Bastard leaf packs? or no?
Discussion in '1st Gen Tundras (2000-2006)' started by RUSTYNUTS, Aug 7, 2022.
  1. Feb 17, 2024 at 7:29 PM
    #61
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Bump. We need measurements and pictures. Did you cut any of the leafs?
    Asking for a friend.
    RUSTYNUTS[OP] likes this.
  2. Feb 21, 2024 at 8:24 AM
    #62
    RUSTYNUTS
    RUSTYNUTS [OP] Diagnosed: incurable
    Rusty
    sOCal
    to be continued...
    Update: I settled on a bastard pack (for each side) that included 1 main spring, and the 2 longest intermediate springs from each pack, (original '00 AC springs and original '05 DC springs) so totalling in 5 leafs, and ditched the overloads. I wanted alot of flex without too much lift, and that was working best for me.
    To answer your question; I did not have to cut them because the '05 DC leafs were longer, besides the main leaf
    It gave around 2" of lift, so I started looking for shocks around 2" longer. Long story - short, I kinda stumbled onto a nice discovery; the rear shocks for later gen tundras mount the same (post/stud on top with an eye on bottom) and are roughly 2" longer at both compressed and extended lengths. I got a set from a 2019 tundra and while the length was perfect, they were shit off road, and now shit on the road. If you don't abuse your truck the way I do, and just want to lift the rear an inch or two, and keep it on pavement, then later gen rear shocks will indeed work for your 1st gen. I know that wasn't your question, but worth noting nonetheless
  3. Feb 21, 2024 at 8:34 AM
    #63
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :worthless:
    I take it the intermediate springs were different lengths from AC to DC then?
    I know comparing my 03 2wd and 06 4wd leaf packs, the intermediate springs were different lengths.
    Note the Crocs, just for you. :burp:
    RUSTYNUTS[QUOTED][OP] likes this.
  4. Feb 21, 2024 at 8:45 AM
    #64
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    theres a little bit of difference. The '06 AC has longer intermediate leafs than the '06 DC leafs. Cant fairly compare to the '02-'03 AC leafs i have, since they've been taken apart.
  5. Feb 21, 2024 at 9:21 AM
    #65
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Definitely looks like making bastard packs just got easier. I previously expected to have to cut leafs down to size, like @des2mtn mentioned doing on his bastard packs.
    Mr.bee[QUOTED] and des2mtn like this.
  6. Feb 21, 2024 at 9:34 AM
    #66
    So, quick question of the rhetorical sort, why do you have a bottom half of a microwave wall mount bracket just laying around?
    shifty`, des2mtn and FrenchToasty like this.
  7. Feb 21, 2024 at 9:54 AM
    #67
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Possibly, just trial and error. I'd expect to use a grinder on this job at some point on this job, even if not for the leafs, but to cut u-bolts or centering pins. That's not a big deal though. I probably could have gotten away with throwing donor leafs somewhere in the main pack without cutting leafs themselves, but happy with my results.
    Adding to your original pack will still require cutting the clamps to allow a donor leaf in the main pack. If you use the donor leaf with the clamp, the clamp has to come off it. Just swapping in leafs that are longer in another part of the pack to avoid cutting leafs may result in lifting the truck too high for stock length shocks, but lots of variables such as condition of the leafs, and weight regularly carried.
  8. Feb 21, 2024 at 10:05 AM
    #68
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I keep thinking we could make some decent leaf packs by taking the pack with the longer intermediate leafs, and sandwiching the slightly shorter middle leaf from another pack between those intermediate leafs, and then either do progressive AAL, or smaller bottom leaf (depending on desired lift and stiffness). No overloads, for more flex.
  9. Feb 21, 2024 at 10:52 AM
    #69
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    you dont? The hoard provides.
  10. Feb 24, 2024 at 1:51 PM
    #70
    bfunke
    bfunke Tundra Curmudgeon
  11. Feb 26, 2024 at 10:07 AM
    #71
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    PFA, i know it would break a main leaf before adding any extra load capacity.
    according to google a whole leg is about 17% of body weight, and at 210lbs thats 70lbs for both legs. I know my thigh weight is included, but when i sit on a single top leaf (on top of an i beam for minimum sliding friction) the 140+ lbs squats a leaf about 3/4". So would that equal roughly 186lb/in? Havent grown the huevos to try & stand on the leaf & measure squat (rounded ends), but maybe after a few beers i'll try.
  12. Feb 26, 2024 at 4:21 PM
    #72
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What's the ibeam weigh? Set it on the leaf?
  13. Feb 26, 2024 at 7:03 PM
    #73
    blenton
    blenton New Member
    Take a few measurements with a tape and find out…
    https://suspensionmaxx.com/leaf-spring-rate-calculator
    Mr.bee[QUOTED] likes this.
  14. Feb 27, 2024 at 8:00 AM
    #74
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    this video makes making a bastard pack seems entirely too easy.
    Since i have a dc. I would need a AC pack, longer leaf pack bolt and u-bolts. And that’s it???
    455h0le_dachshund likes this.
  15. Feb 27, 2024 at 4:27 PM
    #75
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  16. Feb 27, 2024 at 4:48 PM
    #76
    blenton
    blenton New Member
    Sounds about right if you are talking about the primary leaf. Second Gen tundra is about the same on the primary.
  17. Feb 27, 2024 at 4:55 PM
    #77
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its the longest leaf that isnt the main leaf. But sitting on it, i didnt squat it an inch, and had to be more than 70 lbs on it.
    but thats a cool tool. Guess i'll have to add 2 leafs to each side.
  18. Feb 27, 2024 at 5:32 PM
    #78
    blenton
    blenton New Member
    So, one thing that isn’t spelled out in the tool is what length should be used for each leaf. Some formulas I’ve seen use L = half the overall leaf length (from the shackle to the tire, basically). This changes the spring rate drastically if it is the case with calculators as well. I am looking for more clarification online. The total spring rate of Gen 2 springs is like 400 lbs/in without the overload, but I suppose if there are two sets of leaf springs. That’s 800 lbs/inch with a static spring load set at ~3” of spring compression once on the vehicle. That makes for about 2400 lbs of design load on the springs with an empty truck, which jives with the back end weight of an empty truck. So maybe the calculators are correct even with how low that spring force seems.
