87 octane or premium fuel
Discussion in 'Performance and Tuning' started by Tbag1118, May 13, 2022.
  1. Oct 26, 2023 at 11:56 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I just did a trip to my sons college 470 miles each way. I drove like I always do on the highway 65-85 mph with no regard to fuel milage. I got 19.8 on ride there using premium (93) octane, and I got 19.3 using (87) octane on way home. If it helps I think on way home I was driving a little faster. Either way I was happy with that milage. On the down side, last weekend I did the same trip in my wife’s V8 Armada and got 19.1 there and 18.9 on ride home.
    cmiles97 likes this.
  2. Oct 26, 2023 at 12:04 PM
    Big Sexy
    Big Sexy New Member
    Bret
    2023 Platinum Magnetic Grey Metallic
    None yet, just bought 9/30/23
    I know I'm going to be talking about a different truck here, but I'll add it anyway...
    My last truck was an '09 F150. I bought her a Hypertech tuner (great investment, BTW). Off the assembly line, the engine was tuned for 87 Octane. The Hypertech tuner had a mode to reflash the computer so it would be tuned for 93 octane.
    I haven't drilled too deeply into Hypertech options for my Tundra yet, especially considering my Tundra is 14 years younger than my F150 and no doubt the computer is far more advanced. But, if you want to run premium, I would suggest buying something to flash the computer to optimally use that fuel.
  3. Oct 26, 2023 at 12:05 PM
    Big Sexy
    Big Sexy New Member
    Bret
    Thanks for sharing this. This is a real-world test that I'll take at face value. I'd agree the difference does not justify the increase in cost.
  4. Oct 26, 2023 at 1:02 PM
    nodak67
    nodak67 New Member
    JR
    think you are doing the wrong comparison
    Annual Miles 12000
    Car #1
    Car #2
    Fuel Price ($/gal)
    2.92 / 3.42
    Fuel Economy (mpg)
    13 /17
    Annual Fuel Cost:
    2,695.38 / 2,414.12
    which comes out to roughly a 11.65% savings
    Savings: 281.26
    Savings after ...
    Year 3 843.78
    Year 5 1,406.30
    Year 7 1,968.82
    Reddawg1100 likes this.
  5. Oct 26, 2023 at 1:03 PM
    Big Sexy
    Big Sexy New Member
    Bret
    Do you have a hybrid?
  6. Oct 26, 2023 at 1:12 PM
    nodak67
    nodak67 New Member
    JR
    30% increase in mpg doesnt correlate into the same savings in money when you compare regular gas price vs premium gas price. you are not saving 30% in cost
  7. Oct 26, 2023 at 1:43 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    It’s not a hybrid. 22 Platinum
  8. Oct 26, 2023 at 2:11 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I run a nice mid grade 89ish fuel since you realize the ethanol content of 87 is higher than published and mid grade has a slight reduction in the amount of ethanol. While premium is ethanol free, I did not notice any difference in performance or mileage going to a mid grade 89 rated fuel. I ran premium till around 5k miles.
  9. Feb 28, 2024 at 8:07 AM
    usmc raid
    usmc raid New Member
    Anything high performance engine, specially turbo requires 93 fuel
    Common sense
    Any large engine requires 93 fuel as well
  10. Feb 28, 2024 at 8:33 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    All this chat about octane and no mention of TopTier vs non.
    Toyota recommends the 87 Octane TopTier or higher.
    Because TopTier matters.
  11. Feb 28, 2024 at 8:51 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I do what @ryanwgregg does. He puts in premium...so I put in premium. :cool:
  12. Feb 28, 2024 at 9:26 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    This exactly but with the Ford caveat that you don't get the full HP/TQ rating unless on 91 octane. Not sure what Toyota says on this.
    Using your truck as a car and not racing, 87 is the way to go.
  13. Feb 28, 2024 at 9:32 AM
    cmiles97
    cmiles97 New Member
    XP package
    Ethanol is not good for increased MPG because it contains less energy than gas but is great for Turbo motors.
    Ethanol also has a higher thermal efficiency meaning when it does ignite, the temperature of the combustion is lower compared to pump gas. This allows a turbocharged engine to take more boost within a safe operating range without damaging the engine.
