3D Printable Tundra Model
Discussion in '2.5 Gen Tundras (2014-2021)' started by THORYOTA, Apr 19, 2022.
  1. Feb 12, 2024 at 12:56 PM
    #91
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Don't forget the TRD Pro bed stamps :D
  2. Feb 12, 2024 at 1:16 PM
    #92
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I'm new to 3d printing but id be happy to test it out when ready. Id love to make something that would fit my axial scx24. Don't get me wrong, the c10 body on it looks great but if i could make something match the tundra that would be awesome.... I'd just have to figure out how to model some nfab podium step bars and my roof top tent setup. i know there are tons of roof top tent models to print...
    THORYOTA[OP] likes this.
  3. Feb 13, 2024 at 11:18 AM
    #93
    THORYOTA
    THORYOTA [OP] God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    There will be a pro version. Maybe @Tundra234 would make us some mini TRD decals also.
  4. Feb 13, 2024 at 11:19 AM
    #94
    THORYOTA
    Thor
    Asgard
  5. Feb 13, 2024 at 11:46 AM
    #95
    Tripleconpanna
    :fistbump:
    BTW.... that's looking awesome :muscleflexing:
    Can we get the Pro version w/295s??? that is if they'll fit on a stock Pro suspension ;)
    PS>>> Great work!!!!
    THORYOTA[QUOTED][OP] likes this.
  6. Feb 14, 2024 at 10:29 AM
    #96
    THORYOTA
    Thor
    Asgard
    Not so elegant door hinge solution:
    reneaux likes this.
  7. Feb 20, 2024 at 5:42 AM
    #97
    THORYOTA
    Thor
    Asgard
  8. Feb 20, 2024 at 6:23 AM
    #98
    THORYOTA
    Thor
    Asgard
  9. Feb 20, 2024 at 8:36 AM
    #99
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I need it
    Tripleconpanna likes this.
  10. Feb 20, 2024 at 11:00 AM
    #100
    THORYOTA
    Thor
    Asgard
    Boys, I'd estimate we're about 90% done with the modeling. Working on smoothing out the surfaces and making sure everything fits and is able to be printed. I'd say we'll be ready to test print some pieces next week sometime.
    The Dude, centex, C.I. and 4 others like this.
  11. Feb 20, 2024 at 12:33 PM
    #101
    Tripleconpanna
    :yes:
  12. Feb 21, 2024 at 5:47 AM
    #102
    RyCo85
    RyCo85 TOYOTA - The One You Ought To Admire
    Ohio
    2015 Black Tundra SR5
    Slowly making her look like a 2020
    Looks amazing!! May have to start with a metallic black PLA and see how she looks. You are doing an amazing job, keep up the great work!
  13. Feb 26, 2024 at 9:53 AM
    #103
    THORYOTA
    Thor
    Asgard
    Not sure how these will turn out, but we'll see. Tread pattern is modeled after Wildpeak AT3s and ratios are from 295/70/r18
  14. Feb 26, 2024 at 10:11 AM
    #104
    THORYOTA
    Thor
    Asgard
    Wheel is a separate piece that slides into the tire and on to the Axel.
    As far as the axels go, I've been thinking about trying some 5 mm carbon fiber rods like used in rc planes, but wood or metal could work too.
    Reddawg1100, Tripleconpanna and chugs like this.
  15. Feb 26, 2024 at 10:23 AM
    #105
    18" TRD Off Road Wheels
    Amazing work, but I gotta ask; what's up with this part of the fender?
  16. Feb 26, 2024 at 11:22 AM
    #106
    THORYOTA
    Thor
    Asgard
    I'm still trying to get that right. The hood and fenders have some crazy curves that have led to me remodeling each of them about 4 times.
    These are the 30 sketches for the hood, not including the ones for the scoop and bulge.
  17. Feb 29, 2024 at 8:39 AM
    #107
    THORYOTA
    Thor
    Asgard
  18. Feb 29, 2024 at 8:55 AM
    #108
    I see alot of interests in people wanting to buy one of these.
