General Supercharger Thread
  1. Feb 21, 2024 at 5:58 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Harrop uses the same SC rotor design/size as the new Magnuson 2650. I'm a fan of their IC design and easy access to the fuel rails personally, but you really can't go wrong with any of them. Whichever you choose, make sure you get it tuned properly.
    Speaking of tuning, has anyone done any Maggy 2650 datalogs at low elevation to see how that tune is? We know the OG Maggy tune is lacking and the Harrop stage 1 (no actual tune) is garbage.
    ARES35, HulkSmurf14, reywcms and 3 others like this.
  2. Feb 21, 2024 at 6:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ditto
  3. Feb 21, 2024 at 8:51 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I'm working on it!
    Waiting to get my draggy from my brother and then will run a log or two. Looking like this weekend. I'm at sea level... good ole flat eastern shore of MD
  4. Feb 21, 2024 at 9:21 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Main reason why I got mine. Extra power for mountains esp with big lift and tires
    koditten[QUOTED] and Saltyhero13 like this.
  5. Feb 21, 2024 at 9:25 AM
    NatesNightMare
    Pinetop Az
    Also magnuson does a basic tune for you. Once you get the kit you olug into your obd and download the stock claibration file and you send it to them. They put the adjustments in for fuel etc and send it back. Then you flash it over and done. You can also pay MONEY and get a custom tune.
    koditten[QUOTED] and HulkSmurf14 like this.
  6. Feb 21, 2024 at 9:51 AM
    ARES35
    ARES35 New member for life
    Mile high
    Curious also about low elevation logs on Maggie stock map. Mine was riddled with knock and ran lean as hell, into the 12's. And I'm at 5k
    reywcms likes this.
  7. Feb 21, 2024 at 11:13 AM
    NatesNightMare
    Pinetop Az
    Anyone know what size the stock pulley is on the 2650 magnuson?
  8. Feb 21, 2024 at 11:14 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    86mm/3.38"
  9. Feb 21, 2024 at 11:18 AM
    AZTundra
    Paul
    Phoenix, AZ
    Here was a log with my Maggie provided tune at around 1100 elevation. Not ideal by any means. This was on the 1900, not sure if they've made any changes in comparison to the 2650.
    ARES35[QUOTED] likes this.
  10. Feb 21, 2024 at 11:40 AM
    NatesNightMare
    Pinetop Az
    You still selling pulleys?
  11. Feb 21, 2024 at 11:45 AM
    snivilous
    SW UT
    Yes sir, got 3x of both the 70mm and 76mm sitting here.
  12. Feb 21, 2024 at 11:47 AM
    NatesNightMare
    Pinetop Az
    Im at 7k ft elevation. But we travel to oregon once or twice a year which is around 4500. Im looking for a mild one just to bump some psi but when I get to lower alt its not gonna hurt anything
  13. Feb 21, 2024 at 11:49 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    The 76 gives you a nice bump at 7k and is still drivable at lower elevations as long as you take it easy
    snivilous[OP] likes this.
  14. Feb 21, 2024 at 11:55 AM
    NatesNightMare
    Pinetop Az
    Lol taking it easy isnt always an option
    Passing vehicles etc etc
    But whats "taking it easy "? I mean for the most part im a pretty conservative driver but on the faster side lol
  15. Feb 21, 2024 at 11:57 AM
    snivilous
    SW UT
    76mm you shouldn't need to tweak the tune and the injectors you have should be fine. @helidave goes to a lot lower elevation than that without swapping the pulley and is fine. If you don't want to fiddle with stuff, that's what I would do. Even though the 70mm at higher elevation shouldn't need much support, I would be wary of recommending it without saying that injectors and a tune would possibly be required. The 76mm is much more of a install and not worry since it's not a large bump at high elevation.
    helidave likes this.
  16. Feb 21, 2024 at 12:10 PM
    helidave
    flagstaff
    2015 DC 4x4
    Taking it easy means not doing wide open throttle pulls to redline.
