S.o.b fabrication “High clearance rear bumper”
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Apr 19, 2022.
  1. Feb 29, 2024 at 5:20 PM
    #121
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    What did you do with BSM? Just unplug the sensors and turn it off on the dash?
    AZBoatHauler[QUOTED] likes this.
  2. Feb 29, 2024 at 5:23 PM
    #122
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Same
  3. Feb 29, 2024 at 6:11 PM
    #123
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    You can turn the bsm off and leave the sensors out. The only thing to be sure to do is tape up the plugs really well to avoid moisture and corrosion. @n0rth had some funky ECU fuses blow due to those plugs shorting out.
  4. Feb 29, 2024 at 6:14 PM
    #124
    STravis
    Travis
    Ruidoso, NM
    I say do it!
    Full disclosure, I am the guy that builds them so I would benefit too haha, but I think it's a great idea for both of you.
  5. Feb 29, 2024 at 6:19 PM
    #125
    AZBoatHauler
    So.Arizona
    Yes. Taped up the plugs on the harness really well.
    TRDFerguson and STravis like this.
  6. Feb 29, 2024 at 6:23 PM
    #126
    AZBoatHauler
    So.Arizona
    Pair of moose knuckles to finish it off.
  7. Feb 29, 2024 at 6:48 PM
    #127
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Thanks for the info. I have an Expedition One rear bumper on the way, so I am in the same boat for the BSM sensors
    If you want a truly weather proof solution you can order the connector body and plugs below. This will be the same as everything being hooked like it was from factory in terms of weather resistance.
    https://www.corsa-technic.com/item.php?item_id=1003
    https://www.corsa-technic.com/item.php?item_id=1055
  8. Feb 29, 2024 at 8:26 PM
    #128
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Then I’d have to road trip to NM too…
    :monocle:
  9. Feb 29, 2024 at 8:27 PM
    #129
    RainMan_PNW
    Casey
    Clark County, WA
    No way to work a spot for the sensors into the design?
  10. Feb 29, 2024 at 9:09 PM
    #130
    STravis
    Travis
    Ruidoso, NM
    We have some great local camping that you could take advantage of if you do come.
    Not really unfortunately, the profile of the bumper doesn't really leave anywhere to stick them.
  11. Feb 29, 2024 at 9:19 PM
    #131
    RainMan_PNW
    Casey
    Clark County, WA
    I’d be tempted to just pull the parking sonar too. At that point the entire factory bumper harness isn’t needed except for license plate illumination… I wouldn’t miss the sonar, but BSM would take a little to get used to again.
    STravis[QUOTED] and FrenchToasty like this.
  12. Feb 29, 2024 at 9:19 PM
    #132
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Surface mount it!!
  13. Feb 29, 2024 at 9:20 PM
    #133
    RainMan_PNW
    Casey
    Clark County, WA
    Or sell it with the bumper…
  14. Feb 29, 2024 at 9:21 PM
    #134
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    What’s the fun in that :D
    STravis and FrenchToasty like this.
  15. Feb 29, 2024 at 9:25 PM
    #135
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    And I’d be willing to bet you could make it work here if you got the tree protectors.
    At least my old sensors don’t seem to be super sensitive. I plugged them in and had them dangling facing out. Didn’t throw a “see dealer” message.
  16. Feb 29, 2024 at 9:31 PM
    #136
    With that bumper…… do you really need BSM?
  17. Feb 29, 2024 at 9:33 PM
    #137
    RainMan_PNW
    Casey
    Clark County, WA
    I was just thinking the same thing…
    Once I commit to that level of modification, I think I’m ok with no more sensors…
  18. Feb 29, 2024 at 9:35 PM
    #138
    RainMan_PNW
    Casey
    Clark County, WA
    On a 2020, the control for them is in the instrument cluster. If you unplug them they’ll simply deactivate. No errors or warnings at all.
    the parking sonar is a different story.
  19. Feb 29, 2024 at 9:36 PM
    #139
    Adam seemed content with just sonar. I wish I had sonar…. One day I’d like to get a rear camera on my backside……..
  20. Feb 29, 2024 at 9:38 PM
    #140
    AZBoatHauler
    So.Arizona
    I can’t express how excited I am to see what trouble I can get into now.
  21. Feb 29, 2024 at 9:39 PM
    #141
    AZBoatHauler
    So.Arizona
    I keep that shit off almost all the time - but had to fill the holes one way or another.
  22. Feb 29, 2024 at 9:40 PM
    #142
    You’ll be pleasantly surprised!!!
    BillyB, STravis and Mater like this.
  23. Feb 29, 2024 at 9:42 PM
    #143
    AZBoatHauler
    So.Arizona
    Might finally need a locker since I don’t have to worry about body damage.
    BillyB, n0rth, STravis and 2 others like this.
  24. Feb 29, 2024 at 9:45 PM
    #144
    I’m scared to use my locker and be too impressed and pissed why I didn’t do it sooner……..
  25. Feb 29, 2024 at 9:52 PM
    #145
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    Update on my order
  26. Mar 1, 2024 at 4:53 AM
    #146
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    I had one of the plugs get ice and salt driving back and forth to our local ski hill, and blew one of the ECU fuses. I ended up replacing the fuse and terminating the wires for that plug.
  27. Mar 11, 2024 at 1:26 PM
    #147
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Update: I finished up the hard part of cutting up the bed side.. at least I think. I just picked up the bumper and prepping it for Steel-it.
  28. Mar 11, 2024 at 1:27 PM
    #148
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Nice work!!!
    Love the green/bronze combo.
  29. Mar 12, 2024 at 8:19 AM
    #149
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    That's looking great. I will have to keep my eye out for you roaming the streets of WNY this year. :thumbsup:
    STravis and FiveO Enduro[QUOTED] like this.
  30. Mar 12, 2024 at 7:22 PM
    #150
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    How much do the front bumper and rear bumper weight?
    STravis likes this.
