Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Feb 17, 2024 at 4:46 PM
    #1021
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    You’re the man. THANK YOU! My bed caps are a tad “wavy” in one spot from the previous owner. Hopefully the DB seal will conform. I’m not willing to spend $300+ for new plastic rails haha.
    SM Tundra[QUOTED] likes this.
  2. Feb 17, 2024 at 4:58 PM
    #1022
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I bought the butyl tape and am going to do my rail caps when the weather warms up. Hoping that seals it up better but there is minimal water infiltration aside from each corner of the bed.
  3. Feb 18, 2024 at 7:09 AM
    #1023
    Willard
    Willard New Member
    2024 F250
    Borrowing this pic of a Tacoma - this is the exact area on the tundra where my DB cover leaked. You need to fill the gap between the bed side and front wall (I ran a bead of silicone down the crack) and also along the top of the bed rail under the plastic cap like the putty shown in the pic.
    The tundra doesn’t have a separate piece width wise along the top of the front bed wall but DB provides weather stripping to apply there which helps level it with the bed rail caps.
  4. Feb 18, 2024 at 5:21 PM
    #1024
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    1. How hard is it to remove the plastic covers?
    2. Why not just butyl tape on the top of the bed sides (but near the outside not the inside like you did it)?
    if you can stop the water intrusion from the “outside” it will just drip down the side of the truck.
    I also have some leaking into from the cover, but,from under the plastic covers, AND only when using a high pressure washer
  5. Feb 18, 2024 at 5:39 PM
    #1025
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    plastic covers came off easily. Really just pull up and they pop out. At least on the Tacoma they did. I guess you could use butyl type on top of them but used my bed often to haul things that couldn’t fit under the cover, so the cover came off fairly often. Guess I didn’t want it exposed. Plus butyl tape is a bit sticky, so I realized if it encountered the seal around the bed cover it would stick to it when opening the cover. I like the butyl tape cause it’s easier to remove than caulk or sealant and when doing some research a lot of people said it was very good to use to keep water out. So I just tried what I thought would work and it worked out well.
  6. Feb 18, 2024 at 6:16 PM
    #1026
    Oldandfat
    Cannuckastan
    I have a hard time explaining so here’s a pic of what I meant (I highlighted in red where I was asking why you did not place the butyl).
    you placed on the “inside or close to the bed” and I asked why not “outside and closer to the outside of the box”
  7. Feb 18, 2024 at 6:19 PM
    #1027
    SM Tundra
    Cody
    Ahh, ok that makes more sense now. I think I stuck to the inside cause I folded it over the edge of the bed. There was some holes on the top inner portion of the bed that needed to be filled in. I figured as long as there was a seal the outside wasn’t needed. But I think either would work.
  8. Feb 18, 2024 at 7:47 PM
    #1028
    andywocky
    andywocky New Member
    2024 Tundra 1794 Limited Edition (Blueprint)
    Nice pic! Do you know if you can have the ATV rails *and* the Yakima racks in the cover at the same time?
  9. Feb 19, 2024 at 3:34 AM
    #1029
    Bergy24
    Bergy24 New Member
    What size butyl tape is everyone using? I like the idea to add the shims to the entire length of the cap as well.
  10. Feb 19, 2024 at 5:04 AM
    #1030
    therealjonwick
    JR
    2019 OR
    Agreed. DB said mine will come with 24 shims. The additional packs are 8ct. Figure I’ll get 3 packs? 24 more?
  11. Feb 19, 2024 at 5:19 AM
    #1031
    shawn474
    MoCo, Maryland
    I just went to diamondback to order the shin pack; put 4 packs in my cart for a total of $16. The only shipping option cost $17.51 to ship!!!! I am all for using the parts made for stuff but generally hate paying exorbitant shipping costs like this. Do you all think the butyl tape that I already have will serve the same purpose?
  12. Feb 19, 2024 at 5:26 AM
    #1032
    therealjonwick
    JR
    2019 OR
    Damn! That’s insane. From what I’ve heard, the rails will flex over time. Maybe if you used a lot of the tape and put it in the empty spots under the plastic rail to fill the gaps? I assume it would also compress. Might help a bit. Wonder if there is any other material you could use and cut your own shims to spec? I haven’t gotten mine yet so I can’t know the size for reference.
  13. Feb 19, 2024 at 5:30 AM
    #1033
    shawn474
    MoCo, Maryland
    it really is based on principle…..I am literally one state away from them. To charge that much in shipping is price gouging. I am quite sure I can find another material….just need to figure out how thick it is.
  14. Feb 19, 2024 at 5:31 AM
    #1034
    therealjonwick
    JR
    2019 OR
    Yea I was thinking some type of plexiglass.
  15. Feb 19, 2024 at 1:12 PM
    #1035
    shawn474
    MoCo, Maryland
    I emailed diamondback today asking if that was their only shipping option - their customer service is top notch. Sent me a new invoice with much more reasonable shipping charges and I ordered them. Will install them when the weather warms up in hopes of further sealing the cover
  16. Feb 19, 2024 at 4:22 PM
    #1036
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Can't speak from experience but I don't see why not.