  19. Feb 29, 2024 at 10:14 AM
    #109
    Tripleconpanna
    Did you put wheel spacers on that thing?? The 'poke' seems a bit off on the head on shot and the last photo depicting the rear tire/fender relation as well; maybe dial the tire size back just a little :notsure:
  20. Feb 29, 2024 at 10:34 AM
    #110
    THORYOTA
    Thor
    Asgard
    Decided to mess around with "lifting" this bad boy. I'm working in 1:24 scale and since 1 inch = 25.4mm, for our purposes 1mm is almost equivalent to one inch.
    Here's the base height:
    Here's a 2.5mm"
    And here's what 6mm would look like:
  21. Feb 29, 2024 at 10:54 AM
    #111
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Wow, awesome job. I've wanted to get into 3D modeling, however it is an investment. Kudos! I'd love to know what applicatio(s) you've been using and your general thoughts on each.
    Also, if you need some test printers, I am happy to volunteer.
  22. Feb 29, 2024 at 11:21 AM
    #112
    With the current tires, I vote that the 2.5 looks the best. :thumbsup:
  23. Mar 1, 2024 at 5:12 AM
    #113
    THORYOTA
    Thor
    Asgard
    Good call. I was working with the frame that everything was based and the proportions of the tire/wheel while still giving myself a flat surface for printing. So without having to change everything I made some cutouts in the frame so the tires could still be somewhat proportional, tucked-in, and not forcing me to re-model each of the components.
    I'll have both versions available to download and one could use some 5mm washers as "wheel-spacers"
  24. Mar 1, 2024 at 8:15 AM
    #114
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    I agree, the 2.5 looks best with that tire setup.........:101010:
  25. Mar 2, 2024 at 4:19 PM
    #115
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    i want in. will it print on an ender 3?
  26. Mar 4, 2024 at 7:50 AM
    #116
    THORYOTA
    Thor
    Asgard
    News and Notes:
    • V 1.0 Modeling 99.9% is complete! I'm currently going over each component for "printability" and packaging each piece for testing.
    • Click here to take a brief survey if you are interested in helping test print. More info on that to come. We'll set up a group chat on GroupMe to chronicle our progress.
    • For those interested in utilizing this for your RC car, sorry but V1.0 likely won't be of use. The original intent was to create a printable model, not something that can be used and abused. That will likely come in v2.0.
    • Rear Doors will not open and close. I cant make it work without remodeling the entire cab and the front doors. As we test print if someone can figure it out, we'll go from there.
    • Other items needed to complete the model:
    1. Axel Rod
    2. Door Hinge rod
    3. Hood Rod
    4. Tailgate Rod
    5. Tailgate Magnets
    6. Door Magnets
    • Looming Questions/Concerns:
    1. Push-Fit Connections
    2. Filament
    3. Layer Height/Infill/Print Settings
    4. Viable Scales to print in
  27. Mar 4, 2024 at 9:53 AM
    #117
    THORYOTA
    Thor
    Asgard
    For most people, a full model will only be able to print in 1:24 and 1:18, as the frame length is the limiting factor due to bed size. upload_2024-3-4_12-52-28.png
    DannyD303 likes this.
  28. Mar 4, 2024 at 12:40 PM
    #118
    fisherman951
    Tony
    2017 crewmax 4x4
    Hi wonder if any one has like a commercial grade 3d printer
  29. Mar 5, 2024 at 3:28 AM
    #119
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    OK Fellers... I also belong to a BBQ Forums and there is a feller on there that is building a 3d printer with his other 3d printer.. I asked him to come look at this thread and to see if he had any input... He said he also built a 4runner body for his RC car but didn't like it... This is one of the reasons he's building a new printer... If anybody's interested in his build... Or might be able to gain some input... Here's a link to the thread... He say's that y'all are trying to make the frame to big witht the printer you have... To make it 2 pieces and glue it together... But anyways... here's the link...
    https://www.smokingmeatforums.com/threads/building-a-3d-printer-with-my-3d-printer.325690/
  30. Mar 5, 2024 at 5:11 AM
    #120
    THORYOTA
    Thor
    Asgard
