Going Long Travel Front and Rear
Discussion in 'Long Travel Suspension' started by heckler66, Jul 4, 2023.
  1. Aug 23, 2023 at 7:08 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Those that ran into the issue of the coil hitting the bump mount. Are both of you on fox coilovers?
  2. Aug 23, 2023 at 7:23 AM
    heckler66
    heckler66 [OP] New Member
    2012 Tundra CM 4x4
    Icon Billet Upper CA King 2.5 Fr / Rr Deaver U748 Victory 4x4 bumper RCI Skid plates Baja Designs lights
    Yes, Fox 2.5 w/ 800lb coil
    reywcms likes this.
  3. Aug 23, 2023 at 7:32 AM
    jojo9878
    jojo9878 New Member
    Joseph
    2016 magnetic grey 1794
    Front: 2.5 king 2.5 coil overs Rear: 2.5 kings
    I’m running king 2.5s with 800lb springs from
    Camburg
    reywcms likes this.
  4. Aug 23, 2023 at 7:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Interesting.
  5. Aug 23, 2023 at 7:50 AM
    jojo9878
    jojo9878 New Member
    Joseph
    I just chopped the front bump stop off and kept the other one in the back. Since we are on bump stop discussion. Where do we mount the hydro bump on the camburg kit?
    reywcms likes this.
  6. Aug 23, 2023 at 8:18 AM
    heckler66
    2012 Tundra CM 4x4
    From what I can tell, you’d have to chop the rear factory bump stop mount and fab up a bump stop bucket around there. There is a strike pad on the Camburg LCA near the rear.
  7. Aug 23, 2023 at 8:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hydro for the front? Will need to be on the backside or middle just given the lack of space. Correct the other one gets removed also
  8. Aug 23, 2023 at 8:31 AM
    Vizsla
    Vizsla 2 = 2.5
    Too late now, but might be enough clearance for the front bump once the limit straps are set? The hydro bump location replaces the rear bump stop, there is a strike plate on the lower control arm for it. Highly recommend the hydro bump, don’t need to run the heavy compression valving in the bypass with the bump, better ride quality/easier to tune. Sorry been busy, will reply to your dm soon as I get a chance.
    snivilous, joonbug and reywcms like this.
  9. Sep 4, 2023 at 11:45 AM
    jojo9878
    jojo9878 New Member
    Joseph
    Anyone have an any instructions on building the LT CV axles. I need to rebuild mine because the Threads on the outer cv are missed up and the boots are torn so I’m looking into building a set. I understand the inside has a retention clip that’s easy to get off. But the outside one I have no clue how to do. I know a couple of guys are have the same question. I just don’t know if I wanna spend 2k on rcv axles right now
  10. Sep 4, 2023 at 12:05 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @Vizsla has rebuilt his many times.
  11. Sep 4, 2023 at 1:42 PM
    jojo9878
    jojo9878 New Member
    Joseph
    I know @heckler66 and I were wondering how to do it. my kit came with them pre assembled but I want a spare
  12. Sep 4, 2023 at 6:11 PM
    Vizsla
    Vizsla 2 = 2.5
    Instructions for building LT CV axles
    https://www.chaosfab.com/PDF/87300.pdf
    The outer is not easily removed. Completely remove inner CV from axle shaft, get a steel piece of pipe that the axle can slide down in, needs to be a close fit. Slide axle into pipe, find a hard surface(street, concrete, etc..), and smack the pipe into it till the clip breaks. You’re replacing the outer cups, might be able to cut the cup open with an angle grinder to remove alternatively.
    The small boot clamps will go on last when re-assembling, slide a WD 40 straw into the boot, then slide the boot into position with straw to relieve air pressure. Remove straw and clamp.
  13. Sep 6, 2023 at 11:11 PM
    Trdripper
    Trdripper New Member
    Bronze 2nd Gen
    King 3.0 front Coilovers with TC UCA King 3.0 rear Bypass shocks
    Anyone have any number figures on rear travel with a SUA and some 16 inch stroke bypasses…?
