Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Nov 21, 2023 at 2:17 PM
    #391
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Up to 295s will fit on stock wheels. 34 would be 295/60 on 20, and 295/70 on 18.
    Goobax[QUOTED] likes this.
  2. Nov 21, 2023 at 2:40 PM
    #392
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    thanks, this is the calculator I was using so my understanding may be slight off on the right description of size
  3. Nov 21, 2023 at 3:07 PM
    #393
    rruff
    rruff New Member
    Yah, those are 34s too... but I think you'll like the look of the wider tire.
  4. Nov 23, 2023 at 1:32 AM
    #394
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    I don't buy all these guys saying they're running 275/70/R18's on stock Tundras with no rubbing.
    I just had Les Schwab Open Range AT Plus 275/70/R18's installed on my 2019 Double Cab last Friday and they rub hard at full lock, especially in reverse. Stock rims with a front leveling kit. Not sure what they're hitting, but hope to sort it out tomorrow.
  5. Nov 23, 2023 at 8:09 AM
    #395
    rruff
    rruff New Member
    Did you align it yet?
    Trouble shooting is pretty easy if you know where it's hitting.
  6. Nov 23, 2023 at 8:37 AM
    #396
    coTony
    Tony
    Montrose, CO
    Any tire that will fit in the opening
  7. Nov 24, 2023 at 11:28 AM
    #397
    Buster1
    Buster1 New Member
    Oregon
    They were hitting the skid plate. A little tweaking with some vice-grips solved the problem.
    FREEK and rruff[QUOTED] like this.
  8. Nov 24, 2023 at 4:28 PM
    #398
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    See, that's how we fit them
    FREEK and rruff like this.
  9. Nov 24, 2023 at 4:46 PM
    #399
    rruff
    rruff New Member
    Tweaking the "skid plate" (ie sheet metal cover) is kinda like taking the mudflaps off... it's too easy to count as "making clearance". Still I'm surprised that 33s rubbed.
  10. Nov 25, 2023 at 7:19 AM
    #400
    BillyB
    BillyB New Member
    Billy
    AZ
    Yeah, I'm surprised he had rubbing there with skinny 33's also.
    rruff[QUOTED] and coTony like this.
  11. Dec 21, 2023 at 5:35 PM
    #401
    mpd13078
    mpd13078 New Member
    Alabama
    2017 Platinum Crewmax 4WD 5.7L
    Stock
    Purchased Nitto Ridge Grappler (16/32 tread depth) LT275/65/R20 in 4/2021 (factory size P275/55/R20), leaves 1/2” clearance between sidewall and UCA. As of today, 12/2023 & 26,857 miles later with consistent rotation/balance, 8/32 tread depth & all around even wear. Pics just off the lift. Doesn’t really leave pavement & no towing yet.
  12. Jan 27, 2024 at 5:17 PM
    #402
    66Platinum
    66Platinum New Member
    Angel
    Salinas Valley CA
    20 Platinum MGM
    you sure you purchased 275/65s your photos show 275/60?
  13. Jan 30, 2024 at 10:33 AM
    #403
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    I recently got some 295/70r18's and am wondering if the full size spare will fit up under the bed. Anyone tried it? any modifications I need to do to make it fit?
  14. Jan 30, 2024 at 11:00 AM
    #404
    rruff
    rruff New Member
    I have one of those on the stock rim with stock springs and shackles. I think I had to take a sledge hammer to the tabs that hang down to bend them out a little. It's a "big" 295/70r18 also... STMaxx.
  15. Jan 30, 2024 at 11:06 AM
    #405
    KSTNTUNDA
    KSTNTUNDA New Member
    Nashville
    2020 LIMITED TRD OFF ROAD
    I've run Micky Thompson Baja Boss AT's in 275/70 18 for 50K miles with no rubbing issues. Stock wheels and suspension
  16. Jan 30, 2024 at 11:56 AM
    #406
    831mic
    California
    '16 DC TRD PRO
    Noted, thanks dude. I'll see what kind of trouble I can get into while under the truck later today.
  17. Feb 28, 2024 at 9:55 AM
    #407
    6rian
    6rian New Member
    3rd gen with 37x12.50 KO2s with the red Bilsteins. Required some plastic trimming and the common frame/liner modifications to make it "streetable" with some rubbing (not recommended). Just experimenting before swapping out the suspension.
  18. Mar 10, 2024 at 6:56 PM
    #408
    aznracer305
    aznracer305 New Member
    2010 Custom Blue Crewmax
    I’m currently on 275/55/20 20x9 offset 0 with 1.5” wheels spacers to gives it a little poke. Tires rubbing on body mount at full lock. I want to run bigger tires therefore if I remove the wheels spacers can I run 275/65/20 or 295/60/20? Needs to buy tires asap as these cooper are getting bad. Thanks
  19. May 16, 2024 at 2:49 PM
    #409
    sweatypowderpig
    sweatypowderpig New Member
    sierra nevada
    2019 Cement Limited DC TRD Off Road
    Looking for advice.