  14. Feb 28, 2024 at 4:00 PM
    Breathing Borla
    Northern Illinois
    as it relates to knock sensor on 87? Like torque limit when not using 93?
  15. Feb 29, 2024 at 1:27 PM
    Racer57
    Racer57 New Member
    Octane is only for pre-ignition (spark knock) issues. It has zero effect for mileage or power.
    Larly5000 likes this.
  16. Mar 4, 2024 at 6:58 PM
    Voiko
    Voiko New Member
    It is very interesting discussion. I am not so much concerned about the mileage as for the longevity of the engine. Is higher octane when towing better for the the longevity of the turbo engine
  17. Mar 14, 2024 at 10:36 AM
    7Fid13
    7Fid13 New Member
    I just run 89 all the time! Some people say 87....some say 93. I just hit the button in the middle and never had an issue. It's worth the extra 30 cents per gallon to not be using the absolute minimum 87 in my mind.
  18. Mar 14, 2024 at 1:51 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    my 2 cents...there is a quote in here that 87 will get you 10-12 degrees of timing retard under a hard pull but 93 will reduce that to 0-2 degrees. Mileage difference will be minimal in most situations. I've found it's easier to pull hills with less throttle on 93 on the highway at 65-75 mph. Maybe 1 mpg more. When I romp it boost gauge will go to an indicated 16-17 psi on 93. 87 seems to max out at 15 psi FWIW. My truck is bone stock with drop in TRD air filters. Makes sense as that timing gives you a little more torque under load...probably not worth an extra buck a gallon for 95% of us. If you are trying to get a little more out of the truck with high flow filters, exhaust and especially any kind of tune the yep 93 is the key.
    Rcflyersd likes this.
  19. Apr 20, 2024 at 1:50 PM
    smileytn1
    smileytn1 New Member
    Try some moroso or 102 av fuel then see what mpg you get. Guys the computer and sensors are set and i've tried that too and it dosen't buy you anything My 2cents
  20. Apr 20, 2024 at 2:41 PM
    #50
    Markysharky
    Markysharky New Member
    Depending on the octane and ethanol. Fuel mileage will vary about +\-1 mpg. Not significant. Where I live it’s cheapest to run 88 octane (e15) because it’s about 40 cents cheaper per gallon.
  21. Apr 20, 2024 at 11:58 PM
    #51
    FleecingOilyRansomDealer
    FleecingOilyRansomDealer New Member
    2023 SR5
    According to the manual, the truck can take 87 and above, and a TopTier brand is recommended.
    https://www.toptiergas.com/fuel-stations/
  22. Apr 21, 2024 at 12:13 AM
    #52
    2023 SR5
    The manual says it's important that ethanol stays below 15% (E15 or lower). The tundra is not designed to use FlexFuel.
    Alcohol can react with and corrode Aluminum at high temperatures, and the engine is largely made of aluminum.
    This is a technical report discussing it (not by Toyota)
    https://www.diva-portal.org/smash/get/diva2:720728/FULLTEXT01.pdf
  23. Apr 21, 2024 at 5:05 AM
    #53
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    From: https://www.tundras.com/threads/what-grade-fuel-are-you-burning.15757/page-5#post-2398639
    One of our past members is a Shell engineer. This is what he said:
    "Hi, there is potentially more but more likely different detergents. It’s all about cost. My recommendation would be to buy and additive and not use the premium. You’re wasting your money as your engine is designed for regular. Premium is harder to combust, higher octane, harder to combust. When it does combust, bigger explosion=more power. That’s why avgas and stuff is 102-104 Octane, or somewhere around there. If you don’t want to buy and additive then the premium is ok but I wouldn’t do that too much. It’s extra strain on your engine and you may end up with more gunk on your cylinders since you can’t combust all of it. Feel free to post."
  24. Oct 12, 2024 at 7:48 PM
    #54
    Wymuley1
    Wymuley1 New Member
    Wyoming
    Black Tundra SR5 TRD with 3" factory lift
    My 2024 Tundra was idling/running rough lately (8000 miles).
    I decided to try premium gas (here at our altitude that is 91 octane).
    My engine run much smoother, idles smoother and I have gained 3 mpg on three tanks now.
    Jettster likes this.