  14. Sep 7, 2023 at 3:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    16”-19” depending on the bed cage and shackles etc. I see about 18” with no straps.
    heckler66[OP] likes this.
  15. Sep 7, 2023 at 6:51 AM
    Trdripper
    Bronze 2nd Gen
    Good to know. I was hoping for about 18. I have a budget of about $10-12k to take my rig to the next level. Don’t really wanna buy brand new so hoping to find something with a decent priced used kit… time will tell
  16. Sep 7, 2023 at 6:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’d sell you my kit if my shop was ready for the truck for the next phase.
  17. Sep 7, 2023 at 6:55 AM
    Trdripper
    Bronze 2nd Gen
    When will they be ready? Or when do you expect your kit to come off I should say
  18. Sep 7, 2023 at 7:05 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Not sure but wouldn’t be until after February.
  19. Sep 22, 2023 at 6:32 AM
    heckler66
    2012 Tundra CM 4x4
    Mocked up a reservoir mount. Made the tolerance on the snug side so ill have to trim the stickers on the tube. Uses factory M10 screw locations and tucks along the frame rail.61DE3E76-3238-486C-A201-9BAFA4D9F258.jpg
  20. Sep 22, 2023 at 7:47 AM
    #50
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks sweet!
    heckler66[QUOTED][OP] likes this.
  21. Jan 31, 2024 at 6:48 PM
    #51
    heckler66
    2012 Tundra CM 4x4
    Regarding sag, anyone have any numbers for what kind of front sag they are running on LT setups? I’m running about 5” sag on 16” travel so just over 30%. This is with a single 800lb spring with no tender spring. I have limit straps set to about 1/8” shock shaft travel below full extension.
  22. Jan 31, 2024 at 7:56 PM
    #52
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LT front kit you have is a camburg?
  23. Jan 31, 2024 at 8:06 PM
    #53
    heckler66
    2012 Tundra CM 4x4
    Yes Camburg. Running 2.5 Fox with no Bypasses yet.
    reywcms likes this.
  24. Feb 4, 2024 at 7:06 PM
    #54
    heckler66
    2012 Tundra CM 4x4
    Mocked up a ghetto pump guard since I don’t have fender liners anymore. We’ve been getting a ton of rain lately and didn’t want them to be pounded with water no stop. Plan to make a nicer looking one out of aluminum soon but had steel on hand. Also made a pump filter relocation with some cheap parts from Ace and 2 Uni breather filters (~$55).
  25. Feb 4, 2024 at 7:08 PM
    #55
    jojo9878
    jojo9878 New Member
    Joseph
    I still haven’t relocated mine. I just keep slamming my tire into it lol. I need to fix that
  26. Feb 4, 2024 at 7:16 PM
    #56
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Careful with that pre filter- I did that before and still water logged the intake filter. I’ve got a parts list for the relocation also if needed.
    Mountun Goat and Peeeheeuuu like this.
  27. Feb 4, 2024 at 7:42 PM
    #57
    heckler66
    2012 Tundra CM 4x4
    Planning on redoing the SAI plumbing like yours but with the cheap hose I used I didn’t want to get close to anything hot. Also curious how you’re dealing with air intake rerouting! I had some prefilter material and figured it was better than nothing at the moment.
  28. Feb 4, 2024 at 8:30 PM
    #58
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ve got a different airbox with a large cone style filter and plate in wheel well. Currently working a much better airbox system the moves the box up further. Since I’ll be cutting all the wheel well out. More to come on that
  29. Feb 19, 2024 at 9:57 AM
    #59
    heckler66
    2012 Tundra CM 4x4
    Here is my attempt at the pump intake relocation. Didn’t consider the large grommet in firewall but it still works as intended. Machined the hose adapter for -AN10 fittings and made a manifold with -AN10 to 5/8” for a clamp on filter.
  30. Feb 19, 2024 at 12:18 PM
    #60
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks damn good
    coTony and heckler66[QUOTED][OP] like this.
