Off Road Build with DIY and Production Mods on 37’s
Discussion in '3rd Gen Builds (2022+)' started by PapaDave418, Apr 3, 2022.
  1. Jan 14, 2024 at 4:36 PM
    #211
    PapaDave418
    PapaDave418 [OP] A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
  2. Jan 14, 2024 at 6:12 PM
    #212
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    Wow! That's a great price too!
    A bunch of the others I was looking at were well over a $100.
    Thanks
    PapaDave418[OP] likes this.
  3. Jan 14, 2024 at 8:42 PM
    #213
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah I agree, great product and a fair price. Much better than a Power Tank mount for sure. The guy who makes them is out of Idaho as well which I like helping local small business
  4. Jan 24, 2024 at 3:25 PM
    #214
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    What mobile unit are you using or do you recommend? About to get my technician license.
  5. Jan 24, 2024 at 6:31 PM
    #215
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I have the Yaesu 400XDR but they just discontinued it and launched a newer model. It’s been very solid and I had Ham Radio Outlet do the MARS mod so I can also use GMRS channels if need be. Technically not allowed but often the very shops you buy it from will do it for you for like $35. One can do it themselves but if you screw up it can brick the radio.
  6. Jan 24, 2024 at 6:35 PM
    #216
    BabyMoose
    Awesome. You're the second person to recommend that unit but hard to find because they're discontinued as you said. Some have suggested the 400 is still better than the newer 300 and 500. Maybe the 300 will be in my future still. Is there a handheld you like by the way? Thanks!
  7. Jan 24, 2024 at 7:00 PM
    #217
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah I use the Yaesu FT-60 handheld, there’s definitely a newer version as mine does not have a color screen. But it’s solid, similar to what departments use
    BabyMoose[QUOTED] likes this.
  8. Jan 28, 2024 at 4:07 PM
    #218
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Camping Heater Build
    Now that my wife and I live up in North Idaho we decided to invest in heat for our RTT set up because it gets cold! I decided on a forced air propane heater due to nearly zero maintaince and I already carry propane. For me I like my build to be easy to use because then I use it more. I bought a Propex 2211 from VanCafe which is the external mount model that is weather resistent, but not completely water proof. My requirements were I wanted to permanently mount it on the rack under the iKamper and it had to be easy to set up, like under 5 minutes!
    I tried to find a location on my @KB Voodoo ProMax rack to mount it but stalled cuz I just didn’t like the way it looked, it didn’t look clean to me. So I decided to fab a box to place it in which makes it look cleaner and also stores my hoses which can be a bit ungangely. I bought 2 “Fat 50cal” ammo cans from a military surplus store then cut the bottoms off, and connected them end to end by bending a stainless steel sheet to extend the length. I wired up an 8 pin plug for the power and controls to route of the box and to my rack harness with the power coming from the truck. I used a project box for the control panel and it lives full time in the tent with the master power switch on my rear control panel mounted by my tail gate. I bought off Etsy a window tent pass through which works great!
    Camping Diesel Heater Rotating Dual Tent Vent Assembly - Etsy
    This Car Accessories item by CounterCultureShop has 44 favorites from Etsy shoppers. Ships from Garden Grove, CA. Listed on Jan 26, 2024
    [​IMG] www.etsy.com
    Propex HS2211 6500 BTU Exterior Gas Air Heater
    The Propex HS2211 is a weatherproof, externally mounted gas air heater, perfect for keeping your van warm during cold weather while saving space!
    [​IMG] vancafe.com
    Workflow: pop the tent, open the ammo can, pull out attached hoses and tent window pass through, power up the heater from the master switch, select temp in the tent on the control panel and bam! Heat!
    50BD0420-EBB3-4219-95BA-58FFE3ADBC56.jpg F0A23D7B-8753-41B0-8F81-740FCC3BF941.jpg 04860431-17C3-488E-BE53-DEE8D63022FD.jpg 3F3CF36B-C581-4E30-9ABA-E82679C69348.jpg 06EBB201-A2C0-4755-8C07-829A77449BCB.jpg 0B3641FD-B012-4F06-9FA2-28F720CA3218.jpg 9304E1C5-37FC-4A8F-81D6-DD10755C3E29.jpg 98A24E4B-99FC-4292-BBE3-74F498372BE7.jpg
    Just got back from camping and snow wheeling in Montana86F38ACE-19EE-4904-8F4C-FC1984336483.jpg 68986863-A8C2-4198-9812-C2D356FC9BB0.jpg
    Black@Blue19, Nic146, Gaston and 3 others like this.
  9. Jan 29, 2024 at 11:22 AM
    #219
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    That heater is slick!
    From my research, I see a lot of guys drift towards diesel heaters to avoid condensation, which people claim propane is prone to. Did you notice any condensation issues with this set up?
    I'm slowly building up my Tundra to replace my GX as my main camping rig and heat is one of the requirements for the new rig.