    If the lowest you go is 4500' you shouldn't have any issues. Like snivilous said, I've had mine down to like 1500' with the 76mm and everything was fine, even doing some short WOT runs to get datalogs it was nowhere near maxxed out.
  17. Feb 21, 2024 at 12:20 PM
    NatesNightMare
    Pinetop Az
    Doubt 4500ft is lowest. Im in az so we go up through vegas and north from there, through reno, corner of cali and into oregon. At some point I want to take my family across country. My moms side is in Ohio. Id like to show them everything ive seen as a kid
    HulkSmurf14 likes this.
  18. Feb 21, 2024 at 12:27 PM
    VWTim
    Corvallis, OR
    No redline Draggy runs with your family in the truck at sea level :) Normal driving and towing, you'll be fine.
  19. Feb 21, 2024 at 12:34 PM
    NatesNightMare
    Pinetop Az
    Lol
    No draggy runs but I do gotta pass slow ass people
  20. Feb 21, 2024 at 12:41 PM
    carn_dogg
    Pat
    Eastern Shore MD
    I’m at sea level and just bought your 76mm sniv.
    I’ll see how it does!!
    ran draggy today in 2wd. Spun through 30mph or so and ran 6.10 0-60
  21. Feb 21, 2024 at 1:24 PM
    carn_dogg
    Pat
    Eastern Shore MD
    @snivilous do you know what belt is required when moving to your 76mm pulley on the Maggie 2650?
  22. Feb 21, 2024 at 1:27 PM
    snivilous
    SW UT
    I think everyone is running the Dayco K081145 and it fits both the 76mm and 70mm.
    @Wynnded did a good write up here on options:
    Wynnded[QUOTED], helidave and Mdl like this.
  23. Feb 21, 2024 at 1:46 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    “Well kids, for the next leg of our trip, have you ever seen a hole in the side of the block of a 3UR FE?”
    :bananadead:
  24. Feb 21, 2024 at 1:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are you running a wideband AFR gauge? Most with the SC will run one to help them know if they are running lean when on it. Ideal is the 10.1 to 10.5 and above 11.0 can lead to problems. Most run a combo boost/afr setup.
  25. Feb 21, 2024 at 2:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Umm...yeah. Nice 3 big ones! When I had a misfire in boost and it stumbled I was like NOOOO! The memory still lingers.
  26. Feb 21, 2024 at 2:05 PM
    NatesNightMare
    Pinetop Az
    Im not trying to run hard but somethimes ya gotta mash on it to pass someone.
    By your saying, its not good to go with a 76mm
  27. Feb 21, 2024 at 2:07 PM
    snivilous
    SW UT
    In that case I would definitely do the 76mm. The 70mm would require pretty huge injectors to be able to survive in Las Vegas. Even my setup which is similar to the 70mm with 715cc injectors and I am cautious to use much WOT in Las Vegas since it'll push past 10psi easily which gets into the danger zone of what the engine can handle imo.
    Flip side is, you can always run a small pulley and just swap in the OEM pulley before a trip. That is the beauty of the quick change.
  28. Feb 21, 2024 at 2:30 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Thanks. Any reason not to go heavy duty?
    5081145 Is $20 vs the regular one being about $60. Decent diff and heavy duty one is less.
  29. Feb 21, 2024 at 2:33 PM
    snivilous
    SW UT
    I would get the heavy duty one then. I think @Wynnded only suggested running that one since it's what the part store had for him locally so there was proof it works. But I've never run the 2650 so I have no first hand experience ironically hahaha
    Wynnded and HulkSmurf14 like this.
  30. Feb 21, 2024 at 2:35 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Haha ok right on. Your prev post about 10psi being max for this motor…has me concerned now about change out to 76mm at sea level. I just went wot and see 8-9 psi. Def don’t want to blow up my motor in search of a tighter butt clench
    Wynnded and NatesNightMare like this.
