The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.9%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.3%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    54 vote(s)
    41.5%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.6%
Multiple votes are allowed.
  1. Feb 8, 2024 at 9:48 AM
    #901
    AZBoatHauler
    So.Arizona
    I wouldn’t t-tap those wires. Could cause a break jeopardizing the OBD port.
  2. Feb 8, 2024 at 9:52 AM
    #902
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    t-tap? just cut and wire nut them like a professional.
  3. Feb 9, 2024 at 11:16 AM
    #903
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    I would likely unpin it from the OBD connector and solder the brown wire directly to the existing wire.
  4. Feb 9, 2024 at 11:33 AM
    #904
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    OBD extension cable and tap into that? Leave OEM alone
    ToyoMafia and TaquitoBandito like this.
  5. Feb 9, 2024 at 11:43 AM
    #905
    cooper4x4
    2016 Tundra SR5
    What do you mean by extension cable?
  6. Feb 9, 2024 at 11:53 AM
    #906
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Something like this. Strip it back.. there should be wires you can tap into. I would stay away from the ribbon cable versions as the wires would be pretty thingD31A434C-0E81-4E5A-A04D-D6DF4E5F5694.png
    TaquitoBandito and bulldog93 like this.
  7. Feb 9, 2024 at 11:56 AM
    #907
    cooper4x4
    2016 Tundra SR5
    I'm not worried about tapping the OEM wires, just wanted to be sure they're just simple automotive wires and not something more complex.
    TaquitoBandito and Mater[QUOTED] like this.
  8. Feb 22, 2024 at 8:13 AM
    #908
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Finally getting back to this after @wackyhacky asked about updates on the other thread.
    The TL;DR on getting OTA updates to work is restarting the head unit AFTER enabling the wifi connection to check for them.
    Details:
    • Turn your truck on to ACC and head to Settings once the radio is up and running
    • You'll go to the System tab and then down to the bottom option About/Software Update:
    • Tap Over-The-Air Software Update and Connect
    • Add your wifi network if you haven't already and connect, then tap Yes to connect and disable your CarPlay/AA connections:
    • This is where you'll need to turn the truck/radio off for about 30 seconds, then turn it back on. It's important to give it about 30 seconds, as the HU doesn't fully power off right away.
      • I recommend starting the engine and leaving the truck running for the next steps
    • Now go back to Settings>System>About/Software Update and tap Over-The-Air Software Update. If there's one available to download, you'll get the prompt to download and install. If you're up to date, you'll see this:
    • The update will take a good while to download and install, around 10-15 mins if I remember correctly. Don't turn off the power or anything while this is going.
    • Once complete, you'll need to set the Wifi back to Phone Link Mode; Settings>Device>Wi-Fi:
    • Tap Wi-Fi Mode and select Phone Link Mode
    • Tap Yes
    • You're now back in Phone Link Mode and can select your phone to reconnect in the Device menu
    GWill, What the!?, TreeCat and 7 others like this.
  9. Feb 22, 2024 at 3:41 PM
    #909
    Azblue
    The Dirty T ( ^_^)_且
    Well thanks a lot Jake, I followed your instructions and it bricked my H.U. and then my dash caught on fire.
    JK, worked fine. I was on software 5.0 and updated to 6.0. Thanks for the write up!
    20240222_161011.jpg 20240222_162146.jpg 20240222_162258.jpg 20240222_162840.jpg
  10. Feb 22, 2024 at 3:43 PM
    #910
    coTony
    Tony
    Montrose, CO
    Any noticeable changes
    TaquitoBandito and Azblue like this.
  11. Feb 22, 2024 at 3:44 PM
    #911
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Would have been a whole lot more fun if fire was involved though
  12. Feb 22, 2024 at 3:49 PM
    #912
    Azblue
    Just finished and haven't fucked with it yet. I'll see when I drive to work in the morning.
    True.
  13. Feb 22, 2024 at 4:19 PM
    #913
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I'm just hoping you had the garage door while you sat there with the engine running and the update was applying
  14. Feb 22, 2024 at 4:36 PM
    #914
    Azblue
    It was open, but I like to live dangerously, I didn't have the truck running.
  15. Feb 23, 2024 at 3:34 PM
    #915
    Azblue
    OK, one change from my drive to work. When you first fire it up and select XM, I no longer get the message to dismiss the Wi-Fi connection, which is actually nice.
  16. Feb 23, 2024 at 3:41 PM
    #916
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That is definitely the most underrated feature update
  17. Feb 23, 2024 at 3:55 PM
    #917
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yeah, that was super annoying!