  10. Jan 29, 2024 at 11:33 AM
    #220
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Good question but it’s mixing apples and oranges. Diesel heaters work amazing, super hot, and diesel is cheap. Propane does create condensation at the point of ignition but the Propex propane heater is basically a miniature home furnace as its combustion and heated air exchange are separate. A Buddy Heater will make a tent wet, but diesel and propane exchange heaters dry out a tent. My bias is for a propane exchange heater but they can cost A LOT more. You can get a cheap diesel heater on Amazon for like $150 but many users struggle to make them reliable. My buddy had to add anti-gel to his diesel tank to get it to work in cold weather when he tested it then at camp he never turned if off as he was worried it wouldn’t fire back up. I set mine for 65° like at home and it turned on and off all night just like a house furnace.
    So that’s the big difference. It comes down to budget, hassle factor, fuel you wanna carry as both will get you similar results.
    Long answer to a short question!
    Black@Blue19, helidave and Gaston like this.
  11. Jan 29, 2024 at 12:05 PM
    #221
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    Exactly the type of answer I needed. Thanks.
    I've seen tons of videos on those Amazon heaters. I've waffled back and forth on trying one out, but I'm really looking for something more reliable. I know there's a few places that sell a more professional setup, but then you're in the same price point as what you posted. So it becomes a question of what makes the most sense as a fuel source.
    How much propane do you carry and how long are you out for generally?
    I have an Ignik 5# that I take with me and run a two-burner Mountaineer stove as my only propane powered device. The canister generally lasts months for me on 1-3 day trips, cooking for two adults and two kids.
    I'm curious if I'd have to up my propane if I went that route for heat.
  12. Jan 29, 2024 at 6:12 PM
    #222
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    So I just installed this and did a weekend in Montana, I have a 5lb and we were heating the tent for about 12 hours (granted it goes off and on like a house unit) and it used maybe a third. So if you just used it for sleeping I’d say at least 4-5 nights if you sleep 6-8 hours heated.
    Another factor is diesels pull 15A or so when heating up the glow plug each time they start, but that’s only for like 5 minutes I believe, then run around the power drain of a fridge, 1.3A or so. Propane just pulls 1.3A and the fuse they send with it is only a 5A fuse
  13. Feb 5, 2024 at 7:05 AM
    #223
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Blue Mountains
    Oregon
    4908C8EF-D4A2-4A83-B0A3-C9396A3D6E0C.jpg 29C29D7B-A4A3-4CD0-9DB5-AE506935345A.jpg
  14. Feb 13, 2024 at 5:28 PM
    #224
    AND
    AND New Member
    Washington, PNW
    Did you fit the 27F battery yet? planning to copy your work :hattip:
  15. Feb 14, 2024 at 6:27 AM
    #225
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Hopefully working on it today then traveling for work till Sunday, so we will see. :thumbsup:
  16. Feb 14, 2024 at 3:41 PM
    #226
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I installed an X2 AGM battery to replace my stock 75AH battery with 92AH. The X2 Group 94R fits nicely as a direct replacement and has 81AH 159 reserve minutes of capacity. I opted for the larger X2 27F which has 92AH and 190 reserve minutes of capacity. The 94R is 7.4” (about stock) in height whereas the 27F is 8.75” so I thought about getting fancy and making a new center bracket. But I didn’t.
    There is a bottom bracket which secures the battery into place and the center strap is secondary. I reversed the bracket and bent it to fit. Isn’t too pretty but it fits nice and snug. The battery cables reach just fine and overall pretty easy.
    489F9774-EAC3-40B2-8841-18986AED4C9D.jpg 0447022B-0C86-4D89-840D-424BEB54B14C.jpg
    Reversed the bracket then gave it some mallet love
    E9AC5940-F0F7-4D01-94B7-CA4A903EF734.jpg 6650C640-C3E9-49C2-BB4A-1678A822E8D2.jpg
    The bolt is cinched tight
    D09CE14B-4564-46DC-A30B-0996009163A9.jpg 98E3D1BC-F824-4FA0-99E7-94A6D088A3B8.jpg
    This screenshot is of my fridge when going about 60mph and it’s registering 14.3v which is enough juice to top off an AGM nicely
    Black@Blue19 and Black widow TRD like this.
  17. Feb 20, 2024 at 1:39 PM
    #227
    GrandPooPaw
    GrandPooPaw New Member
    2024 Platinum
    looking and researching
    Awesome Build Man!
  18. Feb 24, 2024 at 6:15 PM
    #228
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Camping Mod-
    I added solid LED’s to my 270 awning, used a project box for my electrical junction box, and bought a dimmable switch that is fully waterproof. I put the LED’s on every other support bar so it wasn’t too much, it is camping after all……ha
    I placed carpet tiles on my iKamper base, helps with the cold and the knees.
    Florida AF and Black@Blue19 like this.
  19. Feb 26, 2024 at 8:26 PM
    #229
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Today I added SDHQ ABS Guards. Simple mod that can save a lot of headache and repair if you off road. They protect the sensor from a broken branch or something catching the loop and ripping the sensor wire out which would cause a lot of problems trying to drive the truck. They don’t cost too much for the protection
    94B65138-C0F5-4EFA-BBE2-88B325BEA772.jpg 01B85464-B551-4C1D-A4B7-A6960A94879E.jpg E0731BD0-2C9B-4E5A-AE64-8B5C15E25E70.jpg 14D8FB04-CA54-4DD3-970B-981C5E8EAFE4.jpg
    Black@Blue19 and BabyMoose like this.
