  1. Feb 27, 2024 at 2:03 PM
    Hope you bought a 5th one for a spare, that's some deal.
  2. Feb 27, 2024 at 2:12 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Replaced passenger side wiper arm. Very easy install.
  3. Feb 27, 2024 at 2:16 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    No pics??? :rofl::rofl:
  4. Feb 27, 2024 at 2:26 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    Hot damn that’s a deal.
  5. Feb 27, 2024 at 2:27 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Awesome! Congrats!
  6. Feb 27, 2024 at 3:19 PM
    RetiredTundra
    RetiredTundra New Member
    Gary
    2020 Limited TRD
    What a score on the wheels!
  7. Feb 27, 2024 at 3:19 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    What off set on your wheels? I want to run this size tire next.
  8. Feb 27, 2024 at 3:35 PM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    Can you post some pictures from the back, both sides? I want to see how much they stick out. :) Also, what tires did you get?
  9. Feb 27, 2024 at 3:47 PM
    mfelton18
    South Central Texas
    Give me till tomorrow for photos, the sun is already getting low where I am. Tires are General Grabber ATx 275/70 r18. I'd say they stick out maybe .75 of an inch or less. The factory side steps stick out farther just for an idea.
  10. Feb 27, 2024 at 3:47 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Battling a steering wheel shake after putting on used 285/70R17 K02’s and Icon wheels. I figured they just needed a rebalance and Discount Tire took care of that for me, but the shake is still there with no significant change. It was dead nuts smooth with the stock wheels and Cooper AT3’s. I wonder if I need some more toe in or if the tires are just bad.
    bulldog93 likes this.
  11. Feb 27, 2024 at 3:49 PM
    mfelton18
    South Central Texas
    Wheel out of round? I had a shake also but replaced my 100k front suspension and it went away.
  12. Feb 27, 2024 at 3:57 PM
    RobertD
    Robert
    DFW, Texas
    Did you change tire size? If so, I'd probably take it for an alignment. If the wheel offset changed and so did the size, I may have shifted things just enough.
    But it is possible a wheel is out of round, as mentioned above.
    Hope its easily resolved and you get back to a smooth ride.
  13. Feb 27, 2024 at 4:02 PM
    kbahus
    kbahus New Member
    MI
    I am going to try swapping one front wheel at a time to the back to rule out the tires. I assumed Discount would say something if a wheel was out of round or a tire wouldn’t balance. When I used to mount tires back in the day it was pretty obvious if there was a problem on the machine. I do hope it is an alignment issue as I am worried I got hosed on these tires. Trying to live that champagne lifestyle on a beer budget.
  14. Feb 27, 2024 at 4:25 PM
    Cthulhu
    CBI Offroad ditch light brackets and some old cheapo Nilights. Will upgrade if condensation ever happens or they just croak.
  15. Feb 27, 2024 at 4:34 PM
    Mitchell
    Mitchell New Member
    2020 Platinum Crewcab 4x4
    Just changed differentials, and transfer case fluids. Redline 75W-85, and 70W-75 in the transfer. And if my belly grows another 1/2", I will have to put her up on jackstands!
  16. Feb 27, 2024 at 4:36 PM
    ToyoMafia
    Magic carpet.
  17. Feb 27, 2024 at 4:47 PM
    BFG's are notorious for balancing issues.
    bulldog93 and Sierradevil like this.
  18. Feb 27, 2024 at 5:06 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Saw a thead in here where the wheels were not seated correctly. Take off your tires, hand tighten the lugs in a star pattern, then torque. Then test.
    Cheap test, worth a shot.
  19. Feb 27, 2024 at 5:49 PM
    centex
    centex New Member
    6 sets I’ve owned have never had an issue.
    bulldog93, biebs96 and koditten like this.
  20. Feb 27, 2024 at 5:50 PM
    kbahus
    kbahus New Member
    MI
    I did go with ET style lug nuts as I thought that might be an issue as well. I have had great luck with K02's on other vehicles, it is hands down my favorite tire and never let me down which I was why was ok going with these.
  21. Feb 27, 2024 at 6:32 PM
    koditten
    Kirk
    Midland of the Mitten
    All on your 2.5 gen? I'm only on my 4th set of michillins on my '08.
    You got 300k on That unit?
  22. Feb 27, 2024 at 7:05 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    which wheels? I had icons6 speeds with KO2s a few years ago. It ended up being the wheel. DT swapped out for a set of Fuels and been smooth ever since.
    kbahus[QUOTED] likes this.
  23. Feb 27, 2024 at 7:16 PM
    kbahus
    kbahus New Member
    MI
    They are Icon Thrusts, what was wrong with the wheel?
  24. Feb 27, 2024 at 7:29 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Supercharger install was delayed till next week. Nipple busted off the fuel pump in the box during shipping. Luckily the tech went through all the parts before starting the install. At least magnuson was good about getting a replacement on the way pretty quickly
  25. Feb 27, 2024 at 7:42 PM
    centex
    centex New Member
    Not entirely certain what that has to do with it but between the 3 HD diesels, 2 half tons, and my k5 rock crawler that gets driven to and from the off road park, with a combined mileage of north of 500k, I’ve never had an issue with BFG’s balancing. Nitto Terra grapplers, yes. BFG’s, no.
  26. Feb 27, 2024 at 8:27 PM
    RobertD
    Robert
    DFW, Texas
    Not sure your plans for your stock pieces, but @dugfur was looking for a set.
  27. Feb 27, 2024 at 9:27 PM
    dan8906
    dan8906 New Member
    Daniel
    That’s great you haven’t had issues, but it’s pretty well documented that many people have had issues with them including myself.
    equin likes this.
  28. Feb 28, 2024 at 4:21 AM
    jeffw6236
    Jeff
    San Antonio
    On mine the center bore was slightly off - like it wasn’t perpendicular to the rest of the wheel if that makes sense. The wheel itself was round. . They’d put it on the machine and it would balance fine. Then after a few miles the wobble would come back. Did this several times at 3 different places. Finally I had them put it on the machine and run it for 10 minutes. Started fine then eventually they saw the wobble. I don’t know all the terminology so this may not make sense. But they use that cone to tighten it on the balancing machine. They’d tighten it up and all would be fine. But then it would shift. Finally they ordered an old school cone for the balancer and you could see the issue immediately.
  29. Feb 28, 2024 at 4:22 AM
    Damie Street
    Edsel
    What's in the BAG? :rofl::rofl:
  30. Feb 28, 2024 at 4:27 AM
    ToyoMafia
    Magic carpet.
    Shhhh
    Damie Street[QUOTED] likes this.