    2019 Tundra DC with off-road package, but suspension is stock beyond that. I don't anticipate any upgrades there in the near future, unfortunately.
    Stock summer tires are finally dying, so it's time for new rims/tires. stock TRD 18s will become full-time rims for winter tires.
    I've had my eye on the 17" method 701s and nitto ridge grapplers since I bought the truck. I'm already on the schedule for a BMC. RCI skid plate is installed currently.
    I don't want to go too crazy with width and diameter. I'm a function over aesthetic guy. Prefer to largely maintain fuel economy and speedometer accuracy. What size do y'all think I should go with?
    Mostly pavement, but some off-roading at least once a week to get to trailheads and such for mtn biking, hunting and backcountry skiing.
  20. Jul 24, 2024 at 12:06 PM
    #410
    xbunnbla
    xbunnbla New Member
    I was looking for the largest tire size for my 2024 trd pro tundra? I have heard so many people say different things, imagine that. Any pics would be helpful.
    drewpweinerMD and Flynn47 like this.
  21. Aug 2, 2024 at 11:51 AM
    #411
    Flynn47
    Flynn47 New Member
    Flynn
    2024 Lunar Rock Platinum Tundra Hybrid
    TRD Off-Road & TRD 3" Lift
    Had 285/65 R20's put on yesterday. 3" factory lift and wheels. Rubbing on the sway bar. What's best way to fix this?
  22. Aug 2, 2024 at 12:00 PM
    #412
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    '23 Turd Pro, stock. 295x70x18 cooper at3 xlt.
  23. Aug 24, 2024 at 2:32 PM
    #413
    dbrownii
    dbrownii New Member
    IMG_2007.jpg IMG_2004.jpg PSA for anyone here…
    2020 SR5 4x4 with TSS Off Road “Texas Edition” - whatever BS you wanna call it. Stock was 20in wheels and 275/55/20 DuraTrac - no added lift.
    Today I swapped for BFG All-Terrain TA K02 and went with the taller 275/60/20. Notice the clearance. Decent difference in filling out the wheel wells too - gains about an inch in height. Hope this helps one of yall.
    PermaFrost likes this.
  24. Nov 14, 2024 at 9:00 PM
    #414
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    A lot of pages that I haven't seen yet, but was looking for the 3rd gen of 2022 and up sizes.
  25. Nov 14, 2024 at 9:15 PM
    #415
    JohnWhicker
    JohnWhicker New Member
    Why didn't you go with the KO3's ?
  26. Nov 22, 2024 at 6:01 PM
    #416
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Can confirm 285/60r20 BFG KO3 fit a bone stock 2025 Tundra limited. OEM wheels and no spacers needed. It has about 1” of clearance to the control arms and full range forward and backwards. Super stoked with both the tires and look.
    drewpweinerMD and mrlittlejohn like this.
  27. Nov 23, 2024 at 4:18 AM
    #417
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I think I've just made a mistake. I bought these aftermarket wheels. 18x8 stock +60 BS. I’ve just ordered new Toyo RT 285/75R18 tires. They are 34.8x11.3 height and tread width.
    Should I go to a +25 offset? I wanted to keep the tire inboard of fenders as best I could but probably miscalculated inside rub in the turns? What do you think? These are the wheels. Factory replica basically
  28. Nov 23, 2024 at 4:23 AM
    #418
    PermaFrostTRD
    Northern NY
    285’s on stock wheels (60mm offset) will be tight on the stock uca but shouldn’t rub.
    Lots of guys run that size and actually push the suspension without issue.
    edit:
    Depending on your skid plate you may have to trim it.
    Not sure on the OG 2nd gen’s if they have the front forward “mudflap” or not but the on the 2.5’s those usually have to be removed.
  29. Nov 23, 2024 at 4:57 AM
    #419
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Thanks for this info. I had planned on removing the tiny front flap. I don't have skid plate yet, I've looked and will create and
    build my own. My time will offset the giant cost of buying and importing into Canada now.
    I do know the rear plastic panel and mudflap on fronts might have to go. I'll look at cutting plastic away first, then if
    the flange weld of body panels needs to grind down, I'll do that too. I don't want to remove mud flap so will have to
    look at cheap flat aftermarket for that.
  30. Jan 9, 2025 at 9:35 AM
    #420
    brent.ff
    brent.ff New Member
    Without having to go through 81631 posts, curious what the max size i can fit on a 2024 SR5 TRD Offroad. Stock tires were 265/70/18. Dont do any hardcore offroading, but lots of gravel/forestry roads for fishing and will be carrying a camper so likely wanting C or E rated?
