General Supercharger Thread
  1. Feb 27, 2024 at 3:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I hear ya. I did the burnout video to throw a little shade at my brother. Mostly only do some dumb stuff when it's wet out. Turning the 35's not too good for the drive train either! Must be a mid life thing...
    ARES35 and Silver17[QUOTED] like this.
  2. Feb 27, 2024 at 3:13 PM
    Land Bruiser
    Land Bruiser New Member
    South Park, CO
    2018 Lexus 5.7
    Harrop 2650, 37” tires,
    Does disabling it all eliminate the system from torque limiting all together? I feel like mine pulls power when I'm nowhere near spinning tires. If I'm being honest spinning tires seems like a pipe dream; unless I'm doing a boosted launch. AWD, 10,000ft, and 37's with a tuned stage 1 feels near stock power.
  3. Feb 27, 2024 at 3:21 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I don't think so, need to adjust the torque limit maps in the tune. The full traction off just won't override before those maps come into play. And even the maps we have access to don't fully cover everything it seems like, like low range torque limits.
    Fastlane47, ARES35 and Mdl like this.
  4. Feb 27, 2024 at 5:29 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  5. Feb 27, 2024 at 6:43 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Always have mine off. Went out to rip a forest loop and the rear end stepped out hard off camber rocks and the Nannie’s saved me from balling it up in a ditch. Surprised it kicked on honestly lol.
    Fastlane47, ARES35 and Saltyhero13 like this.
  6. Feb 27, 2024 at 6:47 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Also another note, had a fun run with a maggy tundra. He was in front of me and nailed it so I proceeded to do the same. Closed in hard on him and had to lift off the gas. Good looking truck. Lifted on 37s
  7. Feb 27, 2024 at 7:41 PM
    Saltyhero13
    Stay safe out there.
    Nannies off can get crazy, you can get sideways fairly easily.
  8. Feb 27, 2024 at 7:42 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    [/QUOTE]
    Can someone dumb this down for me? How do I decide what boxes in the table to change? How much do I change them?
    ARES35[QUOTED] likes this.
  9. Feb 27, 2024 at 7:52 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Nannies are always off lol New brakes made me charge the corners harder and brake later lol.
    ARES35 likes this.
  10. Feb 27, 2024 at 7:58 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Very true!! It was not a good experience
    But it taught me that it will walk. I turned off all safeties and it was better and more controllable.
    I can spin tires from a dead stop with not much throttle.
    Saltyhero13[QUOTED] likes this.
  11. Feb 27, 2024 at 8:11 PM
    ARES35
    ARES35 New member for life
    Mile high
    Can someone dumb this down for me? How do I decide what boxes in the table to change? How much do I change them?[/QUOTE]
    @helidave Not in front of editor right now but in your transmission shift scheduling, compare with where you're currently shifting in normal/tow haul etc with cell values/pedal position. You will have to compare actual shift vs the tables. I'm running the TRD shift tables with slight adjustments to 3-4/4-5/5-6. Then match your faults, cold/cold fault and so on. Also note my 17 does not have the shift pressures table or the torque management table like the TRD tune has:notsure:. You may be able to adjust the torque management upshifts/downshifts table also but that is over my head since I don't have that option. Also I did not have to adjust torque model spark effects. The TRD tables worked well with small adjustments in transmission shift scheduling for me
  12. Feb 27, 2024 at 8:22 PM
    helidave
    flagstaff
    2015 DC 4x4
    Sorry, I meant the ignition efficiency stuff.
  13. Feb 27, 2024 at 8:34 PM
    ARES35
    Mile high
    The HPT repository SlowNStock has that calculations spreadsheet. Plug in your ignition efficiency adjusted table, adding for more timing to be pulled. Then paste for your calculated inverse value's. Believe that'll pull timing in between shifts but I haven't tested this
  14. Feb 28, 2024 at 8:33 AM
    Speedkills119
    Speedkills119 Shenanigator
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    That was the ticket for the Tundra. The IS350 is still just a stupid car...
    snivilous[OP] likes this.
  15. Feb 28, 2024 at 8:38 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Installed a new prospeed intake tube since my old one was getting eaten by the box. Been throwing a P0101 ever since. Annoying, so now chasing the little details. Worst case I'll throw the previous intake tube back in. So far cleaned the maf, swapped in a new maf. Now just sealed the pcv Line better and swapped the old filter I had in. We'll see what happens.
  16. Feb 28, 2024 at 8:55 AM
    Speedkills119
    Is the ID of the new tube the same?
  17. Feb 28, 2024 at 8:58 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yessir
  18. Feb 28, 2024 at 9:02 AM
    Speedkills119
    Yeah, I'd through the old one in and see... If it persists maybe the plug/pins.
    reywcms[QUOTED] likes this.
  19. Feb 28, 2024 at 9:04 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Posting this here as well
    There is a new VCM Suite 5.1 beta update available here with Throttle relearn & Reset all adaptives support added for this specific application
    M3Tundra-JK, Mdl and reywcms like this.
  20. Feb 28, 2024 at 9:05 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I did notice the maf mount angle is slightly off and making the maf point slightly up rather than straight. Maybe causing turbulence as air goes into the maf. Again, all theory here lol. Worst case clean the old tube up and slap it back in.
  21. Feb 28, 2024 at 9:09 AM
    Saltyhero13
    "I reckon your air ain't straight."
    Nah could be a number of things. I'd check the seal. I hate that tube with passion.
    Performance MRP if you need custom length/diameter.
  22. Feb 28, 2024 at 10:46 AM
    helidave
    flagstaff
    2015 DC 4x4
    Any tricks to recover from an interrupted flash and possibly bricked ecu? My laptop shut off half way through writing a tune with HPT.
    @Fastlane47 @Mdl @nags @mZiggy
  23. Feb 28, 2024 at 11:03 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Did you try to reflash again?
  24. Feb 28, 2024 at 11:04 AM
    helidave
    flagstaff
    2015 DC 4x4
    Yes. Just gives an error and fails.
  25. Feb 28, 2024 at 11:15 AM
    NatesNightMare
    Pinetop Az
    Ouch! You may need to hit up a shop. If they can even recover it. You may have bricked it :nuclear:
  26. Feb 28, 2024 at 11:35 AM
    helidave
    flagstaff
    2015 DC 4x4
    Tried a few more times without success. Tried to use the VF Tuner ecu recovery tool, and that didn't work either
  27. Feb 28, 2024 at 12:02 PM
    NatesNightMare
    Pinetop Az
    Try contacting VF tuner see what they say
    helidave[QUOTED] likes this.
  28. Feb 28, 2024 at 12:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Try disconnecting pos and neg on battery. Do a discharge, headlights on and touch pos negative cables for any residual and reconnect in about 15min. Worth a try.
    I also believed the hpt support had me try their beta version.
  29. Feb 28, 2024 at 1:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Can you communicate with ecu through obd with scanner or Techstream? How are the ecu and ign fuses?
  30. Feb 28, 2024 at 1:19 PM
    helidave
    flagstaff
    2015 DC 4x4
    Did the battery disconnect and drain. Fuses are good. No communication with scanner. Don't have techstream