  20. Mar 2, 2024 at 7:51 PM
    #230
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Camping tonight at Frenchman Coulee in WA where catastrophic ice age glacial floods devoured the landscape. Pretty cool views
    The waterfall was 3.5 miles across and 400 feet tall, nutsA094B635-95F9-44D2-866E-CCAB89744F1A.jpg E78C8F50-A996-4C10-82E0-3264782A7E35.jpg 10BD86D1-80AD-4A85-8CD3-AA611ED810C6.jpg 1AF28357-41E7-41B2-9FA4-D93B192CC693.jpg EED14B5A-5AB5-434C-94F7-12A0AAA437CC.jpg
  21. Mar 9, 2024 at 8:51 AM
    #231
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I installed my 5lb propane mount and given the clearance of my @KB Voodoo rack I placed it to the side of the slide out cargo tray underneath. It’s plumbed in and I just need to open the valve to run my heater, or remove it for my fire pit if there’s a regional fire ban in the summer.
    5lb mount off Etsy
    Extrusion mount I threw together
    653949EE-A1F7-45EB-94EA-693E12AD5469.jpg 61F49115-1B8F-4235-B4FF-E99DE46CF1C8.jpg
    Regulator mount solution with quick connect
    With the Rotopax locked on its hard to steal
    I made an ammo can fire pit, I added rounded lava rocks later. I made a mistake on the cut so I fashioned a fire emblem to cover it up
    FAC58081-343A-4430-9434-D8ED77223A3B.jpg 186B4579-E354-4D59-A0E8-BB4BC87005D9.jpg
  22. Mar 17, 2024 at 7:35 PM
    #232
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Such an amazing weekend at Hells Canyon Idaho
    08A430C3-938C-4616-AA89-499C8BA6F0EA.jpg 2DB59640-4B24-4359-B537-2C6EF4B91EFB.jpg AE178FF2-829A-4FF2-AF3B-CBCB861F7229.jpg
  23. Mar 31, 2024 at 10:16 PM
    #233
    llod
    llod New Member
    2024 Tundra - amongst others
    Work in Progress
    Hey Dave, we chatted years ago about PullKitchen stuff (shame looks like it's no more, I always thought it was a rad setup)
    In any case, I've been doing lots of planning on my own new Tundra build, and was randomly searching for a Tundra specific hood antenna mount - and somehow ended up on your build thread here. Shot you an email to your old address, but it bounced. Really was just shooting you an email to say awesome work on the build and all the documentation (so I'll just say that here instead, haha). I was planning a second battery and some bed power similar to what you're doing, and saw lots of your other little mods and just lots of clever stuff for inspiration.
    Take care!
    -Mike (Last Line of Defense)
  24. Apr 10, 2024 at 7:36 PM
    #234
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Thanks! I use my PullKitchen every trip, this is at Whiskey Rock Bay on Pend Oreille Lake in North Idaho. Set up really fast to heat up some soup
    Florida AF, Black@Blue19 and 3d_pilot like this.
  25. Apr 22, 2024 at 5:36 PM
    #235
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Not related to Tundras but considering building out a Humvee ambulance camper conversion! Haha
  26. May 5, 2024 at 8:21 PM
    #236
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Last weekend I took 14 rigs to Whiskey Rock Bay on Lake Pend Oreille in North Idaho. Today I did a 30 mile loop through the mountains east of Hayden Lake, easy but lots of fun
  27. May 18, 2024 at 4:22 PM
    #237
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Last weekend we went camping and of course took the obligatory Aurora Borealis photos while camping.
    Where we are up north most of it was directly overhead, so amazing to see
  28. May 27, 2024 at 12:04 PM
    #238
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    For Memorial Day I got up early to find Horse Haven back country air strip. Easy drive up the mountains but I like to air down for comfort and reduced wear on the truck. I made my own 4-way inflator a couple years ago, it’s a different design using Y connectors and zipper sleeves to keep debris out went you toss out the lines to the tires.
    The Y connectors and sleeves make it very easy to roll up and the red line has a quick connect air Chuck at the end so I can double the length if needed by connecting the blue line there if needed to reach a long ways.
  29. Jun 11, 2024 at 8:18 AM
    #239
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Bethel Ridge driving section 4&6 of the WA BDR
    Florida AF, Black@Blue19 and Gaston like this.
  30. Jun 22, 2024 at 5:35 PM
    #240
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    With my rack off roading I was worried about the bedsides flexing from the weight. These are Rago Fab’s bed side stiffeners and the install is pretty straight forward. On the left side behind the tail light is the shock dampener for the tailgate which makes access to the bolt a touch difficult but not impossible. I trimmed my right brace to clear my PullKitchen IMG_0174.jpg IMG_0175.jpg IMG_0179.jpg IMG_0180.jpg
    mayan, Florida AF and Bnewman077 like this.