  17. Feb 22, 2024 at 6:55 PM
    #1037
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    You guys with the HD ATV carrier, loading from the side, can you drive up one side and then at destination drive down the other side, or do you have to back up/down one way (either loading or unloading)?
  18. Feb 23, 2024 at 10:20 AM
    #1038
    andywocky
    I like the blue truck setup! How long is that RTT / how much does it extend back past the tailgate? Any issues with that?
  19. Feb 27, 2024 at 10:56 AM
    #1039
    therealjonwick
    JR
    2019 OR
    You have a lift?
  20. Mar 4, 2024 at 5:35 AM
    #1040
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    2013 MGM CrewMax Rock Warrior
    Recently picked up this DB 270 for my 2013 for a decent deal. Have wanted one for a long time. Has anyone custom built a cross bed box for theirs similar to the crossbin Diamondback sells for $400 on their website? IMG_0602.jpg I figure a Saturday afternoon with some plywood and a few beers I could easily make something that does the job.
  21. Mar 4, 2024 at 5:50 AM
    #1041
    Bergy24
    Bergy24 New Member
    What kind of deal?
  22. Mar 4, 2024 at 5:58 AM
    #1042
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    $750, he had held pretty steady on his $1500 original price for quite a while. I know they can be had used for less but with it being the 270 (which I wanted more than the SE) I couldn’t turn down.
    Bergy24[QUOTED] likes this.
  23. Mar 4, 2024 at 6:32 AM
    #1043
    shawn474
    MoCo, Maryland
    That's a good deal; I got my HD on facebook marketplace for $1100. It is a battle of attrition for sellers and buyers.......often times sellers have these listed for weeks or months taking space and buyers wait weeks or months waiting for one local to come up. I had two sold out from under me that I could have gotten cheaper than the one I bought but I was trying to get a GREAT deal instead of a good deal. I look at it this way: the comparable $750 covers can't hold a candle to the diamondback versatility and quality.
  24. Mar 4, 2024 at 10:00 AM
    #1044
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Smokin deal. Sometimes the deals come up but usually not when you are looking.
    I was looking at getting a crossbin but the shipping cost was going to be almost as much as the bin itself.
    I think the best time to order stuff from DB is when you are ordering a cover. Then the shipping is manageable.
  25. Mar 4, 2024 at 10:06 AM
    #1045
    shawn474
    MoCo, Maryland
    Yeah I got the crossbin 13 locally for $175. They used to be way cheaper......I think in the last 18 months they have gone up something like 50%. When you add shipping on to of it, they are too expensive for me to justify. BUT, i much prefer the crossbin to any alernatives (bins, crates, etc). They are well worth it, but I just couldn't justify paying regular prices.
  26. Mar 16, 2024 at 12:33 PM
    #1046
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So I picked up a used diamondback SE a few months back. Bought some new weather strip for it and it works great. The lone problem is the constant rattle I hear when the back window is down. I caulked along the C channels like others have recommended but I still have the noise. After investigating a bit more it actually looks like the lock mechanisms are loose on the underside of the cover. Even when locked I can wiggle the center a good bit and it makes the noise I hear. You can see in the photo it looks like there is an O ring in there that is chewed up a bit. I tried to loosen/tighten the 13mm nut in the center but it just spins. Has anyone else taken this lock off before? Just trying to see if I can get it apart and add a new thicker o ring to fix the problem.
  27. Mar 16, 2024 at 1:02 PM
    #1047
    SM Tundra
    Cody
    I have never taken the locks off before but I mean mine has made noise with my Tacoma and now my tundra. If I hit bumps I can hear it with the back window open. Figured it was just the nature of a metal cover and making noise. Never really thought much of it. Mine wasn’t rattling though, so maybe that is why it didn’t bother me
  28. Mar 16, 2024 at 1:15 PM
    #1048
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Yeah I hear noises like those as well and like you said, the nature of metal. This is a constant rattle though with any imperfection in the road. Drives me nuts.
  29. Mar 16, 2024 at 5:42 PM
    #1049
    SM Tundra
    Cody
    I’d recommend messaging Diamondback. They are really fast at responding. Could be a bad seal around the underside of the lock maybe. That’s what I would do and see what they say.
    Nbab23[QUOTED] likes this.
  30. Mar 16, 2024 at 7:04 PM
    #1050
    therealjonwick
    JR
    2019 OR
    Got my cover on. I’m nervous I tightened the brackets too much. Set the wrench to 5lbs. Just kept cranking and never would pop. Seeing slight bending of the rails. Not sure what is going on. Tried 3 different wrenches. Anyone have this issue? I do not have the bedrail kit in mine so it’s right to the truck bed. Does the middle look too compressed? Thanks!
