM TRD grille without the TSS stuff..
    53100-0C260-B1 - TRD Pro Grille - 1G3 Magnetic Gray - 2016 Toyota Tundra | Sparks Parts
    Do your research and see who has the cheapest shipping cost.
    Code - TUNDRAS.COM at Sparks gives some kind of discount, I can't remember if it is off the shipping or parts.
    #83
  24. Mar 10, 2024 at 7:11 PM
    #84
    WestKY_Tundra
    Randall
    West KY
    Got ya, Ill hit up Sparks and see what they got!
    Thanks man!!
    1lowlife[QUOTED] likes this.
  25. Mar 15, 2024 at 3:49 PM
    #85
    Marauder8708
    Marauder8708 New Member
    Central NY
    2014 Grey Tundra CrewMax
    Headlights, tail lights, wheels, towing equipment.
    I bought these and put them on my 2014. Very happy with them. There is the slightest gap at the top of the light. Overall very impressed for the proce
    DallasTundra[QUOTED] likes this.