  18. Feb 23, 2024 at 3:56 PM
    #918
    Azblue
    I haven't noticed anything else yet, but I just drove to and from work.
  19. Feb 23, 2024 at 4:04 PM
    #919
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The main thing I’ve noticed is that my phone and remote volume knob both stay connected a little better than before. Not much else has changed.
  20. Feb 23, 2024 at 4:23 PM
    #920
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    are you trying to give me an aneurysm?
  21. Feb 23, 2024 at 4:24 PM
    #921
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  22. Feb 27, 2024 at 6:15 PM
    #922
    cooper4x4
    2016 Tundra SR5
    Got my Alpine installed tonight. I'm probably missing something but I have a couple of issues.
    1. I'm not able to access the vehicle info screen. It's not an option on the home screen.
    2. Most of the sound comes from the dash speakers. Barely anything coming out of the doors or sub. Running RCAs to a JL amp, then connected to door speakers using an adapter harness. Sub connected directly to amp.
    Ideas?
  23. Feb 27, 2024 at 6:28 PM
    #923
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Edit: I just re-read your first bullet and I don’t think this applies as written. But I’ll leave it anyway. Are you using the Maestro RR with the OBD2 connector?
    For your first issue, you either need to engage the parking brake (obviously while not moving) or install the VIM bypass. Assuming that you wired the parking brake trigger wire to the head unit, you can access the settings only while the parking brake is on. You might need to do an engage, disengage, engage again routine for it. I went the VIM bypass route and can access the settings (and video playback features…) without the previously mentioned steps.
    For your second issue, I’d recommend disconnecting the dash speakers from the wiring harness. Your HUs built in amp is running those and your aftermarket amp is running the rest. You could probably get away with messing with your amp gains, but the stock speakers are crap. Unless you’re still using the stock door speakers, then we’ve got a whole different conversation to have.
    ToyoMafia, coTony and AZBoatHauler like this.
  24. Feb 27, 2024 at 7:17 PM
    #924
    cooper4x4
    2016 Tundra SR5
    I'm using the AX-TRIG1 bypass.
    I upgraded speakers years ago from JRT. As for disconnecting the dash speakers.... I'll do that once the doors and sub start working. Right now, there's not much noise from the doors, even when turned way up.
    TRDFerguson[QUOTED] likes this.
  25. Feb 27, 2024 at 7:18 PM
    #925
    cooper4x4
    2016 Tundra SR5
  26. Feb 27, 2024 at 7:31 PM
    #926
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Your input sensitivity looks real low across the board. Are they set to min? I had to tweak mine quite a bit after switching from my Kenwood to the Alpine. Might be worth reaching out to JRT to see what he recommends, but I’m guessing those settings need some tuning.
    ToyoMafia likes this.
  27. Feb 27, 2024 at 7:50 PM
    #927
    cooper4x4
    2016 Tundra SR5
    I didn't touch them today. Set it according to JRT's recommendations when installed several years ago.
  28. Feb 27, 2024 at 8:15 PM
    #928
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    What are you using for the radio interface module though? iDataLink Maestro RR? Crux swc module? Nothing at all? You need something between your stereo and truck to get vehicle info fed into the HU.
  29. Feb 27, 2024 at 8:33 PM
    #929
    cooper4x4
    2016 Tundra SR5
    Maestro RR2. The RR2 instructions showed only 1 wire connected to the OBD2 port, so I spliced that into the factory wiring. I confirmed the OBD2 port is still working after the splice with a scan tool.
    I got the speakers working. The input sensitivity was turned all the way down... somehow.
  30. Feb 28, 2024 at 8:36 AM
    #930
    cooper4x4
    2016 Tundra SR5
    Any suggestions for #1? The steering wheel controls work as configured in the RR2 (based on another post, this should be coming from the OBD connection). I used the attached diagram.
    EDIT...not sure it matters, but I flashed the RR2 after everything was connected and installed. The Alpine didn't turn on until after the flash was complete.
    In lieu of using the "OBDII" connector, I tapped the red/gray wire into the brown wire on pin 2 of the OBDII harness. To mitigate concerns that the splice messed something up, I successfully tested the OBDII port using a scan tool after the splice, so it should be receiving a signal.
    The braided red/yellow wires in the diagram (from the OBDII connector) are labeled "NC" so I assume that means they're not used per another post in this thread.
    The diagram shows 4 connections on the RR2. All four are connected.
    The "Vehicle Info" icon is not showing on the home screen. This is what it should look like: [​IMG]
